Question about Ricoh Aficio 1018D Copier
Hello, ricoh aficio 1018d error code display sc 925 what can i do for it.
  • Ricoh Master
  • 525 Answers
IMB non-connected error
Symptom:
IMB is not connected. This SC only
appears with B040 and B043 version
machines.
Possible Cause:
• IMB is not connected
• Poor connection between BiCU and
IMB
• IMB defective
• BiCU defective
Posted on Jan 22, 2011
Turn main power switch off then on.If error reoccurs.call service.Functional problems. What does mean.
It means that something with the functionality of your device is not working properly. Take it for service.
Mar 07, 2016 | Ricoh Aficio 1018D Copier
Sc 925
CHECK THE THE HARD DISK
Jan 27, 2014 | Ricoh Aficio 1018D Copier
Ricoh aficio 1018d sc 544
Hello!
This code is related to a Fusing low temperature error.
You probably need to change Hot roller (or fusing rooler) and thermistors.
You can reset this code but it will pop-up again sooner or later.
The best advise i can give you is to call a technician (if you do njot have technical knowledge)
If you still want to reset the code tey this:
Press yellow key
Press in the key pad 107
Press red key at least 5 sec.
Exit all the way out.
Turn the machine off and on.
Hope this helps you
Aug 03, 2011 | Ricoh Aficio 1018D Copier
Ricoh aficio 1018D all in one printer is showing problem. No. SC 194
sc194 is an error with the scanner. It could be a bad exposure lamp, but it could also be a circuit board that needs to be replaced (either the SBU board or BICU board).
Mar 05, 2011 | Ricoh Aficio 1018D All-In-One Laser...
Have an aficio 1018 copier with an error code SC544 any ideas ?
that's a fuser unit error do an Sc reset and restart the machine if not replace the fuser unit
May 19, 2010 | Ricoh Aficio 1018 Printer
Cant reset Z error at Printer Ricoh Aficio 1018D
Im assuming that you are referring to the Z as the jam light. In that case the operation panel will tell you what part of the machine is jammed by displaying a diagram and a letter that corresponds to a chart that you will see when you open the front door. make sure to open all the doors then close them to reset jam code (there is a hidden door on the right lower side called the A door) Good luck
Apr 05, 2009 | Ricoh Aficio 1018D All-In-One Laser...
Code error sc543 ricoh aficio 3260C
SC-543
Heating roller fusing lamp overheat
The detected fusing temperature stays at 200 °C or more for five seconds.
Replacetment the PSU. Got it here: http://www.websitetoolbox.com/mb/copierquestions
May 05, 2008 | Ricoh Aficio 1018D All-In-One Laser...
I Can not Reset error -codes
Its a fuser error code, the machine won't go back to working unless you go into svc mode and clear the error. I suggest calling a local tech.
Jan 08, 2008 | Ricoh Aficio 1018D Copier
1,382 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
