Question about Canon MV920 Mini DV Digital Camcorder
At the bottom of the display screen a small red flashing symbol has appeared which resembles a man in a rowing boat with a diagonal red line through it. what is this and how do I get rid of it? Thanks in anticipation. Dave H
  • daveh209 Sep 27, 2010
    Thanks for the solution to this problem, I didn't realise this battery existed. You are spot on. Thanks again.
    Dave and Don.
  • Canon Master
  • 19,396 Answers
Hi Dave.
The symbol below means that you need to replace the backup battery:
The backup battery must be replaced every few years, here instructions:
aac2b89.gat the bottom of the display screen a small red - moz-screenshot.png><br /><br /><img src=
The battery can be purchased at any camera shop, it is a CR1616 Li 55-57 Mah. Here online retailers:
Sony Battery - CR1616 - Li 57 mAh
Varta Electronics Battery - CR1616 - Li 55 mAh
If you repute this solution helpful, then please do not forget to accept the solution. Your rating is important.
Many thanks.
Ginko.
Posted on Sep 27, 2010
  • Ginko
    Ginko Sep 27, 2010
    Hi.
    You are welcome.
    Have a good day.
    Ginko.
Hi, I see a flashing red symbol very small rectangle looks like it has a diagonal red line through it. it is on the lower right side of my screen, above the area where the symbol for "remote"...
try to reset it by taking out the battery for a few min. then put the battery back in an turn it on. if that don't work go to www.canon.com click on Brochures & Manuals an down load the manual for your canon free.
Jun 07, 2011 | Canon Elura 100 Mini DV Digital Camcorder
Game 100 professor layton and the curious village please solve
Most of the squares you make will be tilted 45 degrees to the side, and their sizes will vary as well.
Start by looking for pins you can connect to create squares at a diagonal. Hint 02 You want more specifics? All right, here's the location of one of the squares. Connect the four pins in the top-left corner to form a tiny square.
Just so you know, this is the only square on the board that isn't tilted. Hint 03 The largest square contains the pin that's third from the top on the left column and the bottom pin from the far-right column.
You also need to form a small diagonal block using the two pins lined up diagonally on the bottom-left portion of the board. There are two more small squares just like this one on the board. Solution For square 1, use pins 1 and 2 from row 1, and pins 1 and 2 from row 2.
Square 2 uses pin 1 from row 4, pins 1 and 3 from row 5 and pin 1 from row 6.
Square 3 has pin 3 from row 3, pins 2 and 4 from row 4 and pin 4 from row 5.
Square 4 is formed with pin 5 from row 1, pins 4 and 6 from row 2 and pin 4 in row 3.
Square 5 involves pin 3 from row 1, pin 5 in row 2, pin 2 in row 3 and pin 3 in row 4.
Square 6 has pin 3 in row 2, pin 5 in row 3, pin 2 in row 5 and pin 3 in row 6.
Square 7 uses pin 4 in row 1, pin 1 in row 3, pin 5 from row 4 and pin 2 in row 6.
May 31, 2011 | Nintendo Professor Layton & the Curious...
I have a very small icon in red on the viewing
From what you are saying it sounds like the battery warning symbol. Have a look at page 150 onwards in the instruction manual. All the symbols are displayed there.
Mar 14, 2010 | Canon MV530i Mini DV Digital Camcorder
I have a zr100 camcorder and I have a red flashing icon underneath the battery icon. It looks like a boat with a diagonal line through it with an arrow to the right of the line.
On page 24 of the manuel it shows the symbol that you mentioned below the battery symbol. It's labeled item 4. Which states "flashes in red when the lithium button battery is not installed, or when it needs replacing". I guess you need to check the lithium battery with a voltmeter to see if it's any good.
Dec 04, 2009 | Canon Video Cameras
Model MV6i Camera works but have flashing red icon adjacent battery icon which looks like a 'little man in a row boat '!
This symbol means that your backup battery needs to be replaced. It is a "button battery", type CR1616. Instructions for replacing it are in the manual, which is available to view or download here.
Aug 26, 2009 | Canon MV6iMC Mini DV Digital Camcorder
Flashing symbol
This symbol means that the backup battery needs to be changed. The backup battery is a button-type battery, CR1616. It is located under the main battery behind a small square panel. Instructions for changing it are in the manual -- look under "backup battery" in the index.
Apr 06, 2009 | Canon MV800i Mini DV Digital Camcorder
Red blinking on screen.
This symbol indicates that the backup (date/time) battery CR2025 needs to be replaced. This battery is held in a holder that slides out from the bottom of the camera. Pages 8 and 104 in the manual (available here) detail how to do this.
Dec 11, 2008 | Canon MV30i Mini DV Digital Camcorder
Flashing warning
Your CR1616 battery is not installed properly. +sign to +sign
lockwood.b@sbcglobal.net
Dec 22, 2007 | Video Cameras
Canon MV920 Mini DV Digital Camcorder Logo
316 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
