Question about LG Washing Machines
MumbaiUSER MANUAL OF Lg Tromm 5.5 Kg Wd 85260Np
  • 334 Answers
SOURCE: LG Tromm WD R8012 Owners manual
GO TO THIS SITE AND LOOK FOR YOUR MODEL NUMBER UNDER WASHERS. http://www.lge.com/us/support/product/support-product.jsp GOOD LUCK.
Posted on Jun 11, 2009
SOURCE: LG WD-12331. Front load washer and dryer machine
since it is a washer-dryer, the lint trap is in line with the drain. you have to empty the drain basket. there's an access door on the bottom left, first take the little tube out and drain the remaining water, then open the large drain cap to the right and clean out the trap. once you're done put it all back together and it should work. you're supposed to do this every few months. It was too much for me to deal with so i ended up buying a separate dryer and just use the washer .
Posted on Aug 02, 2008
SOURCE: machine not accepting detergent powder
You are putting the detergent at a wrong place. i.e. in the place of cloth softener. Reas the manual and fill it at the proper place.
Posted on Aug 14, 2009
SOURCE: 1E displayed in the Display panel of the LG front
IE...Is a water inlet problem... clean the screens at the inlet hoses...
your fill vlave is not working,,, turn off the water supply and remove the clamps and undo the wires, could be just a plug in, may have to cut the wires get you a new one reinstall it with the flow going in the right direction and you will have water!!!!
Posted on Aug 30, 2009
  • 67 Answers
SOURCE: I have LG washer & dryer 8 / 5 kg WD-14440RDS
Does it turn on? if so either the start button is faulty(LG will want to sell the whole board but the switch is fairly easy to replace) or the door lock.
Posted on Apr 17, 2010
Wiring diagram for kg80490np washing machine front loader
More details required. i.e kg? np? Brand name enter minimum details in Search box should show up and suggest.
Good Luck
Feb 03, 2015 | LG Washing Machines
Looking for lg tromm wd-r801b manual.
The best way of getting an owner's manual is through LG directly.
Apr 28, 2012 | LG Washing Machines
Lg tromm wd 85485 error code cl mean ?
Possible that the drain valve is clogged if the inlet line is working and so you need to remove the drain and back flush.Also check after the power plug is removed for few hours and see if the fault resets to start the machine only to show the error a few minutes later. if so clean the drain lines, check the inlet flow and the door switch.
Dec 15, 2011 | LG Washing Machines
My LG WD-85260NP model Front load washing machine is showing the error as 'FE', what does it mean and how to rectify it? I have lost the manual in our transportation and I have downloaded the...
LG's 'FE' stands for 'overFlow Error' which I strongly suspect means a service engineer's attention. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Aug 15, 2011 | Washing Machines
Machine not accepting detergent powder
Aug 14, 2009 | LG Washing Machines
Jun 11, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Tromm 8/4 WD R8012
The manual suggests to shut the water off ,
remove the inlet hose and check the screen for blockage.
The ie message is the inlet water is insufficient.
May 22, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
845 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
