Hi, I start up the printer, It's starts ok for about 10 sec, then when it's starts to check the 4 motor that drives the drums, it dies, no power. Could it be the power supply or the others boards? Gab.
    Genius:
  • 1,478 Answers
Try plug the printer on a different AC out let and see if it repeats same thing, if it does, replace the power cable on your printer, if the problem still persist after replacing the power the power cable, then, it means the problem is from the power board circuit. The power board circuit on your printer will need to be work on or replace.
Take care.
Posted on Sep 27, 2010
Remove c-24 errorminolta di450/500
Sir/Mam,
C0F24 Code is the code for the sensor that monitors the drum. I would remove the drum cartridge two black screws pull out the drum assy. Remove the drum be careful do not nick or harm the drum the sensor is located on the left side of the to the rear of the of the drum looks like to little eye of a bug. Dust with a brush NO VACUUM static could destroy it. Re-install drum and re-install cartridge. When the last time a PM was done Developer replaced and Drum replaced?
Dec 14, 2014 | Minolta Office Equipment & Supplies
Tip
Whirlpool Dryer Various Test Procedures - Part 1
TEST #1 Supply Connections
This test should only be done after confirming proper voltage at the outlet.
1. Unplug dryer or disconnect power.
2. Remove the cover plate from the back of the dryer.
3. Check that the power cord is firmly connected to the dryer’s wire harness.
4. Access the machine control electronics without disconnecting any wiring to the control board.
5. With an ohmmeter, check for continuity between the neutral (N) terminal of the plug and P8-3 (white wire) on the machine control board. If there is continuity, go to step 6. If there is no continuity, disconnect the white wire of the harness from the power cord. Test the continuity of the power cord neutral wire . If an open circuit is found,
replace the power cord. Otherwise, go to step 6.
6. In a similar way, check the continuity between the L1 terminal of the plug and P9- 2 (black wire) on the control board. If there is continuity, go to step 8. If there is no continuity, check the continuity of the power cord for power cord’s L1 wire. If an open circuit is found, replace the power cord. Otherwise, go to step 7.
7. Replace the main harness.
8. Visually check that the P5 connector is inserted all the way into the machine control electronics.
9. Visually check that the user interface assembly is properly inserted into the front console.
10. If both visual checks pass, replace the user interface assembly.
11. Plug in dryer or reconnect power.
12. Perform the Console Buttons and Indicators Diagnostic test to verify repair.
13. If indicators still do not light, the machine control electronics has failed: Unplug dryer or disconnect power.
Replace the machine control electronics. Plug in dryer or reconnect power. Perform the Console Buttons and Indicators Diagnostic test to verify repair.
TEST #2 Machine Control Power Check
This test is used to determine if power is present at the machine control electronics.
NOTE: The drum light is controlled by the machine control on all models.
2. Open the door.If the drum light illuminates, then power is present at the machine control, and it is functional. Go to TEST #6. If the drum light fails to illuminate, do not assume the machine control electronics needs replacement. Several conditions may cause the drum light not to illuminate, including a bad bulb. If the drum light does not illuminate, go to TEST #1.
TEST #3 Drive Motor Circuit
This test will check the wiring to the motor and the motor itself. The following items are part of this motor system:
Harness/connection Belt/belt switch Drive motor Centrifugal switch Door switch Machine control electronics
2. Access the machine control electronics and measure the resistance across P8-4 and P9-1.
If resistance across P8-4 and P9-1 is in the range of 1 to 6 ohms, replace the machine control electronics.
Otherwise, go to step 3.
3. Check the wiring and components in the path between these measurement points by referring to the appropriate wiring diagram and strip circuit in Section 7.
4. Check the belt switch and drive motor. Access the belt switch and drive motor by removing the front panel/drum assembly. Slowly remove the drum belt from the spring-loaded belt switch tension pulley, gently letting the belt pulley down.
5. Remove the white connector from the drive motor switch.
6. Check for the resistance values of the motor’s Main and Start winding coils. NOTE: Main and Start winding coils must be checked at the motor.WINDING RESISTANCE ω CONTACT POINTS OF MEASUREMENT
MAIN 1.4–2.6 Blue wire in back at pin 4 and bare copper wire on pin 5 of black drive motor switch
START 1.4–2.8 Blue wire in back at pin 4 and bare copper wire on pin 3 of black drive motor switch. If the resistance at the motor is correct, there is an open circuit between the motor and machine control electronics.
Check for failed belt switch. If the Start winding resistance is much greater than 4 ohms, replace the motor.
7. Check the belt switch by measuring resistance between the two blue wires while pushing up the belt switch tension pulley.If the resistance reading goes from infinity to a few ohms as pulley arm closes the switch, belt switch is OK. If not, replace the belt switch. If belt switch is OK and there is still an open circuit, check and repair the wiring harness.
8. Door switch problems can be uncovered in the Door Switch Diagnostic Test; however, if this was not done, the following can be done without applying power to the dryer. Connect an ohmmeter across P8-3 (neutral, white wire) and P8-4 (door, tan wire).With the door properly closed, the ohmmeter should indicate a closed circuit
(0–2 ohms). If not, replace the door switch assembly.
on Apr 11, 2009 | Whirlpool LER4634J Electric Dryer
Husqvarna 125l carb problems
Check the fuel lines. Ethanol in the gas swells the old type fuel lines.
Jul 17, 2014 | Garden
"Stability Control Fail" light on.
first job is to check the part load and main beather hoses are ok the stability system light may be a false indicator if the engine has stalled best is to get fault codes out of the ecm with a code reader to help but air leaks on the engine inlet side can cause strange/seeming unrelated symptoms
Aug 22, 2017 | 1997 Jaguar XK8
Xerox 3535 ero 004-361
Hi
Error code 004-361 means Drum error or Drum motor failure. You'll need to check the drum cartridges, remove the cartridges to check. Now enter DC330 [004-003] and press Start. The Drum Motor will now energize and the drive rotates. If it doesn't then measure voltage between the Drum Motor P/J210-4 (+) and GND (-), it should be +5 VDC is measured. Try measuring the voltage between the Drum Motor. If there is no voltage detected then you'll need to replace Drum Motor (PL 1.1). Hope this helps...
Daniel
Oct 11, 2010 | Xerox DocuColor 3535 Copier
Error 012 in canon 6085
hi dear uyou have problem in the drum drive motor not in the feeder motor, coz E012 After the drum motor drive signal has been generated, clock pulses are not generated within 2 sec thays mean yours drum motor is not moving may be the faulty motor or may be the power supply for the motor.
thanks
May 16, 2010 | Canon imageRUNNER C3220 Color Copier
Hp 4600 noise problem
when power on the main board do initial devices:
1) the cartridge include toner unit and photo drum unit
2) fuser unit and all paper road include motors and sensors through the paper road.
the noise at power on you may check:
1) the toner unit that maybe over life cycle to mak much more obstruction, you may take out the cartridge and turn the gears if felling very hard so need to change the cartridge.
2) the toner unit gears damage a little that could make noise, you may check all gears on the cartridge. attention other side drive gears.
3) check the fuser unit gears do same thing above.
hope you fix it and feedback the result thanks
May 06, 2009 | HP LaserJet 4600dn Color Printer
E100
Salut.
E100 means :
When the scanner motor is started up, the BD input signal does not arrive within a specific period of time.
When the scanner motor is started up, the motor rotation is too fast, and fails to reach a specific revolution within 20 sec at time of deceleration.
While the scanner motor is rotating at a specific speed, the BD input signal cycle is not within a specific range (±2%) for an equivalent of 10 mm (print distance).
While the scanner motor is rotating at a specific speed, the BD input signal cycle is not as indicated (±2%).
During the WMUPR period after the power switch has been turned on or the front cover/left cover has been opened/closed, the drum unit is absent.
Possible cause: The wiring is faulty (short circuit, open circuit). The laser scanner unit is faulty. The DC controller PCB is faulty. The drum unit is not installed.
Jan 14, 2009 | Canon ImageRunner 1600 Copier
12 people viewed this question
jasbo
jasbo
