Question about Intel Motherboard
Board not on when i put 4pin smps connector on the board., without this connector board on. plz help
  • 140 Answers
It might be problem with your motherboard VDO section (Voltage down oscillator) which is generating core voltage for processor. You can approach any local motherboard service centers for repair.
Posted on Sep 27, 2010
How to assemble the aspire T120c desktop
Install IO headers for power & reset switch, LED' some-times written on board or find diagram in manual.
Basically install power, 20 or 24Pin power connector.
Install 4Pin CPU power connector.
Install data cables for Hard drive and CD drive.
A video may be found on You-Tube.
Take care!
damnor01
Sep 22, 2012 | Acer Aspire T120 PC Desktop
I have got a system with an Aopen motherboard which having only a 20 pin connector for smps connectivity. the Atx smps i have is is 24 pinned. i can connect the main line by splitting up the 24pin...
The actual Processor fan connects to the CPU Fan header on the mainboard. It's 4 small pins. It plugs in right near the CPU socket on the mainboard. Check the user manual for exact placement, you may download it from the AOpen website if you don't have one already.
Plug in the 20Pin connector if that is the most Pins that the mainboard will allow. Cable tie the other 4Pins back onto the 20Pin connector.
Then if there is additional 4Pin connector required by the mainboard for CPU power and you don't have that connector on you power supply, you will need to purchase a Molex to 4Pin CPU power connector. When you go to the computer store check with them that all is correctly connected.
Take care!
damnor01
May 25, 2011 | AOpen MX4GER Motherboard
Motherboard will not post no video either if i have the 12v 4pin cpu plug in its socket the pc just starts and stops in a loop
The motherboard is stopping while you connecting the 12V 4pin connector because of VRM short circuit (Voltage Raiser Module, CPU V-Core circulatory). Contact Nearest Gigabyte support center for support.
Feb 12, 2011 | Gigabyte GA-EP43-DS3LR Motherboard
I am installing a new power supply. Need wiring diagram to make sure all components are hooked up properly.
Basically each connector is made so that it can only go where it should go unless you do some modification or really force the connector in.
All in all you should have one 24pin brick of wires. This is made up of 20pin block plus 4pin block.
If your computer mainboad requires 24pins of power then take the 20pin block and add the 4pin block to it. If not then just use the 20pin block.
Then there is the 4pin CPU power brick. Can only go in one way.
This 4 pin block is not to be confused with the other 4pin block found on the 24pin brick.
Lastly there are 4pin Molex, SATA and stiffy connectors, they can also only go in one way.
If it all fits in then you should be alright.
CPU: 4pin
Mainboard: 20+4pin
Hard drives: Molex or SATA power
damnor01
Jan 29, 2011 | HP Pavilion a335w (Refurbished...
No keyboard, no display, doesnt sound like computer boot ups
firs remove the cover and remove the 24 pin conected to the motherboard from the smps you will also see another 4pin conector conected to your motherboard from the smps remove them to then short the pin green and bleck in the 24 pin connector and see wether the smps fan is working if working coneect the 24 pin to the motherboard leave the 4 pin aside and switch on the computer if the processor fan is working switch of the computer and connect the four pin conector to the motherboard and switch on the computer if the processor fan is not working then you have problem with the motherboard
Jan 29, 2011 | HP Computers & Internet
My computer want come on with the power the light is on on the back of the tower but it will not come on when i push the power button
you need to check the SMPS first remove the 24 pin conectior to the motherboard from the smps and short the green and black pin if the SMPS fan is working there is no problem in the SMPS conect tthe 24 pin conector to the motherboard then remove the 4pin conector from the motherboard from the smps and switch on the computer of the computer fan is working you have froblem with *********** board
Jan 17, 2011 | HP 1GHz Compaq/ Desktop Computer (RB1GPKG)
What dose the smps 4pin socket used for
Power for the Intel processor.
It's a > 4-pin ATX +12 Volt
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
Is there another problem I can help with regarding this?
Please post in a Comment.
Regards,
joecoolvette
Nov 24, 2010 | Intel D915GLVG Motherboard
Board will not boot.power supply changed
The power supply and motherboard have a connection (4pin) that communicate to each other. Without this connection, the board will not boot and the power supply will not come on.
The power supply can be fooled by jumping certain pins, but the motherboard must be connected.
Please consult your motherboard manual for the location of this connector.
Visit this site for more clarification please.
http://www.pcguide.com/ref/power/sup/partsMotherboard-c.html
Sep 27, 2010 | MSI MS-6734-10 (-6734-010) Motherboard
No display or POST
WAS THE POWER SUPPLY WORKING? IS THE 4PIN BLACK AND YELLOW CONNECTOR FROM POWER SUPPLY IN PLACE? DID YOU TRY BIOS CLEAR? IF IT IS NOT A NEW BOARD - CHECK FOR BLOWN CAPS AROUND CPU (UPRIGHT CYLINDER TYPE THINGIES. RESEAT RAM. CHECK IF MAYBE ONE OF 24 PIN ATX CONNECTOR DIDN'T PUSH OUT OF SLEEVE.
Nov 06, 2008 | EliteGroup GeForce 6100SM-M Motherboard
CPU is not getting started
In SMPS 20 pin Connector please short the green and black wire with a twisterand on the smps. if the fan is rotating then the smps is ok
Jun 19, 2008 | Intel D845GVSR Motherboard
Intel Motherboard Logo
41 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
