If I leave my computer unattended for maybe 15 min. this monitor turns itself off. Is there a way to fix that? Thanks, brumeister
Screen savers can help protect your monitor from wear by showing a constantly changing display when your computer is not being used. Screen savers can be simple, like the Blank screen saver that turns off your monitor to save energy.
To change your screen saver
1.
Right-click your desktop, and then click Properties.
2.
In the Display Properties dialog box, click the Screen Saver tab.
3.
Click the Screen saver drop-down box, and then click a screen saver.
4.
Click the Preview button to see how the screen saver will appear on your monitor.
5.
Move your mouse or press a key to return to the Display Properties dialog box. To try a different screen saver, return to step 3.
6.
Click the Settings button to change the standard behavior of the screen saver you selected. (Each screen saver has its own settings dialog box.) Then, click OK.
7.
In the Wait box, type the number of minutes the computer should wait to start the screen saver after you last touched the keyboard or mouse.
8.
If you are the only person who uses your computer and you are not concerned about security, clear the On resume, display Welcome screen check box. Otherwise, leave this check box selected.
Note: If your computer is joined to an Active Directory, the Fast Users Switching feature will be disabled. This is a common change made to computers used for business, and it happens automatically when a computer joins an Active Directory domain. However, disabling the Fast User Switching feature is not the default setting. Almost all computers in home environments will have Fast User Switching enabled. When Fast User Switching is enabled, you'll see the On resume, display Welcome screen check box. If you're part of a domain, you'll see the On resume, password protect check box.
9.
Click OK.
