Question about Panasonic Car Audio & Video
Hi i have a panasonic cq-c5355n ,to go in a 96 range rover the unit is a factory kex-mo946zrv 6cd stacker.how do i rewire for new stereo plees
techman
  • 3130 Answers
SOURCE: Panasonic cq-c8303u Car stereo problem
There is for sure a hook up problem my friend. There should be a memory wire that always has power to it even when the car or the ignition is off. Then there is a switched type wire that only comes on when the cars ignition is on. Check both of these wires in the car. Check the car wiring diagram to confirm this. To confirm the wiring in this vehicle, I Good Luck with this install. And if all else fails, don't take a chance and blow out the unit, take it to a pro to be installed. Good Luck found the right wiring diagram for your car. Confirm this wiring diagram with this one you have. Go here:http://www.the12volt.com/installbay/stereodetail/955.html
Posted on Jun 20, 2007
  • 78 Answers
SOURCE: Having problems fitting Panasonic CQ-C1323NW car stereo into Ford Fiesta
YOU SHOULD HAVE TWO LEADS IN THE CAR, ONE FOR POWER AND ONE FOR SPEAKERS, YOU WILL NEED A FORD TO ISO ADAPTOR LEAD AND THEN YOU WILL NEED THE LEAD WHICH CONNECTS TO THE PANASONIC RADIO
Posted on Dec 06, 2007
pjstanley
  • 185 Answers
SOURCE: i need a panasonic cq-c1101u
sorry cnt help u
Posted on Apr 06, 2008
Benimur
  • 6966 Answers
SOURCE: i need the wiring diagram
Any developments?
Cheers.
Posted on Aug 03, 2008
  • 28 Answers
SOURCE: How to remove Panasonic cq-c1301u unit from car
This is an interesting question. As to the fact that you didn't mention what kind of car you have, I can't give you exact instructions, but I can give you approximate instructions. Read all Instructions b4 you do anything and detach battery b4 working on system!!!!!!
1. Most car's require you to remove a dashboard panel, of not the whole thing. (on a side note, the panel on my jeep that has to be removed just pops out).
2. Next you need to unscrew the adapter kit from the car. A lot of older cars put Double DIN headunits into their cars, These are the larger sized headunits. Most after-market systems require a plastic adapter to allow them to fit into the larger space. As long as your new unit is the same size as the older unit, this piece can be reused.
3. Then you must remove the old headunit from the adapter. Most are either screwed in or have pressure pins that hold it in place. Either unscrew or carefully push down the pressure pins until you can remove the old headunit.
4. If you have already purchased the wiring kit, if necessary, then continue onto next step, otherwise purchase appropriate wiring kit for your headunit and car. Do not open wiring kit until you are ready to hook up your new headunit!!!!
5. Find new wiring kit, detach old wiring kit, and hook up new wiring kit according to included instructions. For best reliability, I recommend using wire nuts as electrical tape isn't as relaible and can come apart after a while. If you need to save space and can't use wire nuts, I recommend liquid electrical tape. Let this dry before you go any further.
6. Attach new headunit to adapter and then attach wiring kit to back of the headunit. Make sure to attach radio cord to back of headunit. Push adapter and headunit back into place, adjusting wires as necessary. Screw adapter back into place.
7. Re-attach dash panel back to car, reattaching screws where and if necessary and reattach battery. Power up car and test system.
8. Listen away.
If you cannot get this to work, most places like Best Buys and Circuit City have professionals that have the necessary parts and expertise to exchange headunits in cars and can do this for a small fee. Just replacing a headunit should be relatively cheep. Adding other components as well would be more expensive.
Posted on Mar 25, 2009
What procedure to put radio code into 1996 landrover discovery has a Cd stacker as well
Hold down the BND button for 4 seconds and then put in code. This is what I had to do to get my radio in my 1996 Range Rover working.
Jan 23, 2013 | 1996 Land Rover Range Rover
I have a Panasonic CQ-RX400U and I need to hook it up to a 1992 Ford Taurus and I need cables to hook it up and the thing that holds it in place in the dash.
I would get an stereo installation kit from Auto Zone or a local automotive audio store. It will come with the surround for the new stereo to fit where the old stereo went, and a wiring harness to hook the new stereo up to and plug into the existing car wiring.
May 20, 2010 | Panasonic CQ-RX400U Car CD/ MP3 Player
Need unlock id code for panasonic cq-vx100u
HELLO
PLEASE NEED CODES UNBLOCK MI STEREO PANASONIC CQ-VX100U
Mar 27, 2010 | Panasonic CQ-VX100U Car DVD Player
Pioneer CDX-P670 Wiring / Power
hi according to the manual the two pin connector is for the power and the pin nearest the square control plug is ground, the other pin is +12, have tried this with mine and it works
Nov 26, 2009 | Pioneer CDX-P670 6-Disc CD Changer
Eed master reset code for dvd stereo panasonic CQ-VD7005U. THIS dvd stereo was made in 2007. need a 4 digit master code
Hi
Unfortunately there is no original default code for this particular unit. At initial setup this unit gives an option of whether or not to set a security code and the first code that you input at that time is now retained by the unit.
It is electronically locked so that a thief cannot use the stolen unit unless that person knows the code you have set.
Therefore it is not a simple process of selecting the original factory default code. Neither can the unit be decoded or cracked as the initial code you entered is personalized and is not associated with the unit through any other database.
Therefore the only answer here to reactivate this unit is to return it to your nearest Panasonic service centre to be reset.
For further assistance you can contact Panasonic directly at
http://www.panasonic.com/support
or phone
1-800-211-PANA (7262),
Monday-Friday 9 am-9 pm; Saturday-Sunday 10 am-7 pm, EST.
Thanks for using FixYa.
Nov 18, 2009 | Car Audio & Video
1997 DEVILLE HAS A FACTORY AMPLIFIER HOW DO YOU BYPASS IT
Had the same probem with my Avalanche. Electroncis store wanted $180 for harness. I ended up running new wires to the speakers and bypassed the amp. Stereo sounds awesome. Make sure you remove the stereo amp fuse.
Sep 03, 2009 | Panasonic CQ-VD7003U Car DVD Player
Reset code security for car stereo panasonic cq-vx100u
My friend have in car panasonic Cq-vx 100u them forgot the code. now Ineed a defaul code please sir.
Aug 18, 2009 | Panasonic CQ-VD7001U Car DVD Player
Wiring a 2004 range rover
what is wrong with the car,, that you need to rewire. the wiring for suspention is independant.
Sep 08, 2008 | 2004 Land Rover Range Rover
Panasonic cq vd7001u
cost me $40 bucks for this problem, watched the authorized servie guy from panasonic fix it, all you do is turn the unit it so the code screen comes up and then press and hold the toggle button in the bottom right side of the unit for 10-15 seconds, it will reset the unit for you, just keep holding it down and it will work
Jun 07, 2008 | Panasonic CQ-Vd7001U
No sound from CQ-1305U car CD/stereo
You may have one of this two problems:
One of the speaker wires is grounded to the chassis.
Or your car may have a factory amplifier between the radio and the speakers.
My suggestion is to rewire the speakers lines
Dec 25, 2007 | Panasonic CQ-DP383U CD Player
Car Audio & Video Logo
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
