Question about Dell 1600n All-In-One Laser Printer
Scanner Sheet Feeder Malfunction
Whenever I scan something, the sheet feeder pulls the last two pages through together. Any suggestions on how to fix this?
    Genius:
  • Dell Master
  • 1,056 Answers
Change the top pick up roller. Can be ordered through the Dell parts dept. takes about 30 seconds to change.
Posted on Jul 22, 2008
How i can scan multiple pages in one file ??
You need a document feeder. The printer has on or it doesn't. If it does you usually place the documents face up in the overhead feeder and the scan sensor in the printer will detect a load of paper in the feeder and choose to there instead of a single sheet under the glass.
Apr 17, 2016 | Artronix Technology Artec ViewStation AS6E...
My scanner just started smearing the first page of a duplex to pdf but when I scan just front of document it doesn't smear it
Hi
Your question is not clear.
Sometimes using technical jargon makes it harder for people to understand each other (this applies to both askers and answerers).
I always advise askers to use normal language as much as possible and answerers to do the same and where jargon is unavoidable, to explain as they go along.
Please post again to clarify what you mean by "..a duplex to pdf..", in normal language not in technical jargon.
A PDF is not a real, physical document. It is a digital document on a computer or a webpage created in PDF format.
A Duplex document is a real document, printed on both sides of each sheet of paper.
If you are trying to scan a multiple page Duplex Document using the Sheet Feeder of your scanner, the ink on the reverse side may be getting caught up in, affecting and/or staining one of the rollers in the Sheet Feeder.
The bottom roller in most non-industrial Scanner Sheet Feeders expects to touch only the plain reverse side of a sheet of paper as it is passed through and turned over to rest on the Platten (scanning surface) of the scanner ready to be scanned.
Multifunction printers with built in scanners and sheet feeders and duplex printing capability are designed in a way that makes them more forgiving of dealing with duplex printed paper.
Duplex printing printed in a laser printer is less likely to cause a problem as long as it is allowed to dry thoroughly. Inkjet printing that is allowed to drry thoroughly should also be okay.
If the scanning is being attempted very soon after printing, then the wetness of the printing may be the problem.
Sheet Feeders that handle duplex printed sheets invariably become stained and need periodic cleaning.
If the document is not too long, you may have to scan it manually, page-by-page.
If the document exists as a PDF somewhere on your computer or on the internet, then it is unclear why you would need to scan it. This is why your question is puzzling.
Post a further comment, if this answer does not help you solve the problem.
I hope this helps.
Aug 25, 2011 | Fujitsu fi-5750C Flatbed Scanner
E 5 keeps flashing. I know the ink cartridges are empty but I only want to use the scanner not do any printing. I have tried power off and reset and the suggested fix of holding both buttons together. Nil...
Error E2.5 refers to the asf (assemply sheet feeder) in otherwords its the feeder that pulls in the paper that is malfunctioning. The whole machine needs to be stripped before you can even think about the problem. For a trained canon engineer (Me) it takes 1 to 2 hours to strip and usually the sheet feeder needs to be replaced. Probably with the costs involved it just is not worth it. Take a tip from me, Buy a new machine!! but before you do just make sure nothing has fallen into the machine and caused it to jam..
May 18, 2011 | Canon PIXMA MP160 All-In-One InkJet...
No matter what i do the paper keeps getting jammed before it comes out... It looks like it's getting hang up on something by the front rollers... This is really making me very mad this morning....
I understand your frustration. Try this solution.
* Push down the purple paper lever located on the right side of the multi-purpose sheet feeder and pull the jammed paper upward and out of the feeder.
* Open the scanner cover by pulling the lever located below the control panel, toward you and lifting the cover. Make sure the cover is completely open. Check to see if any paper is left in the paper path.
Close the scanner cover.
Remove the paper in the multi-purpose sheet feeder. Adjust the guides in the sheet feeder to the position for the paper size you are using. Fan the paper well, push down the paper lever. Load the paper with the lever down. Make sure the print side is toward the fax machine and the paper level is stacked below the paper mark. The feeder can hold up to 200 sheets of paper (20lb paper) or up to 10 envelopes.
* Turn the power back on.
I hope this helps you.
Aug 03, 2010 | Brother DCP 1000 All-In-One Laser Printer
My mp730 does not scan since i moved to a new computer under windows 7. I have downloaded the dedicated driver from Canon for the Mp730 with windows 7. Everything else wors properly, printing from word,...
Did you download and install the MP Toolbox (shown under the Software heading) from this link? This is the software program that allows the computer to use the scanner.
Mar 06, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
When I print on my Canon MP730, it always prints out a blank page after every print job. How can I fix this?
SOLUTION(S): Reset the Sheet Feeder Gears
If the power fails while the paper is feeding or during a print job, the paper feed gears will lose their proper
alignment. The reason is that after the power is restored the paper feed gears will attempt to return to the
home position, which may not be possible if the paper stop cam is not in the correct position.
PROCEDURES
1. Remove the sheet feeder from the unit.
2. Remove the sheet feeder motor from the sheet feeder assembly.
3. Remove the drive gear from its spindle.
4. Realign the lifting tray gear and paper stop cam gear.
5. Reinstall the drive gear and sheet feeder motor.
6. Reattach the sheet feeder to the print unit.
7. Reassemble the unit.
Jan 11, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Document feeder doesn't work anymore - I have to feed each sheet manually
Read instruction manual's troubleshooting portion in last pages to correct malfunction, may need repair or to buy new printer.
Oct 22, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Vertical paper feeder for the copier not grabbing next original sheet
I'm having a similiar problem. Can't consistantly feed one sheet at time. If i load several sheets it pulls all through, etc
Sep 03, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Top feeder won't work properly
hello!
have you tried cleaning the separator pad inside the automatic document feeder?
try to Load one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.
If the problem persists, clean the rollers and separator pad manually
May 07, 2008 | HP Officejet Pro L7680 All-In-One Printer
Dell 1600n All-In-One Laser Printer Logo
73 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
