Question about Kenmore Elite HE4 Electric Dryer
Removing cabinet of kenmore elite washing machine
Please help me remove the cabinet. I have removed screws, removed brass clips, un hooked lid switch. I am having problems with the hoses still attaced to the cabinet. I think they are the detergent hoses. Thank you
  • Anonymous Dec 20, 2008
    how do you remove the brass clips
Help me remove back panel on kenmore elite top load we have the bottom lifting but can't get the top,
Posted on Jan 17, 2009
  • 5,911 Answers
It would help if I had your model number, but I'm assuming you have a Kenmore top loader that has the fill hoses attached under the left rear of the washer casing. With the brass clips removed, you should be able to move the cabinet off the frame slightly to give you enough room to reach your hand under the wash tub rim and disconnect the hoses. You may need a set of pliers to remove the hose clamps. I hope this helps you.
If you are having difficulty, please post back and let me know.
Was there a reason why you were removing the cabinet? Do you need further assistance?
Posted on May 23, 2008
Need help raising top of washer.....so that contact going into hole to make washer operate can be repaired.
Remove the left and right screws from the comtrol console base.
Pull the control console forward and then rotate it to the rear of the machine.
Use a flat blade screw driver to un-hook the S clips from the right and left sides of the cabinet.
Unhook the lid switch wires.
Pull the cabinet forward to remove it from the machine.
Do your repair.
Reverse the above order to re-assemble the machine.
Jan 10, 2011 | Kenmore Washing Machines
I have Kenmore 90 series washer its lid switch is not working I want to replace my self how I can fix it model # 110 20922991
remove the top control panel,there are 2 brass colored clips that hold the cabinet on,remove these clips and tilt the cabinet forward to remove it,then you can replace the lid switch
Oct 14, 2010 | Kenmore Washing Machines
I have a Kenmore Elite top washer and was wondering how to lift the top to clean
Disconnect your Kenmore Oasis washing machine from its power source. Make sure that your washer is unplugged before beginning to disassemble it.
Remove the screws that hold the control console to the top of your Oasis washer. In some Kenmore Oasis models, the two screws may be covered by plastic end caps. After removing the screws, set them aside until you are ready to replace them.
Flip the console up, back and out of the way.
Locate the cabinet clips on the top of your Kenmore Oasis washer. These clips are located toward the back of the washer top and would be hidden by the console if it were not currently flipped up.
5
Slide your screwdriver underneath the metal cabinet clips. Wiggle the screwdriver back and forth to gently pry the cabinet clips free.
6
Disconnect the group of colored wires that plug into the top of the washer from the control console. These wires control the lid switch on your Kenmore washing machine. To disconnect, grasp the white plastic clip and pull gently.
7
Remove the washing machine cabinet. Tilt the cabinet towards you, and then lift the entire cabinet up and off of its platform.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 23, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
How to replace kenmore elite washer model 110 16962503 lid switch
Let me offer you a generic solution for most of the Kenmore washers :-
There are 2 screws that secure the console to the cabinet top. The are located in the front or rear corners, and on a Kenmore, may be hidden behind the end caps. Remove the screws, and tilt the cabinet backwards. Remove the 2 gold clips, and disconnect the wiring harness. Tilt the cabinet forward, and off of the base. The lid switch can now be accessed from inside the cabinet (I sit inside).
Hope i helped you.
Thanks.
Aug 14, 2009 | Kenmore Washing Machines
Need to disassemble a kenmore elite oasis dryer
5
6
7
Aug 03, 2009 | Kenmore Elite Oasis ST 6806 Electric Dryer
Removing the top of a Kenmore Elite Oasis Washer to replace hose
5
6
7
May 17, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Washing machine filling with water not finishing cycle
probably just a bad lid switch or best case loose hinge screws if lid switch is located on right side of lid opening try pressing it down with a pencil or small screw driver if works replaced lid switch by removing console screws under end caps or if newer modes switch located under rear hinge area remove console by pressing clips at lower edge each end of console ..remove brass colored clips on older model and pull cabinet or newer model switch is mounted to top of cabinet under console
Nov 15, 2008 | Kenmore 22422 Top Load Washer
How do I open the top of a Kenmore washer 80 series. Model 11092284100?
HI thanks for your question. 2 screws on each side of console. remove. lift up console. 2 brass clips , remove. disconnect lid switch connector. pull cabinet off. thanks the appliance doc. please rate my answer thanks.
Oct 09, 2008 | Kenmore Washing Machines
I need disassembly instructions for a Kenmore Automatic Washer model number 110.24942300. I am trying to help a neighbor correct an internal water leak and I don't want to destroy any fasteners if...
HI. thanks for the question. the cabinet comes off. to remove. 2 screws on each corner, of the console. remove. lift console. 2 brass clips . remove them. disconnect lid switch harness. remove the cabinet. look for the leak. thanks the appliance doc. please rate my answer.
Oct 07, 2008 | Electrolux Washing Machines
Lid Switch for Washing Machine
pop trims from ends of control panel
remove screws from bottom of control panel under trims
slide control panel forward and up from the bottom, and flip over backwards on its hinges
undo brass clips under control panel, NOTE* how the clips are installed
unplug lid switch cable
lift cabinet slide forward and remove cabinet
turn cabinet upside down
lid switch is accessible
assemble in reverse order
Aug 29, 2008 | Washing Machines
Kenmore Elite HE4 Electric Dryer Logo
756 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
