Question about Dell Dimension 8200 PC Desktop
Continuous crashes - I'm going crazy!!!
I have a Dell Dimension 8200 with a 300w power supply and a 2.53 GHz processor. This computer is one of the only computer problems that I have ever be totally stumped. It crashes frequently, crashes such as the blue screen of death, and also the "blahblahblah.exe has experienced a problem and needs to close. We are sorry for the inconvenience." Please note that blahblahblah.exe can be anything from Internet Explorer to Microsoft Word. I have absolutely NO idea what the heck the problem is. The problems all started when we got a digital video camera, and then found out that we needed to have a firewire port, and a DVD burner. We got and successfully installed a 200gb hard drive, a Maxtor CD/DVD burner, and a firewire card. Since then it started crashing a lot, and I am beginning to wonder if it is the PSU not being able to supply enough power, being only a 300w one. Also, I don't know if it's the motherboard dying, or a defective component shorting or something. Please don't tell me to reinstall my operating system or check for viruses, because I have already done that many times, and I have even tried installing Linux on it. Any help would be GREATLY appreciated.
  • 3 more comments
  • Matthew Haynie
    Matthew Haynie May 24, 2008
    Most of the time when I get a bluescreen, it will be a "PAGE_FAULT_IN_NONPAGED_AREA" I have looked on the web and I think it might be a HDD overheat. Also, note that ablsolutly NONE of the capacitors on the mobo have a peaked top. If its a heat issue, note that there's only 1 case fan that has a shroud on it to take heat away from the CPU heatsink. There is no actual fan on the heatsink itself. The system specs are a follows:
    Computer: Dell Dimension 8200 Desktop PC
    Mobo: Unknown
    Graphics card: nVidia GeForce Ti200 (no fan)
    CPU: 2.53 GHz Intel Pentium 4
    CD/DVD Drive: Maxtor CD/DVD Rewritable Drive
    Hard Drive(s): 40 Gb Western Digital Caviar (OS Installation)
    200 Gb Seagate Barracuda(Additional space, possibly problamatic HD)
    PSU: 300w Generic PSU
    That's all I can think of for now, so if you need any more information, I would be happy to provide it. If you want me to do anything complicated, don't hesitate to ask, 'cause I (probably) know what I'm doing.
  • Matthew Haynie
    I have removed the firewire card. No change. More suggestions please?
  • Matthew Haynie
    Its a little late to return the hard drive, but I have run diagnostics on it, and its supposedly all green. See how I got stumped???!!!
  • Matthew Haynie
    Matthew Haynie May 25, 2008
    4 sticks of memorey, 256 each, total of 1024 mb of ram, all identical samsungs.
  • Matthew Haynie
    Matthew Haynie May 30, 2008
    Thank you, now i know the problem is with the memory!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Problem Solver:
  • 14 Answers
Try uninstalling the firewire card. Of the three pieces of hardware you installed, that's the only one I could see the computer having a problem with, unless you picked up a defective hard drive. But sometimes your device drivers can conflict with other things and cause problems like that. I'm certain it's not the power supply, otherwise the computer would probably just decide not to boot. But try taking the firewire card out to see if it helps you.
Posted on May 23, 2008
  • Thomas LaMora
    Thomas LaMora May 24, 2008
    If you are getting a page fault in non-paged area, then the hard drive you picked up is probably defective. Try running some kind of diagnostic test on the hard drive. If it fails, I would return the drive and get a different one.
    Scholar:
  • 143 Answers
Try looking for a virus... LOL
Okay, all kidding aside. A 300w power supply is not totally bad power-wise, but it could be the problem. The first thing I would do is remove the firewire card and see if that clears up the problem. One of two things: faulty drivers OR bad firewire card. Or a combo of all three. Give that a try first and see if you get any relief.
  • 4,234 Answers
Look for a pattern to when this problem occurs. It may be heat related. Be sure that there is sufficient ventilation and air flow. Also, check the motherboard for capacitors that have the tops that are peaked. The tops should be flat. You may have taken a power hit that smoked a few filter caps. That could cause noise on the power lines which can cause noise on the data lines etc...
Keep us posted.
Dan
  • ABRsvcs May 25, 2008
    How much memory in this machine and on how many sticks?
    Dan
  • ABRsvcs May 27, 2008
    This may sound a bit odd, but Windows does not handle memory errors within the non-paged area very well. These errors I'm refering to are hardware errors not pagefaults. Try moving the memory sticks inward. In other words take the 2 memory sticks on the outside and put them into the inner 2 slots as follows:
    Start: memory sticks 1,2,3,4 and place as: 2,1 4,3. Try the machine again and see if the problem remains. Moving the sticks like this will force the virtual memory onto different physical memory sticks. Any hardware memory problems should now be in the "user" areas where memory issues are more easily handled.
    Keep us posted.
    Dan
Optiplex replace power supply
Hello Jacey,
Below are the system specs for the power supplies that are installed in each chassis of the GX280 system. You can call the Dell Spare Parts
Department at 1-877-717-3355 or click the link below.
Spare Parts Department
Wattage small form-factor computer: 160 W
small desktop computer: 210 W
small mini-tower computer with processor speeds of 3.2 GHz or lower: 250 W
small mini-tower computer with processor speeds of 3.4 GHz or higher: 305 W Heat dissipation small form-factor computer: 546 BTU/hr
small desktop computer: 717 BTU/hr
small mini-tower computer with processor speeds of 3.2 GHz or lower: 853 BTU/hr
small mini-tower computer with processor speeds of 3.4 GHz or higher: 1041 BTU/hr Voltage fixed-voltage power supply-110 V at 50/60 Hz manual selection and auto-sensing power supplies-90 to 135 V at 50/60 Hz; 180 to 265 V at 50/60 Hz; 100 V at 50/60 Hz for Japanese computers
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Mar 23, 2013 | Dell OptiPlex GX280 PC Desktop
When i start up my dimension 3100 dell desktop instead of a green light i get a flashing amber light. people say it is the power supply but the light wouldnt even come on if it was. can you please help me?
No, the light WOULD come on if it was a Power Supply problem.
1) If ALL of the LED lights on your computer were on at once, they would use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts.
3) A typical Processor uses from 51 to 125 Watts. Depends on what Processor it is.
Dell Dimension 3100 desktop computer?
An Intel Pentium 4.
Intel Pentium 4 model 640.
Can operate up to a frequency rate of 3.2GigaHertz. (3.2GHz)
Fits in a Socket 775 processor socket. (Also know as Socket T)
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Prescott_2M_.2890.C2.A0nm.29
Can use up to 84 Watts.
You have enough power to light that LED light, but not enough power to turn the Processor on.
Dell Support > Dell Dimension 3100 > Service Manual > Advanced Troubleshooting > System Lights,
http://support.dell.com/support/edocs/systems/dim3100/en/sm/adtshoot.htm#wp1124612
"Power Light - Blinking yellow - A power supply or system board {Motherboard} failure has occurred"
Dell Dimension 3100 desktop computer Service Manual, (Free from Dell Support),
http://support.dell.com/support/edocs/systems/dim3100/en/sm/index.htm
Click on Removing and Installing Parts > Power Supply
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 20, 2011 | Dell Dimension 3100 PC Desktop
I have a Dell Dimension 8400 Series desktop that is totally dead. Nothing happens when power button is pushed. Of course it is plugged into a live outlet.
Possibly a bad power supply. Could aslo be bad hardware.
Depeding on how save you are with computers, depends on how far you might want to go with this.
But remove everything one at a time and try to start the computer. Until all you have is a motherboard, processor, fan, and power supply hooked up. If you are still not getting any power, try to swap the power supply first. If that doesnt work then either Motherboard or Processor.
Lastly, swap the power cable out to see if its a bad cable.
May 03, 2011 | Dell Dimension 8400 PC Desktop
I bought a pentium 4 3.0 ghz 800 mhz & my
The motherboard chipset of the Dell Dimension 2300 Desktop PC, will not support a processor with an 800MHz Front Side Bus frequency rate.
Only Intel Pentium 4's that use a Socket 478, 1.75 Volts, and a maximum of a 400MHz FSB.
The Intel Pentium 4 HT 3.0GHz processor has an 800MHz FSB, (As you have already stated), and uses 1.475 to 1.55 Volts.
The motherboard chipset for that Dell Dimension 2300, is an Intel 845GL.
This list on Wikipedia, shows you parameters the Intel 845GL chipset supports,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Pentium_4_Chipsets
Not a good outcome, sorry. Just stating the facts.
Jan 08, 2010 | Dell Dimension 2300 PC Desktop
Hi I opened a work computer Dell GX260 to clean it out as a favour for my boss. I've removed the processor fan in the process. I then decided that I don't have the right equipment to properly clean it....
You confirm all the connectors are properly connected. Check the power supply connector and the power button connector. Remove the cpu fan connector and refix it properly. Ther is no other chance for failure.
May 05, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
My dell wouldnt post,
It sounds like the motherboard is damaged. Did you try to start with a boot cd? Or will it just not get to the bios setup screen?
Nov 28, 2008 | Dell Dimension 3000® Pentium® 4...
Dell Dimension E510 Powers Up, Then Crashes
It's the processor or power supply. I cant be sure of which without checking it.
Check the fan over the processor heat sink to make sure its working cause it could mean that the processor is overheating If the fan turns and then it cuts off this could meant that the processor is dead. or the bios is corrupted. Try flashing the bios, there is a battery on the main boad, remove it. unplug the system first... when the battery is out press and hold the power button for 10 seconds then release. put the battery back in and try to turn it on..
If that fails then try a new power supply or one from another system to to check if the power supply is fine. YOu can aslo bridge the green and any black wire from the power supply's mainboard connector to see if the power supply runs. If all this fails then you may need to replace your processor,, I';d also recommend changing the power supply as well.
Nov 14, 2008 | Dell Computers & Internet
Remove the camera from the computer & turn off the system
just start your system in safe mode by tapping the F8 key when you push the power button to turn on the system
U will get Advanced options
Use the up and down arrow keys on the keyboard and select the option Safe Mode
Press Enter
Press Enter again
Now u will get messages like multidisk all over the screen
Do not worry
After this u will get usernames to click on
Login as an administrator
Click start>>All programes>>Accessories>>System tools>>System restore
Click next
Select the date on which you had not plugged in or installed your camera(date should be in bold only then it would be selected) .
Keep clicking next till the wizard finishes
The computer will automatically restart and now it would work
May 25, 2008 | Dell Dimension 8200 PC Desktop
Cpu upgrade dell dimension 5100
Hi, according to the Dell website you have a LGA775 socket on your motherboard. Therefore, you can only buy processors that fit into this socket. Here is a list of some offered by Intel that will work: Celeron D 325 2.53 GHz Celeron D 330 2.66 GHz Celeron D 335 2.8 GHz Celeron D 340 2.93 GHz Pentium4 520 2.8 GHz Pentium4 530 3.0 GHz Pentium4 540 3.2GHz Pentium4 550 3.4 GHz Pentium4 560 3.6 GHz Pentium4 570 3.8 GHz The processors that won't work are the ones that are not compatible with this socket. Everytime you look up a cpu it will tell you which socket it is designed for. To buy a cpu you will need to decide: The brand you want. The speed of the cpu that you want. Extras i.e. Hyperthreading, etc. How much you are willing to pay for it. Then you can narrow your search as you stick within your limits. Let me know if you have more questions. Good Luck
Sep 30, 2007 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 8200 PC Desktop Logo
99 people viewed this question
Alun Cox
