Question about Whirlpool Washing Machines
There appears to be water collecting in the drum of my machine when it is not in use - It is only 6 months old, I checked the filter to see if anything was blocking that and it was ok - please advise thanks Ursula
    Problem Solver:
  • 10 Answers
You either have a leaking inlet valve which would require replacing or you outlet is allowing water back into the appliance.check how the outlet hose is fitted
Posted on Sep 27, 2010
Cleaning filter on Samsung front loader
Hi! First I'm not a Samsung tech. But I am an equipment tech (retired) but more important I (sorry) WE, have a Samsung front loader too! I was wondering the same question. Where is the filter? We have 5 dogs and 2 cats so I'm pulling a lot of hair from the lower part of the door rubber (there is a small drain hole where stuff collects) But your question prompted me to really look for this filter. The following is from the manual:
* user manual WF45K6500A / WF45K6200A Page 53 (English)
1. Turn off washer, and then unplug power cord.
2. Drain the remaining water inside the drum. See the "Emergency drain" section on page 49
3. Gently press the top area of the filter cover to open (it's located at the lower left front of washer. ukeboy57) C
4. Turn the pump filter knob (A) to the left and drain off remaining water.
5.Clean the pump filter using a soft brush. Make sure the drain pump propeller inside the filter is unclogged.
6. Reinsert the pump filter, and then turn the filter knob to the right.
7. Close the filter cover.
Note; If the pump filter is clogged, the "5C" information code appears on the washer display screen.
* Final; I haven't done this yet though we had this machine for a month now and I suspect it's filthy. Warning though, the emergency draining looks messy so have the pan and towels ready. (and I just got finished tiling the laundry room floor too!)
Aloha, ukeboy57
Jan 04, 2018 | Miscellaneous
Why is clean water collecting in the drum of my washing machine afer a cycle?
Replace the inlet solenoids. They are where the hoses attach to at top back of machine. Dead easy replacement. Couple of screws and a tubing clamp
Nov 01, 2014 | Bosch Washing Machines
I have a Classic D15 (home hardware) dehumidifier and it's running but not collecting water. It's only about 6 months old. Not sure if I have the receipt for it or I'd take it back. Any...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 11, 2011 | Kenmore 54501 Dehumidifier
My 54351 dehumidifier runs for hours and doesn't collect much wat
I hope someone answers this because I'm having the same problem. Mine is about 4 years old. I thought it was my filthy filter but cleaning didn't change the problem.
Dec 04, 2009 | Kenmore 54351 Dehumidifier
My clothes are coming out smeeling musty
I have a zwf1241w with similar problem. When I disconnected the drain hose that runs from the drum casing to the pump housing there was a lot of collected debris that had prevented the water from draining through properly. You could try clearing this out.
Oct 06, 2009 | Zanussi F1045W Front Load Washer
Water appears in drum after wash cycle is finished.
if you remove the front cover there is a drain plug that holds change and lint paperclips etc, it fills up and gets plugged and wont go throught the drainig pump. if you find this and clean it out you will be good for another 6 months...its important to check pockets before washing
Sep 09, 2009 | Washing Machines
4E code keeps apearing
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 29, 2009 | Washing Machines
Drum filling with water and now and them gives off a nasty smell
try cleaning out the filter but dont forget to turn the hot and cold water taps off at the rear!
Aug 15, 2008 | Zanussi F1245W Front Load Washer
LG WFT1391TP GUZZY LOGIC
Should still be under-warrenty check with your local service agent first please advise if you need any further advise
Dec 12, 2007 | LG WFT1071TP Top Load Washer
Washing Machines Logo
Sal De
Gerry Harvey
Gerry Harvey
