Question about Linksys SRW224G4 24-Port Ethernet Switch
I have a Linksys SRW224G4 connected to a Netgear DG834 ADSL 2 modem 4 port router. It seems to drop the connection every 5 minutes or so. I've checked all the ethernet cables with a tester to ensure no faults. Any idea what the problem could be?
  • 4,348 Answers
The linksys may be assigning IP addresses that conflict with the router. Usually you need to disable Dynamic IP assignment in downstream routers and switches.
Posted on Nov 04, 2010
  • vickijohn Dec 29, 2010
    i also faced the same issues which you are facing and my friend told me about "ijinni technician" i contacted them at WWW. Ijinni. Com for any issues Just open the website and you can chat with the experts who are Microsoft certified technicians and will fix the issue itself on the spot or u can call them through Skype or contact and for more visit their website as it is very user friendly website. Just click on the chat as the response rate will be very fast from them and they have fixed my issues in no time.
Using Netgear DG834 ADSL Modem, want to add a netgear WNDR3700 Wireless Router to act as an assess point
The simplest way to add more ethernet ports is to use a network hub and connect it to the Netgear DG834 instead of the Netgear WNDR3700. This does not require any configuration.
Mar 08, 2012 | Apple MacBook Pro Laptop Computer with...
I got a NETGEAR router and I have been trying to get my Motorola SURFboard to recognize it. I had the USB connection installed and the NETGEAR uses ethernet, so I tried to install the ethernet but my...
The Cable modem must be disconnected from the computer. You cannot use USB and Ethernet at the same time.
1. Turn off power to the Cable Modem and the Netgear Router. Do the same with the computer.
2. Connect an ethernet cable from the modem to the router's WAN (Internet) port.
3. Connect another ethernet cable from one of the remaining 4 LAN ports on the router to the computer's ethernet port.
4. Now power on the Cable Modem ONLY. Wait for the modem to sync up with your service provider
5. After about 2-5 minutes power up the router and wait about 1-2 minutes.
6. Now power on your PC.
Check and see if you have internet access. If not you may have to uninstall any cable modem software related to USB connection. if this is the case, then you may have to repeat steps 4-6.
Since most cable internet providers do not use proprietary connection settings, your internet connection should be up and running without changing any settings in the router or modem.
If this does not resolve your issues, we can continue to work with you.
Nov 29, 2010 | Arris SURFboard® SB5101 Cable Modem
I lost my netgear installatio cd, what do i do to install it?
You dont need that CD, in fact I recommend NOT using it.
1. Power off your cable or dsl modem for about 30 minutes 2. Also power of the router 2. Connect a cable from the modem to the Internet port on the Linksys router 3. Connect your PC to the router. 4. Power ONLY the dsl or cable modem on NOT the router. 5. After about 1 minute power on the router.
Should work now.
Oct 29, 2009 | Linksys Wireless-G Broadband Router
It become very slow when I switch my adsl to adsl 2+
Firmware Upgrade
1. Please verify the model and version of the router underneath it.
2. Go to ftp://downloads.netgear.com/files/dg834v2_dg834gv2_3_01_38_uk_only.zip to download the firmaware.
3. Save the file to the Desktop.
Note: Please perform firmware upgrade with wired or Ethernet connection only. Before you upgrade, write down all current settings as you need to enter them manually after upgrading.
4. Using the computer hardwired on the router, open any web browser like Internet Explorer or Netscape Navigator.
5. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.0.1 in the address field and click Enter or Return key.
6. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
7. Click on Maintenance and then Router Upgrade.
8. Click Browse and locate the upgrade file in your Desktop. Click Upload.
9. Please wait for the router to reboot.
10. Reset the router.
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then please plug it back in.
Apr 15, 2009 | NetGear DG834 Router
My netgear dg834 wired router ceased to get an ADSL connection for no apparent reason? The ADSL connection, filter and cabling all work (as I've tried with a modem). Hmmm?
I'd try a hard reset by unplugging the router, holding in the reset button for 30 seconds, while you plug the router in and see if you can get it going again. If not its time for a new one.
Nov 06, 2008 | Computers & Internet
Connecting another router
i would'nt recommend it, theres no need for two unless you have mote than 4 hardwired pc's and 8 wireless, especially if they are both modem/routers, you cannot use two, only one modem/router and one router
Sep 15, 2008 | NetGear DG834G Router
Dual Routers?
Disable DHCP in the router. Connect the modem to a LAN jack on the router. You'll have 3 LAN ports. If you need more ports, buy a hub. (You can change the default IP address on the Linksys, but you can't forward through 2 NATs.)
Apr 27, 2008 | Computers & Internet
How to connect linksys router with aztech adsl modem
To setup your router
first check..
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If it is not, contact your Internet Service Provider. If it can go online,
to setup connection..
Step 1:
Connect the Broadband modem to the router’s WAN or Internet port.
Step 2:
Connect the computer to any available numbered port (1, 2, 3 or 4).
NOTE: In this example, we’ll connect the computer to port number 3.
Step 3:
Make sure the power adapter is plugged to an available power outlet.
Step 4:
check if you are able to go online wired..
if not your router has to be configured first,
to config your router i need some more information
your internet service providers (isp)name , and how many computers do u have totally..
Nov 16, 2007 | Computers & Internet
Setting up linksys adsl2 modem
The ADSL, Ethernet, and USB ports are located at the back of a Linksys modem. These ports are where the phone cable and computer will be connected. The ADSL Line should be connected to the ADSL port and the computer either be connected to Ethernet or the USB port., If u r using a ethernet cable no need to run the setup cd just connect the ethernet cable and contact ur isp..
do not worry about ur sagem modem, let it be inside.. just connect ethernet cables alone..
To setup a Linksys ADSL Modem with usb cable you need to perform two steps:
  1. Connecting the Devices Together
  2. Installing the USB Driver
Step 1:
Connect the phone cable to the wall jack with ADSL service and then connect the other end to the ADSL port of the modem.
Step 2:
Step 3:
Connect the USB to the USB port on the back of the modem and then connect the other end top the USB port of the computer.
Step 4:
Power on the modem. After connecting the device together, install the USB driver. For instructions, follow the steps below.
Step 1:
Power on the computer.
Step 2:
When the Hardware Update Wizard window appears. Click Install the software automatically (Recommended).
NOTE: Windows XP has pre-installed drivers for the ADSL2MUE and will automatically install the USB driver for the modem.
Step 3:
Click Finish.
Nov 06, 2007 | Computers & Internet
Open Questions:
Linksys SRW224G4 24-Port Ethernet Switch Logo
232 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
