Question about Durabrand Televison & Video
Lost manual I can record the vhs onto dvd but I cannot find out how to format the dvd so as to play the dvd on other dvd players.
  • 2 more comments
  • Angharad May 23, 2008
    Hi I have a Durabrand, dvd/vhs Dual Recorder
    Model No. ADB2737BDS
  • Angharad May 24, 2008
    It is the right model number. I managed to download a Service Manual from a site in the US, but it describes how to take the thing apart. If anyone has a similar model, a scan of the relevant page of the manual would be great.
  • Angharad May 26, 2008
    I have managed to record from VHS onto DVD, I need to finalise the disk for playing on other DVD players.
    I just need to know how to finalise the disk on the machine I've got
  • 1,031 Answers
U CAN USE THE TOOLS IN NERO DVD BURNER TO FORMAT I THINK NERO 7.0 CAN HANDLE ANYTHING IN THAT ASPECT
Posted on May 23, 2008
    Genius:
  • 3,422 Answers
HI,
There is no manual available for the model no. you've posted.Are you sure that is the right model no.?
    Sergeant:
    Champion:
  • 304 Answers
kindly wait, while i searching for your manual
  • Elizabeth Krijt
    Elizabeth Krijt May 23, 2008
    http://www.service-docs.com/store/catalo...
    Drives that use buffer underrun protection will pause a recording when
    the drive's memory buffer is nearly out of data. The drive will wait
    until the buffer fills again and then will resume the recording. If
    it's taking your drive a long time to record a disc, the drive's buffer
    underrun protection may be working overtime, pausing frequently as it
    waits for its buffer to fill again.
  • Elizabeth Krijt
    click HERE
    Guru:
  • 1,894 Answers
Use a erasable media to format the DVD sir..
3 Suggested Answers
SOURCE: panasonic recorded dvds? what's up?
http://service.us.panasonic.com/OperMan/findmanual.aspx?model=DMRES40V
Try the Manual. It has a finalizing section. This is the link above.. Pat
Posted on Jan 14, 2008
SOURCE: DVD recorded discs (from VHS) do not play on other dvd players
I called the manufacturer. They admitted to improper instructions. They provided me a fix to their copying protocol and it worked. Also, they game me instructions on how to fix already copied tapes. It works well and I would have to say I was impressed with their customer/technical service.
Posted on Dec 27, 2008
How to convert VCR to DVD
no easy way to do this unfortunately. You either need to connect your VCR to a DVD recorder and record it directly onto DVD or use a device such as this http://www.dx.com/p/easycap-usb-video-capture-adapter-5707 to connect your VCR to your computer and record it onto your computer that way.
Feb 23, 2015 | Zenith XBR616
I have dubbed vcr tape to a Sony DVD-RW disc and tried playing it back through a toshiba player and it keeps coming up Bad Disk. My PC won't even recognise it. When started dubbing the screen displayed 1hr...
Did you say you used a DVD-RW disc to transfer a videotape onto? The reason your PC won't recognise that disc is because the data format on it is a different language to what PCs understand - plus an unfinalised DVD-RW won't play in other DVD players - it is usually an incompatible format.
(DVD+RW discs with titles/top menus created in video mode CAN be played on a PC DVD drive or a normal DVD player as can finalised DVD-R discs (DVD-R discs MUST be recorded and finalised in the same recorder for compatible playback). DVD-RW discs can only be viewed on the unit they were written/recorded on.
The other reason for the 'remaining space' on the disc you describe showing less than 120 minutes is due to a title recently being recorded or erased - unless you format it - the 120 minute / 4.7GB DVD-RW will not show full available space. Erasing titles on re-writable DVDs does not increase space. The same rule applies to unfinalised +R / -R discs (you cannot re-format these to get the space back once recorded - they are 'once only' writables)
I recommend you invest in some DVD-R discs and re-copy your VHS tape to that - then if you are satisfied with the result, title etc., finalise the DVD-R - it will play on any DVD player or PC with DVD support (or it should). These discs are relatively inexpensive to buy just about anywhere.
Final note: do NOT finalise the DVD-RW you recorded (I hope you haven't already done this) - simply format/erase it - re-use it for something else or keep it until you need it.
You can use any brand of DVD, just take note of the format before recording/playing.
Mar 21, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
How to record a vhs tape to dvd on a samsung 1080
Hello
1.The VHS/DVD player must have recording capabilities.
2 Connect both players to a television so that you can make sure you are recording the appropriate content. You can also monitor the speed at which the VHS is copying to DVD.
3. Place the VHS in the VHS player and the blank DVD in the DVD recorder. You will need to use your remote and go through the menu options to choose the correct format for recording. The formats should be clearly labeled and outlined in your instruction manual. Choose the option that will read something like "VHS to DVD." You may also have to choose recording speed, which varies per blank DVD that you purchase. Every player is different, and every menu will vary slightly. If you have questions, refer to you individual manual.
4. Select the option that works best for you and hit "Play" on the VHS player and "Record" on the DVD recorder. To play the finished DVD, you will select the playback option.
THANK YOU
Dec 14, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
I recently copied some of my old VHS tapes onto DVD-R disc & they play fine on my Magnavox, but won't play on my other DVD player. What did I do wrong?
Check through, the settings of Magnavox and do the similar region
settings in your other DVD.
In short to say, recording format and the play back format does not
match. if you corect this through the MENU available, it should be OK.
May be your other DVD is old model!
Aug 22, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
DVD burning problems
try sothink dvd moviemaker software or dvdvideosoft software from www.cnet.com/download.....most dvd recorders will burn (check your manual for the correct type (+ / -) and brand that works best)...but wont let you play on other machines unless you format and the other machine is just as new as the recorder...(our older dvd players will not play these new dvd)
Jun 08, 2010 | LG RC389H DVD/VHS Recorder
How do I record my vhs onto the dvd?
How about a USER MANUAL instead :D
Please note this unit is NOT a DVD recorder. It only has a DVD ROM drive to play DVDs - not to record to them.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 30, 2009 | Samsung DVD-V4600 DVD Player/VCR
Want to copy vhs to dvd
just play your movies from vhs iput your audio/video to computer with TV CARD and video input. then record it and burn to DVD format after recording.
May 26, 2009 | Panasonic DMR-ES25 DVD Recorder
Transfering a vhs to a dvd
Hi jh1014,
If the disc is not playing on your home DVD player, it is possible that it was recorded in a format your unit does not support.
Your friend’s DVD recorder most likely recorded the DVD in a format readable by the player in which you watched it successfully.
Refer to your product manual for more information on which file formats your DVD player supports.
Thank you,
Jason,
Go Ahead. Use Us.
Jun 17, 2008 | Televison & Video
Converting VHS to DVD
All you have to do is buy a vhs to dvd recorder. They sell those everywhere, like costco, walmart, etc. They keep getting cheaper and cheaper...
They will come with a manual with model specific instructions, but usually its pretty easy. The cassette plays and the device records the video onto the dvd.
They also play vhs and dvds too XD.
Here's a good website:
http://hometheater.about.com/od/dvdhardwareandsoftware/tp/dvdvcrrecorders.htm
Jan 06, 2008 | Emerson EWD2203 DVD Player/VCR
Panasonic recorded dvds? what's up?
Aug 02, 2007 | Panasonic DMR-ES40V DVD-Video Recorder
Televison & Video Logo
56 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
