Question about Epson Aculaser C1100 Printer
Even after inserting a brand new toner the pprinter is saying to replace toner K
    Guru:
  • Epson Master
  • 452 Answers
  1. the Toner k that you are using is not the same model try another one
Posted on Oct 16, 2010
Brother printer MFC 7440 N says to replace toner and I already did
Did you insert a brand new toner cartridge or refill only, if you insert a brand new they read your toner cartridge, if you insert a refill toner cartridge, first you need to reset the toner cartridge, i think in the right side, or left please switch and back to normal position.
Aug 16, 2014 | Brother MFC-7440N Laser Printer
Canon image class MF 4150: it is flashing, message says toner is not set insert toner. Toner has been inserted, it was working this morning, I printed documents fine, now this message. I have taken the...
spacer.gif If you removed and reinstalled toner correctly several times and this error code is flashing, you need to try another new toner cartridge, even though the other one may seem still good to you. If this doesn't remedy problem the Troubleshooting section of the Canonusa.com website says to call 1-800-OK-CANON.
Jul 16, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
I am getting an error message that says "toner is not set, insert toner." I purchased a brand new cartridge, have taken it out a bunch of times and tried resetting it, nothing works. I've had the printer...
I had a similar problem on a Lexmark T520. Some of the off brand generic (and even a few brand name) toner cartridges have slight changes in design that make them miss, or nearly miss the sensor that indicates they're installed. this is usually a metal or plastic actuator on the top of the front panel door.
You can try putting pressure on the printer at different points on the cover. If this wakes up the printer you can either tape paper on the cartridge to make it the right shape to hit the sensor, or get a cartridge from a different manufacturer.
Nov 13, 2009 | Canon imageCLASS MF4150 All-In-One Laser...
Printer is a Samsung CLX 3175FN. It says the
To run a quick check on your black toner, insert your old black toner back to the printer.
press on the menu button -> system -> report-> supplier info-> print. and same for your new toner, if it show u both the old n new black toner are under the same serial number. the new toner might be faulty. Invalid toner detected.
get the new toner with the box packing back to the shop for replacement.
Oct 02, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
Tried to install new toner on my OKI 5800ldn today and it keeps saying it is empty. I have cleaned the connections, restarted, shook the cartridge and nothing is working. This printer is brand new..I am...
Does that printer require you to insert a chip?
look in the toner box and see if there was a chip (or a card) that needs to be inserted into the printer.
May 13, 2009 | Office Equipment & Supplies
Error message about toner
There is no counter on the machine. Toner is recognized by a sensor within the machine that measures density. There is a malfunction. Only way to repair is have it checked /replaced by a tech.
Apr 22, 2009 | Panasonic Panafax UF-790 Plain Paper Laser...
Hp laser 4500 says toner is low or out even after new cartridge
There is a toner sensor in this printer that shoots a beam of light through the toner cartridge. As long as the toner is full and blocks the light, it sees it as being full. If it were the sensor, it would tell you this for all the toners, though. The printer also calculates how much toner may have been used and gives warnings based on that. It could be that this isn't getting reset after you change toner. You can reset the toner gage by going into the reset menu and selecting "New xxxx cartridge" and changing it to YES.
Mar 17, 2009 | HP Color LaserJet 4550n Printer
Toner error
hmmm..not good. when you took out the paper jam, did it come out easy?
http://tinyurl.com/6qcpgy
Aug 18, 2008 | Samsung ML 2010 Laser Printer
Toner Empty Message won't go off
check that the toner is inserted correctly, reboot print.
Aug 27, 2007 | Konica Minolta magicolor 2430 DL Laser...
Epson Aculaser C1100 Printer Logo
76 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
