Question about Sony PCG-TR3A Notebook
Msconfig i only see: general, system.ini, win.ini,boot.ini, services and startup. I am using XP. There is nbot even a "modem" header shown in device manager/hardware....???? Thanks for your help
  • Kato4 May 24, 2008
    Windows XP
  • Kato4 May 31, 2008
    it's Windows XP Professional....
    Champion:
  • 207 Answers
Hmmm
wt type of windows do u have??
pls let me know
Posted on May 23, 2008
I have an HP 3210 printer and Windows XP. Whenever I start my PC I get a message from Document Viewer asking me to install it from a removable disk. I can't find the disk.
Diagnostic startupDiagnostic startup enables Windows to determine the basic device drivers and software to load when you start Windows. When you use this method, the system temporarily disables Microsoft services such as Networking, Plug and Play, Event Logging, and Error Reporting. Also, you permanently delete all restore points for the System Restore utility.
Note Do not use this method if you want to save your restore points for System Restore or if you must use a Microsoft service to test a problem.
To perform a diagnostic startup, follow these steps:
  1. Click Start, click Run, type msconfig, and then click OK.
  2. On the General tab, click Diagnostic Startup, and then click OK.
  3. Restart your computer.
If the problem does not occur, use Selective startup mode to try to find the problem by turning individual services and startup programs on or off. Selective startupSelective startup enables you to select the files and the settings that you want the computer to load when you restart the computer. Select from the following options:
  • Process System.ini File
  • Process Win.ini file
  • Load System Services
  • Load Startup Items
By default, no options are selected. The following actions apply to these options:
  • When you select the check box, the configuration file is processed when you restart the computer.
  • When you clear the check box, the configuration file is not processed when you restart the computer.
  • When the check box is selected, and you cannot select the check box because it appears dimmed, some items are still loading from that configuration file when you restart the computer.
  • When the check box is not selected, and you cannot select the check box because it appears dimmed, the configuration file is not present on the computer.
  • You cannot change the Use Original BOOT.INI option button.
Note When you clear the Load System Services check box, you disable Microsoft services such as Networking, Plug and Play, Event Logging, and Error Reporting. You also permanently delete all restore points for the System Restore utility. Do not clear this check box if you want to keep your restore points for System Restore, or if you have to use a Microsoft service to test a problem.
To perform a selective startup, follow these steps:
  2. On the General tab, click Selective Startup.
  3. Select or clear the available settings.
  4. Click OK.
  5. Restart your computer.
  6. Repeat steps 1 through 5 until you find the problem.
Nov 04, 2010 | HP Photosmart 3210 All-In-One InkJet...
Tip
Installation problems for keyboards/mice in XP
Removing the software and reinstalling it using a "clean boot" may resolve the symptoms you are experiencing. Booting clean is a way to eliminate programs from conflicting with installation of software.
1. Download the latest version of the software for your OS from the manufacturer's website.
2. Open the Windows Control Panel.
3. Open the Add / Remove Programs window.
4. Locate the listing for the keyboard/mouse software and remove it. When prompted to remove the keyboard/mouse drivers files, click Yes.
The following is the procedure for a 'clean boot' in Windows XP:
1. Click Start --> Run --> Type MSCONFIG --> Click OK
2. On the General tab, choose Selective Startup
3. Uncheck Process SYSTEM.INI file
4. Uncheck Process WIN.INI file
5. Uncheck Load Startup Items
6. Click on the Services tab
7. At the bottom, check Hide All Microsoft Services
8. Uncheck all boxes in the window or click the button labeled Disable All
6. Click OK
7. Click Restart
After restarting, reinstall the downloaded software. Next, do the following:
1. Click Start --> Run --> Type MSCONFIG--> Click OK
2. Replace checkmarks in the items that you previously removed them from.
3. On the General tab, choose Normal Startup
4. Click OK
5. Click YES, when asked to restart your computer
Hopefully, you should not have any problem now.
on Apr 25, 2008 | Logitech LX7 Cordless Optical Mouse
Tip
Installation problems -Clean Boot/Install
Removing the software and reinstalling it using a "clean boot" may resolve the installation problems you are experiencing. Booting clean is a way to eliminate programs from conflicting with installation of software.
1. Unplug the camera from the computer. Later you will be prompted by the software to plug in the camera; do so at that time only.
4. Locate the listing for the software and remove it. When prompted to remove the camera drivers files, click Yes.
Now download the latest version of the software for your OS from the manufacturer's website.
The following is the procedure for a 'clean boot'. I am assuming that you have XP. If you have a different OS, just let me know and I will send you the appropriate procedure to boot clean in that OS.
6. Click OK
7. Click Restart
After restarting, reinstall the downloaded software. Next , do the following:
4. Click OK
on Apr 25, 2008 | Logitech QuickCam Communicate STX Personal...
PoweReadACValue error
Probably it is cause due to power management system corruption
Try following steps
Perform a Clean Boot
If your computer is not starting normally, or if you receive errors when you start your computer that you cannot identify, you could consider performing a "clean boot." This operation starts the computer by using a minimal set of drivers and startup programs. This can help you troubleshoot the problem.
Method :Perform a Clean Boot
Step 1: Start the System Configuration Utility
2. The System Configuration Utility dialog box is displayed.
Step 2: Configure selective startup options
1. In the System Configuration Utility dialog box, click the General tab, and then click Selective Startup.
2. Click to clear the Process SYSTEM.INI File check box.
3. Click to clear the Process WIN.INI File check box.
4. Click to clear the Load Startup Items check box. Verify that Load System Services and Use Original BOOT.INI are checked. 5. Click the Services tab.
6. Click to select the Hide All Microsoft Services check box.
7. Click Disable All, and then click OK.
8. When you are prompted, click Restart to restart the computer.
Step 3: Log on to Windows
1. If you are prompted, log on to Windows.
2. When you receive the following message, click to select the Don't show this message or launch the System Configuration Utility when Windows start check box, and then click OK.
Note: Start Windows in Normal State
Steps to configure Windows to use a Normal startup state
After you used the clean boot to resolve your problem, you can follow these steps to configure Windows to start normally.
1. Click Start, and then click Run.
2. Type msconfig, and then click OK.
3. Click the General tab, click Normal Startup - load all device drivers and services, and then click OK.
4. When you are prompted, click Restart to restart the computer.
Sep 04, 2010 | HP Pavilion dv7-1130us laptop
"Webcam is in use by another application."
in ue by another app is usually a driver conflict or a virus. if you have a 3n1 printer or a scanner unplug it and reboot the pc see if you get the same message. if not update the scanner or printer drivers. if the messgae return even after the reboot try a clean boot next.
To Boot Clean in Windows Vista Accessing the System Configuration Utility
1. Click Start and select Control Panel
2. Click System and Mantience
3. Click Administrative Tools
4. Double Click System Configuration
Configure Selective Startup options
1. On the General tab, choose Selective Startup
2. Uncheck Load Startup Items
3. Select the Services tab
4. Check Hide all Microsoft services
5. Click Disable all
6. Click on OK
7. Click Restart.
After performing the necessary steps, restore your system by doing the following:
4. Double click System Configuration
5. On the General tab, choose Normal Startup
6. Click Ok
7. Click Yes, when asked to restart your computer
To Boot Clean in Windows XP
6. Click OK
7. Click Restart
2. On the General tab, choose Normal Startup
3. Click OK
4. Click YES, when asked to restart your computer
if the camera starts to work after doing this your looking at a virus have your pc cleaned by a pro.
Jul 20, 2009 | Logitech QuickCam Pro 9000 Web Cam
When I click Microsoft LifeCam VX-1000 to run but window message error appear said "LIFEcAM.EXE HAS STOPPED WORKING" and the program will close. Thanks for your help.
hi,
if your running windows xp on your pc please try this
Clean boot procedure on Windows XP loadTOCNode(3, 'resolution'); To perform a clean boot procedure on Windows XP, follow these steps:
Warning You may temporarily lose functionality of some services when you follow these steps. When you restore the settings, the services are restored. However, when you restore the functionality, the original error message or behavior may return. Step 1: Start the System Configuration Utility loadTOCNode(4, 'resolution'); To start the System Configuration Utility in Windows XP, click Start, type msconfig in the Start box, and then press ENTER. Step 2: Turn off programs and services loadTOCNode(4, 'resolution'); To do this, follow these steps:
  1. On the General tab, click Selective Startup, and then click OK.
  2. Under Selective Startup, click to clear the following check boxes:
    • Process SYSTEM.INI File
    • Process WIN.INI File
  3. Click the Services tab, click to select the Hide All Microsoft Services check box, and then click Disable All.
  4. Click OK, and then click Restart.
Dec 16, 2008 | Microsoft LifeCam VX-1000 WIN-Blk Webcam
My acer aspire m1640 is booting up then just freezing or it says windows failed to start then scans for a problem finds one and says it can't do it automatic help
Tapping F8 key during bootup and get the window to run in Safe mode with networking.
When you login to administartor to window destkop.
1. Click Start --> Run --> Type MSCONFIG --> Click OK 2. On the General tab, choose Selective Startup 3. Uncheck Process SYSTEM.INI file 4. Uncheck Process WIN.INI file 5. Uncheck Load Startup Items 6. Click on the Services tab 7. At the bottom, check Hide All Microsoft Services 8. Uncheck all boxes in the window or click the button labeled Disable All 6. Click OK 7. Click Restart
1. Click Start --> Run --> Type MSCONFIG--> Click OK 2. Replace checkmarks in the items that you previously removed them from. 3. On the General tab, choose Normal Startup 4. Click OK 5. Click YES, when asked to restart your computer
Hope that helps...Should you have any further questions, please feel free to post them here.
Regards,
Ellin
Oct 18, 2008 | Acer Computers & Internet
Cursor lockup
This just because that there are too many services running in the background of the Operating system
All you need to do is to manually disable maximum of them and disable all the startup Items
Here is how you can do that the easy way
Manual steps to perform a clean boot in Windows XP
The System Configuration Utility dialog box appears.
6. (VERY IMPORTANT DON'T MISS THIS) Click to select the Hide All Microsoft Services check box.
7. Click Disable All, then Click on the startup tab and click on Disable All Button and then click OK..
1. Log on to Windows.
2. When you receive the following message, click to select the Don't show this message or launch the System Configuration Utility when Windows start check box, and then click OK:
You have used the System Configuration Utility to make changes to the way Windows starts.
The System Configuration Utility is currently in Diagnostic or Selective Startup mode, causing this message to be displayed and the utility to run every time Windows starts.
Choose the Normal Startup mode on the General tab to start Windows normally and undo the changes you made using the System Configuration Utility.
Step 4: Optional step to disable features
This step temporarily disables Microsoft features such as Plug and Play, networking, event logging, and error reporting. Also, this step permanently removes the restore points from the computer. The System Restore feature uses restore points to restore your computer to an earlier state. If you remove the restore points, you can no longer restore Windows to an earlier state.
2. Click the General tab, click to clear the Load System Services check box, and then click OK.
3. When you are prompted, click Restart to restart the computer.
2. Click the General tab, click Normal Startup - load all device drivers and services, and then click OK.
Aug 14, 2008 | Microsoft Windows XP Home Edition
Shutdown
Aug 14, 2008 | Dell Dimension 8200 PC Desktop
Invalid boot.ini
One of these two methods should fix your problem......... -------------------------- go to run and type in MSCONFIG. Then click on the "Boot.ini" tab. First, make sure if using XP Pro that the following is listed: [boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS [operating systems] multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect - this is the boot.ini information from XP, straight from the Microsoft Web Site. All the information below [operating systems] should be on one line! If you have a blank boot.ini file, copy and paste this information - if all information is already there, then don't change anything. Next, click the button that says "check all boot paths". You should get back a message stating that everything is good (the computer checks to make sure the boot.ini file is compatible with Microsoft Operating Systems). Next, assuming your computer likes the boot.ini file that is in there (and it should), then click the button that says "set as default". By doing this, you have now created a new (modified) boot.ini file that is a carbon copy of the original. Click apply. You will be prompted to restart. Before doing so, go back to MSCONFIG and in the general tab you will see that "use modified boot.ini" should now be checked. During reboot, you should not get the invalid boot.ini message (at least I didn't). What you will get is a message (after reachign the desktop) stating that you are not using the defaults or something like that and do you wish to go back into MSCONFIG to restore the default settings. Since your new boot.ini file is exactly the same as your original, click no and check the box to hide that irritating message. ------------------------ Or you can try this method.... right click on my computer go to properties then click the advanced tab then cilck settings under start up and recovery under system startup then click edit and paste [boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS [operating systems] multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect --------------------------------- Peter
Oct 04, 2007 | Intel Motherboard
Sony PCG-TR3A Notebook Logo
75 people viewed this question
Top Sony Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Computer Links
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
