Manual for Karda DAC1200-1RH AIRCONDITINER AND HEATING.
My 1998 Gmc suburban doesnt blow in the front but blows in the back what should i check
i had a chevy truck and there was a filter under the dash board and i took it out and it was super dirty worked great after that
Jul 23, 2012 | Cars & Trucks
What does E1 error code on a Karda heat pump, model KSAC-18HRDCI mean as there is nothing in the manual about error codes. How do you clear it?
I have worked this out. There is a 20A fuse inside the compressor(outside) unit, it is a glass fuse that has a sleeve over it and is soldered to the PCB. They appear to have a manufacturing fault and 'blow' at a lower current than the 20A, Just the edge of the fuse link is not properly bonded to the end cap. On inspection they don't look blown, but test open circuit. Was a relatively easy fix with a soldering iron and a new 20A fuse. You can find this fuse on the gas piping end of the compressor.
Sep 12, 2011 | Heating & Cooling
How can i remove the outside cover on a 71055 window airconditiner
there should be a cuopule of screws on each side and on the top and first unscrew the front cover and it may slip in on the top part but remove the side screws first and one in the filter compment
May 09, 2011 | Kenmore 71055 Air Conditioner
2001 Toyota sienna
hi..my van is toyota sienna 2001,now the airconditiner is leak and i want to made to new hose or do it somthing.can you help and show me how to do it,please. thanks so much.
May 05, 2011 | 2001 Toyota Sienna
Karda heat pump not working and displaying E1 on the screen
Did you ever get a solution to this? Mine's doing this today!!! I can't find anything in the user manual to help, either.
Oct 29, 2009 | Heating & Cooling
Heating & Cooling Logo
220 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
