I'm trying to find the usermanual for the HNF6167 washing machine. I need to empty filters and don't know how to do it.
  • chocol8teluv Sep 27, 2010
    Thank you very much. I have followed the simple instructions and now have an empty filter as well as an empty washing machine. THANKYOU
  • Washing Mach... Master
  • 19,396 Answers
Hi.
To clean the filter follow the instructions below;
Manuals here:
NEXTRA (5573 Ko)
HOOVER NEXTRA6
HOOVER NEXTRA 7
Posted on Sep 27, 2010
  • Ginko
    Ginko Sep 27, 2010
    Hi.
    You are welcome.
    Have a good day.
    Ginko.
Check drain light comes on and machine will not spin or empty
You probably have a blocked sump. Empty the machine by hand and remove as much water as possible because you will need to remove the sump hose which is under the machine, place a shallow bowl or dish under it before taking it off or you could flood the floor. I've no idea what machine or model you have but you will probably need to tilt the machine away from the sump (if it is at the rear of the machine then tilt it forward ) undo the clamp holding it on and carefully pull it free from the tub, clean it out and replace it
Mar 25, 2017 | Miele Washing Machines
My kenmore fronload washer will not spin out water from cycle. when I opened the door after wash close were soaked and water in maching.
Not knowing the model of your machine, I can provide some generic advice. Please add a comment to this thread if you need more help. This is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum. While it's trying to get the water evacuated, you will probably see the machine doing a slow tumble for up to 8 minutes and you may also hear the empty pump running too.
You need to locate and clean the filter. Depending on the model there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom) Many models of this design also have a small hose to the left of the filter cap that you can pull out, remove a plug from and drain off any water in the filter before you remove the filter and get your floor wet, so take a look for this before you remove the filter and get soaked.
Jul 22, 2011 | Kenmore Washing Machines
Kenmore washer model111, will fill, agitate but won't drain? i am assuming that it is the water pump, but why would it fill up???
You need to locate and clean the filter. Depending on the model (not familiar which with the model you mention) there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom) Many models of this design also have a small hose to the right of the filter cap that you can pull out, remove a plug from and drain off any water in the filter before you remove the filter and get your floor wet, so take a look for this before you remove the filter and get soaked.
Not sure about your question "Why would it fill up" Why wouldn't it fill up? Like walking through an entry barrier and then discovering the exit is locked, at the time you go in, you don't know you can
Jul 07, 2011 | Kenmore Washing Machines
I am trying to change the greeting on my answering machine. i have a 5.8 v tech system. i don't know where my instructions are and can not get it to work.
You can download the manual at
http://vt.vtp-media.com/ecp/documents/product_Product/69/UserManual/1639/ia5854_manual_bkm.pdf
Jun 22, 2011 | Vtech IA5854 5.8 GHz Cordless Phone
Help.washing machine shows e60 error.i need to know how to fix it cheaply! i tried all of the above but no luck.
Hi! To reset press the reset button in for 5 seconds. The computer board needs resetting. You can also try to reset it by switching the machine off and unplugging it to allow any residual charge to clear from the memory chip. The next step is to clean out the filter at the front - remember to empty the water out first. After a couple of hours, switch the machine on, press reset and then spin to empty any remaining water. If the problem still persists then it is due to Fault in washing NTC sensor, wiring or main PCB. Please do rate this solution as FixYa and revert for further assistance. Thanks Rylee
Jun 13, 2009 | Zanussi ZWF1440 Front Load Washer
Looking for the instruction manual online
CLICK HERE
Please download asap - as it is stored on my personal FTP site, and will be removed in 48 hours.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 04, 2009 | Washing Machines
Programme problems hoover nextra megaload
I had this problem soon after I purchased mine. The engineer came out and readjusted the dial. Hope this helps.
Feb 26, 2009 | Hoover Nextra HNF 3157 Front Load Washer
Cleaning washing machine filter
There is no filter on this machine. The gray gooey substance is sludge (dirt) build up inside the tub. This can be caused from using too much detergent or a detergent that is not HE (high efficiency).
You can try running an empty cycle using the hottest water available with products such as "washer fresh", "affresh" or a cup of bleach to remove the build up.
Remember to use a HE detergent and you only need about 2 tablespoons per regular load.
Feb 09, 2009 | Hoover AAA160 Front Load Washer
Washing Machines Logo
267 people viewed this question
Top Washing Machines Experts
