Question about Fisher and Paykel Fisher & Paykel Washer
Hi the door wont open on my front loader washing machine
  • 124 Answers
SOURCE: washing machine creda front loader
Some washing machines have a mechanical/cable release hanging down underneath, perhaps behind the kick tray thing. the cable is attaches to the pulley at the back and it needs to push against the belt squarely to enable the door to open, otherwise, (after making sure it is unplugged) put you hand down behind the front fascia and lift the moveable part of the doorlock. This will not fix the problem but it will open the door.
Posted on Mar 20, 2006
SOURCE: Kenmore Front Loader stuck in "LOC" and every button produces "ERR"
Look for the 2 buttons on your that have a lock symbol.  Pushing & hold both for 3 seconds.  This toggles the child proof mode.
Posted on Oct 15, 2007
  • 41 Answers
SOURCE: Washing machine rubber door seal replacement
Go to www.Searspartsdirect.com You should be able to find an exploded view and parts list
Posted on Feb 29, 2008
SOURCE: FRONT LOADER DOOR LOCK WONT OPEN OR JAMMED
On a Bosch wfmc3200uc there is a green plastic string, similar to fishing line, located behind the round panel on the front of the machine. It is attached to the top right of the round black piece. Just give a slight tug this will release the lock.
Posted on Oct 21, 2008
FitzOriginal
  • 842 Answers
SOURCE: The door will not open on my Electrolux washing machine
How much trouble do you want to go to?
If you just want to preserve the washing, then simply put it on another cycle tonight and that will keep it fresh until the callout turns up to fix it.
The next clever step is to power the machine off at the mains for 10 minutes. Depriving it of power MAY release the interlock door switch even if the cycle didnt.
Final attempt to get to it... Turn off power, unplug at the mains. drag the machine out so you can see the back. Remove the 2 screws that hold the top on, pull back or tap the top forward (depending on the model) to unclip it. Peer inside. You will see the door switch inside the chassis exactly in line with the door handle on the outside. See if you manually make the mechanism release, or if you have a stubby philips screwdriver, you can probably unscrew the switch complely.
If you trust yourself NEVER to open the door in the middle of a cycle, the machine will of course function without a switch. Just so long as you recognise that you will flood the place if you do open it with water in. Also if you put your hand inside dirung a wash (Or worse still a spin) the power of the motor combined with the weight of the wet washing will rip the arm clean off a fully grown man, so if you doubt yourself or you have kids (or kids may visit) don't leave it like this.
Posted on Feb 09, 2009
Samsung wf8750lsw front loader door wont open
Not sure if you mean when it is fully off or operating, but if you mean that once it is operating the door won't open, then the following applies...
Once a front loader wash cycle starts, the door on a front loader is physically (electronically) locked until the full cycle ends after spin dry. This is to prevent anyone opening the door and letting all the water out in the middle of the wash cycle, which a lot of people try to do to put in more clothing etc.
Apr 11, 2014 | Zanussi F1045W Front Load Washer
My electrolux ewf 1087 front loader door wont open
You will need to remove the drum and reset the alignment.
The cloth is struck and has jammed on the drum movement.
click this link: drum removal
Jan 21, 2013 | Electrolux Washing Machines
The door on my front loader will not open
Here is a tip that I wrote about how to get your washing machine door opened...
Washing Machine Door Jammed
heatman101
Jan 22, 2011 | Maytag Neptune MAH5500B Front Load Washer
My Electrolux ewf1090 front loader door wont open
Turn the power off and leave for 5-10 minutes then turn on. This should release the door lock the problem could be the pump drain filter is blocked clean this and it should resolve future problems.
Apr 25, 2010 | Electrolux Washing Machines
The door on my Smeg Allegra front-loader washing does not open
SOME MACHINES HAVE A DELAYED OPENING TIME SO THE DOOR DOSE NOT OPEN WHEN BUTTON PRESSED LOOK IN MANUNAL TO SEE IF THIS FEATURE IS ON MACHINE IF NOT PROBLEM THEN NEW DOOR LOCK WOULD BE IN ORDER
Dec 30, 2009 | Washing Machines
Lumina washing machine front door can not open
I have a Lumina front loader and the door wont open. Do you know where l can get parts for a new front door in Victoria Australia?
Sep 29, 2009 | Washing Machines
Oct 05, 2008 | Washing Machines
How can i open the door on my washing machine it wont open
Remove machine's upper cover and you will have an access to the door lock unit. Don't forget to disconnect the power cable first! Good luck!
Aug 01, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
151 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
