Question about Evesham Nav-Cam 7700 GPS Receiver
No audio directions
Eveerything else appears to be working, however no voice directions. Unit is not muted
    Problem Solver:
  • 5 Answers
Try doing a hard reset underneath the sat nav is a small slide reset remove sd card first, reinsert and switch on, good luck
Posted on Jun 11, 2008
Does this unit have voice descriptions
You don't mention the model number, but I don't know of a GPS that doesn't have voice directions. Check to see if your unit can mute the voice or maybe the volume is down.
Jun 17, 2015 | GPS
Nuvi 2555mt lost voice
First, do you hear beeps when you press a selection on the screen? If yes, then your speaker is OK and the audio circuits are OK in the unit. Make sure that you have a voice selected in the voice menu. Some units have an audio mixer screen and provide different volume settings for navigation (voice) and system (beeps). maybe the volume for the voice (navigation) is set to off. If you don't hear any beeps when you touch the screen AND you don't hear a voice, make sure that the sound isn't set to be muted. If the sound isn't muted, you may have a defective speaker. More information on audio issues can be found here:
SHARCNET USA Out of Warranty GPS Digital Camera Repair
Apr 18, 2014 | Garmin nuvi 260W GPS Receiver
Lost audio
1. First, make sure that the sound is not checked to be muted.
2. Make sure that you have a text-to-speech (TTS) voice selected in the language menu.
3. When you press a function on the screen, do you hear a beep? If so, this indicates that the sound is not muted and that the audio circuits are working. If you don't hear any beeps when pressing a function on the screen AND there are no voice directions, then I would suspect a defective speaker. More information can be found here:
Mar 24, 2014 | Garmin nuvi 255W GPS Receiver
I'm not getting verbal directions from my Garmin nuvi 260W. How can I fix this problem. A day ago it was working properly.
If you are not receiving any sound on your N?vi 2xx thefirst thing to check is that the sound is not muted. To ensure that your unitssound is not muted please perform the following: Turn the device on Press the Volume button on the 'Where To?', 'View Map'screen Ensure the Mute box is not 'checked' If the mute button is not 'ticked', you will need to changethe voice to ensure that the preset voice is not faulty: Turn the device on Touch the Tool icon Touch Settings Touch Language Touch the language voice next to Voice Scroll through and select another appropriate voice
If changing the voice is not helping you will need to ensure that you arerunning the latest software which can be done by installing a program calledWebUpdater. WebUpdater can be installed via the link below:
Once updated please allow the unit to reboot which will ensure the softwaresuccessfully installs.
Jan 21, 2011 | Garmin nuvi 260W GPS Receiver
I have a Sharp LC37D43U TV that has no audio. The volume indicator shows can be moved up or down but no sound comes through the speakers. The picture works fine. I have nothing else connected to the TV....
It appears you ve discovered the sound task levers required to adjustment properties. Your Tv can still move levers even when the volume is set to mute. Select the unmute button before any voice or audio would be reactivated. Assuming that seting the TV on mute has predominant integrety over the volume functions where not unmuting usually with the same button on the remote would not achieve accessibility to the volume functions. refer to the TV user guide for diagnostic audios. Good luck
Jan 09, 2011 | Sharp Televison & Video
Speaker works for playing of MP3 songs but does not give direction instructions when on purely satnav. Have tried increasing/decreasing volume but no sound comes out of the unit. Have also done a factory...
spoken directions are only available when the computer generated voice has been activated. If you choose any other voice, you will no longer get spoken directions
Oct 05, 2010 | Tomtom GO 730T Car GPS Receiver
It just stopped talking. No voice directions, on
Hit the menu buttom, go to settings, then go to volume and see if it is muted. Sounds like the mute or volume down button got inadvertantly hit and turned down or muted. If this does not work, turn the unit over and look under the fold up antenna for a reset button. Depress this button until the unit restarts and should reset the unit back to factory default settings and get you on your way. Good luck!!! If these don't help you, call the garmin support number at :1-800-800-1020. Hope this helps!
Aug 01, 2009 | Garmin nuvi 885T GPS Receiver
Voice stopped working
This may be a cold solder connection or mechanicaly defective component on the circuit board. There are many parts in that unit that can cause the described fault.
Jerry G.
May 29, 2008 | Garmin StreetPilot C330 GPS Receiver
No voice or sound
Did you check that you didn't activate mute?
If it is on mute. Press both volume buttons at the same time you will hear two descending audio tones.
Jan 10, 2008 | Motorola Mobility H500 Wireless Headset
Getting voice directions
On switching on go to setup click on volume turn all the way up by using + key
Oct 03, 2007 | Evesham Nav-Cam 7700 GPS Receiver
Evesham Nav-Cam 7700 GPS Receiver Logo
53 people viewed this question
Top Evesham GPS Experts
Jerry Greenberg
Jerry Greenberg
Illimar Saatvali
Illimar Saatvali
Are you an Evesham GPS Expert? Answer questions, earn points and help others
