Question about AEG Lavamat 72640 Front Load Washer
Incomplete washing cycle. Water will not drain
  • AEG Master
  • 17,129 Answers
Check the voltage to the drain pump, if present the pump is not working and must be repaired , cleaned and set back.
if there is no supply to the drain valve/pump, the program controller is faulty.
Posted on Sep 27, 2010
The top is locked
Hi Janice
very descriptive "the top is locked"
Samsung model
Check rear of manual for problem help
Probably being held with an electrical solenoid catch because a cycle is incomplete.
Could be full of water. Logic chip says "don't open"
These modern smart devices can be a pain when things go wrong.
Hold drain hose to floor & see if it drains out.
Jan 08, 2016 | Washing Machines
Holding water
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 02, 2013 | Washing Machines
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
Not draining n spinning. incomplete washing cycle.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 16, 2011 | Washing Machines
Hoover H160E - stops with lights flashing 4 times (cyclic)... suaully before aspin cycle... appears to be incomplete drain (drains until no water viisble in drum - but still significant water at drain.....
I would definitely change the pump motor judging from your clear symptoms and observations!
It's probable that the motor isn't running efficiently, just enough when helped by the 'gravity' of the full drum but struggles once that is minimum.
Go for it ;-0)
John C
Feb 26, 2011 | Hoover H160E Front Load Washer
6 yr old side by side inglis fridge/freezer. water
can be from an obstruction (i.e. food or debris) or incomplete defrost. water forms around the drain during defrost cycle and ices up when cooling cycle comes on. defrost the drain and try installing a heat probe part#819043 made by whirlpool.its a metal rod that wraps around the heater and goes into the drain opening to prevent the drain from icing up. hope this helps.
Oct 21, 2009 | Kenmore Refrigerators
Washing machine, clothes come out very wet, as an incomplete spin cycle. I think the brake is out.
You can tell if the brake is out when you open the machine lid while it is in spin cycle,,, if it does not stop spinning quickly, then the brake is not working. but if it stops fast,, the brake is operating correctly.
I'm more apt to think this is a direct drive machine.
If you stand there and watch and listen,,, it should go from the aggitate cycle into the drain water cycle without any spin,,,this will last about 1 minute. Then it should kick into spin cycle once the tub is empty.
These machines are prone to wear after time that causes it to "shift" incorrectly,,, thus spinning when it should be only draining (kinda skipping the drain cycle of sorts)
You can visually check this by opening the door after the drain cycle starts to see if the tub is actually spinning inside. if it is,,, then the transmission is damaged and repair can become expensive.
I have taken the transmission out of an old machine and swaped to repair (if you have another good transmission that is)
You may want to look at the plastic and rubber coupling between the motor and transmission to insure it is in good shape if you find the transmission is shifting correctly as explained.
Oct 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Incomplete wash cycle.
It sounds as if you have something acting as a flap causing the restriction. You should take the hose that leads from the tub to the pump off and see if there is anything just inside the tub. I have noticed that alot times you could have a coin that blocks the opening. You may have to remove the inner tub to remove anything in there
Dec 30, 2008 | Maytag SAV3655A Top Load Washer
Incomplete water emptying following spin cycle
your pump is on its way out inside they have a small fan which pushers the water out if that is lose than the pump has to be replaced common fault
Dec 25, 2006 | GE WJRR4170E Top Load Washer
AEG Lavamat 72640 Front Load Washer Logo
125 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
