Question about Panasonic NV-HS1000 S-VHS VCR
Panasonic NV-HS1000 VCR problem
I have a very high end Panasonic HS1000 VCR, its' about 10 years old, but has not been used very much the last 7 or 8 years. However I want to keep it, and so I have this problem that needs fixing:
It intermittently shuts down when it is playing or rewinding/fastforwarding,
the machine goes into standby mode. On turning it on, the tape can be heard moving forward or backwards not sure which, it can do that for a minute or so and while it does it no operations can be made. All of a sudden it stops the tape and all is well again for a while.
I've had this problem for many years, but I learned to live with it up until a few months ago when it just went into standby and now if I try to turn it on, it lights up for a few secs, then goes back into standby. I've got a tape trapped inside now as well.. I've heard form someone that this might be a faulty 'mode-switch'? If so, is this switch easy to replace? Where is it located? Where can I buy one? I have a parts machine I can use, so would be great if someone could help.. Thanks. John
No Signal when I insert tape to play
Posted on Aug 06, 2011
  • 4,234 Answers
Before you try anything too elaborate, change all of the belts. There are a number of safety features built into this unit to prevent the tape from getting damaged. If one of the reel tables is not turning when it should, the unit will shutdown. There are a number of similar checks made continuously as the machine runs. If you have no experience with these units, bing it in for service. The parts should not be more than $5-$25 total. Add in the local labor charge for the total repair bill. Basically this unit should be cleaned and the alignment checked after the belts have been changed.
Dan
Posted on May 23, 2008
Where can i get replacement recording/playback head.
From Curry's Partmaster. However it is priced at £144.96!
Feb 10, 2011 | Panasonic NV-HS1000 S-VHS VCR
He svhs outputs two vertical white lines on blue screen, what does this indicate please
It sounds like you are describing a test signal used to help tune the vcr to a TV. There should be a switch somewhere marked "test signal". Find it and switch it to off. It should go then. It could be on the back near the aerial connections.
Feb 04, 2011 | Panasonic NV-HS1000 S-VHS VCR
I have a Panasonic NV-FJ600 VCR which ejects every cassette which is loaded , and the two guide rollers remain at the rear of the machine and do not move forward to engage the tape .
If you mean the guides are on either side of the head drum, and the carriage is in eject position, the mechanism is out of alignment. Re-alignment and re-timing may require a workshop service by a professional Panasonic agent.
The bad news is the likely cost(s) involved if parts are replaced.
The NV-FJ600A VCRs were good models a few years ago, one of the first 'super long play' series Panasonic launched.
They use the Z-mech series of decks. These are not impossible to re-align/re-time, unlike previous mech designs, but depending on the extent of wear/damage, can prove uneconomical for a budget VCR which would now be close to 10 years old.
Oct 18, 2010 | Panasonic NV-HD680 VCR
Tape ejects when inserting into video player
check the tab on the back side of the tape- make sure its intact- if tab is missing it will not let you record - i've sometimes added tape to replace the tab ,,
Feb 02, 2009 | Panasonic NV-HS1000 S-VHS VCR
Unable to set up clock om my vhs panasonic, please help
You have to set the time and date on the remote controle, then send it by IR to the unit !
I dont have the exacte way to follow here, but you have an idee to to it !
Dec 21, 2008 | Panasonic NV-HS1000 S-VHS VCR
Panasonic Video Recorder has stopped working
looks like some kind of sensor within the mechanical part, its seems like the mechanism doesnt return fully to its original point giving you these kind of malfunctions, I suggest to take it
to an authorized dealer for a complete check up & tune up
Apr 15, 2008 | Panasonic NV-HS1000 S-VHS VCR
Tape wont play then ejects
I am this problem... please download service manual *pdf... jedlicka.j@gmail.com
Thanks
Oct 14, 2007 | Panasonic NV-HS1000 S-VHS VCR
Panasonic NV-HS1000 S-VHS VCR Logo
587 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
