Question about Ingersoll Rand SS3J5.5GH Wb Ir Portable Air Compressor 5.5HP Honda Gasoline Engine Single Stage 8 Gal Twin k Wheelbarrow
Compressor is slow to build up pressure and will not rise above 33 ppsi, about a quarter of its head room
  • 10,865 Answers
Hello. Here is a great link to a website that will help. http://www.about-air-compressors.com/troubleshooting-your-compressor.html
J.
Posted on Sep 27, 2010
Craftsman air compressor wont build presure
Broken reed valves- assuming the regulator is adjusted to maximum air pressure.
These are located on the face of the pistons and require partial disassembly of the compressor head to serivce.
When installing the new ones, add a drop of light duty thread locking compound to the threads to insure the screws do not fall out in use.
Oct 27, 2012 | Craftsman 33 gal Air Compressor 6 hp...
DeVilbiss air compressor will not build pressure
Does it have an intake air filter? Has the compressor been properly maintained? Oil less? It may have worn out rings and or valves
Aug 24, 2017 | Air Tools & Compressors
I have a Craftsman compressor Model # 919-15292 2. The compressor stopped building pressure because air was continually being released through the unloader valve. I have replaced the unloader valve,...
you must have wired the new pressure switch incorrectly .when the pressure switch opens it will release the head pressure so your compressor must be running with the pressure switch contacts open should be 4 connections 2 marked motor which is from your compressor and 2 marked line which is your power coming in
Jun 15, 2011 | Craftsman 33 gal Air Compressor 6 hp...
I have a model# 919166442 air compressor that all at once quit building air pressure. when it gets to 40psi the engine keeps running but air pressure wont rise
There is a check valve that has gone bad,this allows air into the tank,and does not allow the air to go back toward the compressors head.This can also cause the compressor to lock up.
May 17, 2011 | Craftsman 15 gal Air Compressor 3 hp UMC...
My 1 hp. 12 gal. air compressor is not building air pressure the motor runs the pressure won't go above 20 lb.
It could be that the input air filter is badly clogged. I might more likely be that the Non-return valve on the air tank input is not sealing properly and not allowing the tank to build up pressure. This valve is at the end of the main pipe runs between the compressor and tank. It could also mean (less likely) that the poppet valves inside the compressor cylinder head are not sealing properly. Other faults could be worn rings on the compressor pistons or a bad seal between the compressor cylinder head and block.
To check the Non return valve allow compressor to build up some pressure and then loosen union nut on Non return valve. There should be some air released at first but should stop if valve is ok. If leaking remove valve and check for dirt and clean. If valve still leaks replacement is the only fix.
Sep 14, 2010 | Craftsman Air Tools & Compressors
I have a husky compressor, model number y6010-wk. it builds pressure slow, and shuts down right away.
Problem: My compressor is not producing the air that it once did. It takes twice as long to pump up.
Solution:
1)Turn off your compressor or disconnect the power.
2)Remove the connector tube that sends air to the tank.
3)Remove the head bolts on top of the pump.
4)Remove the head off of your pump.
5)Remove the valve plate off of your pump. It may be a one piece or a 2 piece design.
6)Inspect the valve plate for broken reed valves or broken gaskets above or below the valve plate.
Feb 27, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Ingersoll Rand  SS3J5.5GH Wb Ir Portable Air Compressor 5.5HP Honda Gasoline Engine Single Stage 8 Gal Twin k Wheelbarrow  Logo
144 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
