Question about Adobe Photoshop 7.0 for PC
Error message unable to insert selected graphic because it is not recognized format or is corrupt. I have used this graphic (a pic) a 1000 times everywhere on my computer...dont understand...IF it is corrupt how do I fix it? and as far as unrecognizable..it is a jpg...thanks in advance
Hi If you are in trouble about the placing jpg image in flash then open it photoshop or fireworks save as an other name.jpg and import or place in your working software
Posted on May 29, 2008
Insert sd card again
At this time we recommend you use a different SD card and format it. SD cards can become corrupted and the camera may not recognize your card any longer.
Apr 13, 2014 | Panasonic Sale Lumix Dmc-ts20 Waterproof...
Error message: file is missing or corrupt /WINDOWS/SYSTEM32/CONFIG/SYSTEM unable to log on
your windows was corrupt
the only way to fix this problem is reinstall your windows, use windows cd or recovery cd to reinstall your windows
Mar 29, 2011 | HP Mini 1000 Netbook
Windows is unable to format pen drive when i use right press on drive tools->automatic fix errors and recovery from bed sectors then also display message "windows was unable".
insert 512 MB USB go to click start control panel administrive tools computer management disc mangement you right click select properties tools check now tick in one box after its completed then return and tick the other box scan for and repair/recover any bad sectors and automaticall fix any corrupt files
hope this helps
Feb 25, 2011 | Kingston Technologies 512MB DataTraveler I...
Memory card is locked, how do I unlock this?
Problems typically are pretty rare with Panasonic Lumix digital cameras. On those occasions where you do have an issue, though, look for an error message on the Panasonic camera for some clues as to how to fix the problem.
he seven tips listed here should help you troubleshoot your Panasonic camera error messages.
  1. Built-in Memory Error error message. If you see this error message with your Panasonic camera, the internal memory area of the camera is either full or corrupted. Try downloading photos from the internal memory. If the error message continues to appear, you may need to format the internal memory area.
  2. Memory Card Locked / Memory Card error message. Both of these error messages are related to the memory card, rather than the Panasonic camera. If you have an SD memory card, check the write protect switch on the side of the card. Slide the switch up to unlock the card. If the error message persists, it's possible the memory card is corrupted and needs to be formatted. It's also possible the memory card was formatted using another device that is not compatible with Panasonic's file structure system. Format the card with your Panasonic camera to fix the problem ... but keep in mind that formatting the card will erase any photos stored on it.
  3. No Additional Selections Can Be Made error message. If your Panasonic camera allows you to "save" photos as your "favorites," you may find this error message because the camera has a limited number of photos that can be labeled as favorites, usually 999 photos. You cannot mark another photo as a favorite until you remove the favorite label from one or more photos. This error message also may occur if you're trying to delete more than 999 photos at one time.
  4. No Valid Picture error message. This error message typically refers to a problem with the memory card. Most of the time, you'll find this error message when you try to play back images from the memory card and the memory card is corrupted, empty, broken, or has been formatted with another camera. To fix the memory card, you must format it, but formatting a memory card causes all photos stored on it to be lost. Try inserting the memory card in another device or in your computer and try downloading any photos stored on it before formatting it with your Panasonic camera.
  5. Please Turn Camera Off And Then On Again error message. At least this error message says "please." This error message most likely occurs when one of the parts of the camera's hardware is malfunctioning, usually a jammed lens housing. To try to fix this problem, start by turning the camera off for a few seconds before turning it back on. If this doesn't fix the problem, try resetting the camera by removing the battery and memory card from the camera for at least 10 minutes. Replace both items and then try turning the camera on again. If the lens housing is jamming as the lens moves through its zoom range, try gently cleaning the housing, removing any debris or grime. If all of these steps don't fix the problem, you'll probably need a repair center for the camera.
  6. This Battery Cannot Be Used error message. With this error message, you've either inserted a battery that's incompatible with your Panasonic camera or you've inserted a battery that has dirty contacts. Gently clean the metal contacts with a dry cloth. In addition, make sure the battery housing is free of debris. You sometimes may see this error message if you're using a battery that's not manufactured by Panasonic. If the third-party battery is working OK to power the camera, you probably can ignore this error message.
  7. This Picture Is Protected error message. You'll see this Panasonic camera error message when the photo you've selected has been protected from deletion. Try working through the camera's menus to figure out how to remove any protection labels for the photo files.
Keep in mind that different models of Lumix cameras may provide a different set of error messages than is shown here. If you are seeing Panasonic camera error messages that aren't listed here, check with the user guide for your model of Panasonic Lumix camera for a list of other error messages, or visit the Support area of the Panasonic Web site.
Jul 11, 2010 | Panasonic Cameras
My Sony DSC S40 Digital Camera is giving problem. I purchased the camera on Sept 2005. Lately i am getting format error. Whenever I click photos I am not able to get my half of the photos. When I try to...
When you disconnect from the computer, do you use the "safely remove hardware" icon at the bottom right of your screen or do you just yank out the cord? When you yank, most of the time you will corrupt the card and even the camera. You can try to download your pics from the card using a separate card reader or take it to a store like Walmart that has a Kodak picture kiosk and print your pics or even make a cd of them. Then, Check your owner's manual to learn how to reset the camera. After that, format the card in the camera.
Feb 17, 2010 | Sony Cyber-Shot DSC-S40 Digital Camera
Memory card unformatted
If there are sd card error, you cannot format your sd card. you may get messages like
"No SD memory card inserted" messages appears when using digital cameras,
"A media card hard been inserted that contains errors. Do you wish to repair the Media Card now?"
You can read the files on SD memory card, but you cannot write new files or you cannot edit files on SD memory card,
"Access denied", when SD card is corrupted or broken,
you can fix sd memory card errors first and them format you sd card.
Nov 05, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Format error
format ur card on PC change the card
Jun 16, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Card Error message
Your card may have become corrupted, there are good free utilities out there to save such files from corrupted memory cards, try DIR (Digital Image Recovery) that you can use with a computer card reader if the computer does not recognize your connected camera as an external hard drive.
If you were able to recover your files, format the card in the camera, that should solve your problem using the card.
If the card cannot be recognized by the computer or formatting the card doesn't help, you may have a defective memory card, try another one.
If the card works otherwise but is still not recognized by the camera you may have a defective memory card connector or other camera motherboard problem, sorry.
Hope this helped...
Sep 01, 2008 | Fuji FinePix S602 Zoom Digital Camera
Can't transfer data files
I called Sansa and I was instructed to format my player. The steps were as follows:
1)Connect player to computer
2)Go to my computer and right click on your player
3) Click format on the menu
This will start the formatting of the player. After this I was fine. This is the 2nd time I have had to do this in a year and all I put on this player are books.
******Please Note**** This process will erase any files you have on your mp3 player.
May 08, 2008 | RCA JET S2002 MP3 Player
Adobe Photoshop 7.0 for PC Logo
50 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
