Question about Mitsubishi WS-55805 55" Rear Projection Television
Turns Off the last thig that was occurring was that it would show a lot of random green spots of different sizes and shapes. This would go on for about half an hour before it turns off by itself. But it won't even show an image. I turn it on and the next second it turns off. A couple of years ago I call Anderson's TV repair and they came in a resoldered some of the pins, and it worked fine until yesterday. Do you think some other pins came loose now or is there a short circuit somewhere? Any assistance is greatly appreciated. Luis Diaz
  • 3 more comments
  • luisdiaz00 May 26, 2008
    This is great advice. Just tell me which is the convergence module and I'll check it out. Also do you think I should get a copy of the service manual to help out? If you think so, do you know where I can get a copy?
    Thanx again
  • luisdiaz00 May 29, 2008
    Can you tell me where the convergence module is . Also I know what a capacitor is and I know what a resistor is. i also know that capacitors hold charges. What I don't know is how to discharge the capacitor so I don't electrocute myself.
    I used one of the links on this web page and purhcased the training manual but I have yet to find the service manual. Do you know where I can find it?
    Thanx again
  • luisdiaz00 May 30, 2008
    Sorry IrishDruid, servicemanuals.vstore.ca does not carry the WS55805 service manual.
    Thanx jaime867, I ordered the service manual for the WS55805 from the website you mentioned www.completeservicemanuals.com. It did not give me an option to download, so I guess it will be mailed?
    IrishDruid, thanx for the info. I did have a TV technician come and look at the TV today. He charged me $60 to tell me it was the convergence IC and wanted $500 to replace it.
    Sergeant:
    Champion:
  • 304 Answers
it is possible that some of parts need to be re soldered or you still need someone to check up the unit..
`jack
Posted on May 24, 2008
  • Elizabeth Krijt
    Elizabeth Krijt May 24, 2008
    Check for bad solder on
    convergence module. May have bad stk's. Do not neglect looking
    for bad solder on dsignal and defl boards. Mitsubishi is very prone
    to bad solder.
    President:
  • 2,712 Answers
It could be the convergence IC's that need replacement. It could also be a problem with the many capacitors/resistors around the IC's.
If you are confident enough to try a DIY, here is a good step by step guide with pics to assist you. But beware, if you have no prior experience, I wouldn't recommend opening the set, as there are voltages inside that can KILL.
I suggest you get a qualified service technician to take a look and get the TV fixed.
  • 3 more comments
  • Swilin Sampson
    Swilin Sampson May 24, 2008
    The problem could also be with a failing power board. In any case, I recommend getting a qualified technician to take a look.
  • Swilin Sampson
    Swilin Sampson May 29, 2008
    You can get the service manual (and parts) from HERE.
    If you buy the manual from them, they will even provide online installation guide as you fix. Check it out..
  • Swilin Sampson
    Swilin Sampson May 30, 2008
    Click HERE for a detailed explanation of how to discharge a capacitor.
    Also, the convergence modules will be located on the heat sinks on the main board. Here is a pic of the modules on the heatsink:
    But once again , be VERY careful there is enough charge in a tv capacitor to kill you and will probably kill the capacitor (if it has a high enough capacity)
    due to the extremely high current flowing through it if you do that.
    The normal procedure is to connect both lead with an appropriate
    resistance. And not only once, because large capacitors can
    spontaneously rebuild some residual charge after being discharged
    (still enough to give you a serious shock). Normally both leads are
    connected through a fixed capacitor discharge bridge, which stays on
    the leads while working on the system. Once ready for testing, the
    bridges are removed.
    I would still recommend getting a TV technician to repair this.
  • Swilin Sampson
    Sheesh! Well, take a look at the link I provided you earlier for a step by step guide on how to do this..and DO BE VERY CAREFUL.
    Also, as a precaution, better use an anti-static wrist band ( get them from any elctronics shop or radio Shack) and rubber boots. Also make sure you do not use magnetised screwdrivers, and dont touch any part of the circuitry unnecesarily..
    Also check for busted capacitors around the IC's. They are easy to identify, they will have a swollen cap. Here is a sample pic:
    The capacitors are usually 680-1000mf and 16-35V. I would recommend using 35 of 50V as replacements. They may a bit alrger, but will fit and last longer. Just check the capacitance value of the capacitor/s that need to be replaced (680-1000mF) and make sure this bit is correct. And here is a LINK to show you how to read the value of a resistor based on their color codes. Check with an Ohmeter to see that the reading of the resistors match the value of the color codes. If they dont, they are most likely faulty.
    Good luck with your repair!
  • Swilin Sampson
    Also you make sure that the TV is unplugged from the AC socket for at leat 24-48 hours before you start any repairs, for the capacitors to discharge as much as possible..
  • 2,322 Answers
Do you see the colors like a 3D image?
If you do, then you have a convergence failure on your TV. Common failure on these TVs.
  • 1 more comment
  • Jaime Hernandez May 24, 2008
    It might a DIY if you know how to solder and some basic use of a multimeter.
    This type of repair could cost you $300.00 to $ 400.00, if you do it yourself it will cost a lot less.
  • Jaime Hernandez May 29, 2008
    I could not find a place for a free download. You can visit this website and for about $8.00 you can get the complete service manual with all the parts listed.
  • Jaime Hernandez May 30, 2008
    You can send them an email to ask them how they will send you the service manual.
    Anyways, if you replace the parts yourself it will cost you a lot less money even paying the tech for telling you the problem on your TV. I mentioned that the convergence circuit failed in my post as well.
    Let me know if you need further assistance.
    Good Luck.
    Sergeant:
    Champion:
  • 230 Answers
May be there will be some discontinuity in connections inside if you find it and soltered it the problem will be recovered
  • balachander megavarnam
    balachander megavarnam May 24, 2008
    the pins inside may got loosed because of that this will happen so check that
    or you need to replace the IC's that is not working
I have a sony lcd projection tv model kf-60xbr800, green spots on the lower right corner , it start with one spot and now the spot are all over the screen
Those Rear LCD TVs get bad light engine on some. Causes fuzzy spots size of quarter. Or sharp small bright spots looks like road map or 'stars'. Need new/rebuilt light engine.
Apr 08, 2014 | Sony Grand WEGA KDF-60WF655 60" Rear...
What are the advantages of latex dog toys?
Latex dog toys come in different shapes and s, so you have a lot of options to choose from. Moreover, latex toys are durable and last for a long period of time (compared to vinyl).
Aug 23, 2012 | Baby Einstein Dogs
1996 Toyota Camry idles high randomly?
Check and see if it has thrown any codes. Autozone will hook up their OBD for free. My thinking it is a sensor or a vacuum leak. Good luck.
Apr 05, 2017 | Toyota Cars & Trucks
My Canon Powershot SD880 sometimes takes pictures that have 'ghosts' or litter spots throughout the picture. This happens more often in dark settings and at night. Any ideas?
This is normal behavior when shooting in low light. Just like when someone is speaking softly into the phone, you may turn up the volume on your end. Any background noise, you can now hear more.
Similarly, when there is low light, the camera turns up the amplification on each pixel. Some pixels naturally have a bit more background noise than others, and these show up as bright spots. A higher ISO setting where the camera is more responsive to light is where this occurs.
At a high ISO, taking a picture of pure black shows up as a mottled grey with a few bright spots for pixels that have a lot of noise.
You can overcome this if you have a tripod - set the camera to manual and a use a lower ISO setting. Rotat the selection wheel to M for manual and then press the ISO (just above the function set) button to scroll through different ISO settings.
Photoshop and other programs have noise reduction tools and a tools to remove "hot" spots as well.
Mar 02, 2011 | Canon PowerShot SD880 IS / Digital IXUS...
Panasonic multimedia projection HDGT tv color spots displayed
PANASONIC..PT-52LCX15. STARTED TO A LIGHT COMES ON THE SCREEN. THEN TWO LIGHTS. FINALLY TV DONT COMES ON. I PUT ON THE TV, AND ON BOTTON START BLINKING AND TV DONT COME ON..I TAKE OUT THE TV LAMP..IT LOOKS GOOD NOT BURN. SHOULD I REPLACE IT??
Oct 18, 2009 | Panasonic Televison & Video
Light green and pink spots on my hd tv!!!
For the spots....
I had the same problem, first a blue spot then a green spot showed up. I contacted Panasonic Customer Support. They sent someone out and they fixed the TV for free. They reprogrammed the EEPROM chip in the TV. It is a defect. My TV was 4 years old and out of warranty. They came out last week.
So long as it is not happening by something you have done. It will be fixed free of charge. Call them, it solves the problem.
May 27, 2009 | Panasonic PT-44LCX65 Television
Randomly missing print spots just off center of page
this happens to myne all the time try cleaning all of the rolers and try a different brand of paper
Jan 07, 2009 | Samsung ML 1210 Laser Printer
GREEN SPOTS IN PICTURE
Are they spaced evenly?
If so, an IC responsible for control of the individual pixels has failed.
If not - well, I can't think of anything that would cause a random appearance of any color.
Aug 27, 2008 | Insignia IS-LCDTV32 32 in. Television
Spots on my display
There's nothing wrong with your camcorder. Cystal-shaped spots, black spots, and bright spots of light (red, green, or blue) can appear on the LCD monitor for a variety of reasons. These spots are not being recorded on your tape. But if these are distracting your videotaping, consider taking a slightly different shooting angle and the spots should go away.
Sep 06, 2005 | RCA CC-432 Camcorder
Mitsubishi WS-55805 55" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
