Question about Sun Micro Refurbished SUNBLADE 1000/2000 SUNFIRE 280R BOARD Micro (5015938)
SunFire 280R Our Sunfire 280R doesn't boot up. It keeps self-diagnosing and rebooting. Sometimes it finishes all diagnostics and tries to start up server, then, hangs up and reboots again. Other times, it hangs up even before going into fsck. I see 'Invalid Fcode startbyte at fff0a000" and "Fatal Error reported by CPU0" intermittently during all those reboot cycles. Sometimes, fsck finds incorrect block counts and corrects them. Other times, file system is all fine.
  • 55 Answers
Replace CPU0. If you have more then one CPU, try to switch them around.
If you need a replacement CPU send me an email with the CPU P/N to support@netsalem.com
Posted on Jun 08, 2008
When I try to start it (2000 Pontiac Sunfire), it turns over but just stops - as if it's out of gas but the garage said it's all tied in with the electrical. Four times in 8 months this has...
Try resetting the fuel cut-off switch. This cuts fuel supply to the engine in an accident (if the car was bumped it sometimes sets off). From the trunk, find a hole just bigger than your finger on the side of the car that the fuel filler door is on. Put your finger in there and there should be a button that you can push. Hold it for a second or two should be fine. If that doesn't work, try it again with the key turned in the ignition (not with the engine running but enough to turn on the heater fan). If that doesn't work, it will be something else that i cannot diagnose from here. Good luck.
Sep 15, 2011 | 2000 Pontiac Sunfire
2005 sunfire sometimes stalls while driving at 60mph after 30 miles and sometimes hard to start, have pumped the fuel peddle, can't tell if that helps or not. It does start eventually.
the problem with an intermittent stall is it needs to be diagnosed when it happens.your losing either spark or fuel when it stalls & this is what you need to find out.a couple of things you can do when it does'nt start is try spraying some carb cleaner in the throttle body to see if this helps.you can pull a spark plug wire off & ground it to see if your getting spark.neither one is too hard to do but making sure you have what you need on hand will help.
good luck
Jun 13, 2011 | 2005 Pontiac Sunfire
I have a 2000 Pontiac Sunfire SE Sedan that makes a clunking sound when turning and manuevering at low speed that can be heard and felt on the floorboard and through the steering wheel. What can I do to...
hard to diagnose without hearing my self but from your description i would say it one of your half-shaft
best thing to do for sure is to take it to a repair shop most will take for test drive and diagnose the problem for free
Nov 22, 2010 | 2000 Pontiac Sunfire
2001 Pontiac Sunfire automatic engine may start
You might want to have it checked to see if you have fuel pressure or see if there is spark going thru to your spark plug.If everything is ok it might be your timing belt needs replacing
Jul 23, 2010 | 2001 Pontiac Sunfire
My blinkers work sometimes .if i keep trying they may or may not work on my 1997 sunfire.What could be the problem?
Check all of your fuses and make sure none are black. If this does not work, try to check your wires and your signal for shorts
Mar 10, 2010 | 1997 Pontiac Sunfire
I am trying to install a fuel pump for a 2003 sunfire.
Once you get the fuel tank out, its self explanatory. Some cars do have a access panel under the seat, but I dont think a sunfire does.
Feb 07, 2010 | 2003 Pontiac Sunfire
The sigh check is flashing? what is this? on a sunfire 95
I am not familiar with a Sunfire "95" powerchair. Drive makes a Sunfire General and Sunfire Power Plus, however, which have diagnostics for troubleshooting the flash code in the owners manual.
Here's a link to that site for the owners manual if you lost yours. https://drivemedical.com/catalog/omfiles/SPGT-3C-BL_Manual.pdf
Troubleshooting and flash codes are on page 26.
Jul 07, 2009 | Drive Medical Sunfire Power Based Wheel...
Problems In a cylinder of pontiac sunfire
What engine? Does it have good compression?
Mar 08, 2009 | 1999 Pontiac Sunfire
1997 sunfire Diagnostic Code PO742 ( torque converter circuit stuck on ) how to repair?
TCC silonoid.. torque converter control... seems simple but you gotta drop the front subframe to get the side panel cover to but it in....
Aug 07, 2008 | 1997 Pontiac Sunfire
Open Questions:
Get Data Recovery Backup Online Data Recovery Cloud backup, in simpler language also known as online backup, is a way to backup data by storing a copy of the data over Internet to secured cloud servers. Unlike the traditional ways to store data on local hard drive media the data is stored on cloud servers that are accessible through Internet. Cloud backup technology also help us retrieval of stored data on the go using a variety of devices all connected to the cloud servers. With Cloud backup, end users can upload documents, photos and videos to the cloud and then fetch them at their ease. This helps them save storage space on Server Cloud Backup Solution their computers and mobile devices. Furthermore, the cloud based structure allows end users to upgrade software more quickly - because software publishing companies choose to offer their products via the web rather using traditional, tangible methods that involve discs or flash drives. Top software publishing companies have chosen to turn their business models to subscription based and they deliver their product offerings through cloud solutions. All data is critical for businesses. It's a treasure trove of information. Problem is, they are drowning in it. Datalign provides a lifeline. We provide Cloud Backup For Small Business companies with a unique approach to backup, analyze and organize their data with the use of artificial intelligence Capabilities. Not all data file types should be treated in similar manner. Data may be accessed or stored depending on the requirement of the users; some users may want the data at their fingertips whereas others may want to store it for archival and compliance purpose. To rectify this problem with one solution, we have introduced the world's first Tribrid Backup. Without sacrificing any data, it enables businesses to protect all produced data and save storage costs. Our innovative platform has been designed while keeping you in mind. To provide Online Backup Pricing optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly. Our Cloud services are available on demand and always up and running. We ensure 99.9% uptime for our cloud services. This ensures un-interrupted data transfers and practically no downtime.
Jun 18, 2018 | VIA Computers & Internet
See all Sun Micro Refurbished SUNBLADE 1000/2000 SUNFIRE Questions
Computers & Internet Logo
469 people viewed this question
Top Sun Computers & Internet Experts
Robin Hill
Robin Hill
k24674
Are you a Sun Computer and Internet Expert? Answer questions, earn points and help others
