Question about Actron Digital Multimeter Tester
I have just purchased digitor multimeter q1563 and there is no operating instructions included. the store was of no help. the quick test only dislayed OL.when a reading should have been displayed. the main use will be for auto work so electrical harm is not a real issue
2 Suggested Answers
  • 18 Answers
SOURCE: darrell ,testing 240v with adigitor q1563
Make sure it is switche to AC Volts. If it is a range multi meter, set the range to 240V.
If it is auto ranging, it should do it on its own as long as it is set to AC Volts.
AMPS kill, voltage doesn't. Still, be careful working around electricity.
Hope this helps. If not, contact me and I will give you my email address and you can send a digital pic of the meter and I can tell you how to use it.
Hope this helps!
Rob
Posted on Sep 22, 2009
Testimonial: "it was helpful, but i worked it out in the mean time with the help of my neighbour thanking you darrell"
I need instructions for Quick Easy Dress Pattern McCalls 9345 Sizes 8 - 12. Can anyone help?
You might want to contact McCalls support directly for assistance or purchase a duplicate pattern that has the instructions included. Other than that, perhaps taking it to a sewing store will get some help.
Jan 17, 2017 | Sewing Machines
What is meant to come in the box when purchasing digitor C0598 wireless infrared headphones system
You should also have instructions with a list of components. If not GO BACK TO THE VENDOR
Oct 15, 2014 | Radio Communications
How to set mastech multimeter to read small batteries
Set the multimeter to a DC voltage range that includes the voltage you wish to test. Connect the probes with the correct polarity and observe the reading
Mar 16, 2013 | Mastech 19-range Digital Multimeter Dmm...
I have a Digitor A2632 Sub Speaker and would like to purchase a second unit (identical) Does anyone have one in good condition to sell to me?
Hi Denis.. Did you ever get another Digitor A-2632 unit? Cheers Martin Ruffell.. P.S. Whereabouts do you live?
Jun 07, 2012 | HTC Audio Players & Recorders
How do i install the mcrosoft and where can find the microsoft word 2007 pls help me....???????
Microsoft is a company that manufactures software for computers. So i'm not too sure what you mean by how do i install the microsoft, but i'm assuming you mean the operating system windows. You can purchase the operating system windows from many places including your local best buy or even wal-mart. Another way to purchase it is online at many online stores including microsoft itself or even newegg.com or tigerdirect.com. If you already have the operating system cd, the first thing you do is put it in your cd drive, if nothing pops up, restart your computer. Your computer will automatically push you through step by step instructions to install windows onto your computer. After installing windows you will have a demo for microsoft word, but to have the full version you will have to purchase it on their website.
Hope this helps
--Andy
Jun 05, 2011 | Microsoft Windows 7 Home Premium 64BIT...
Set dead
Hi,you can use the following instructions below to troubleshoot the receiver set that is dead.
Instructions
Turn the receiver off and disconnect the power cable from the wall and the back of your receiver.
Test the cable with a multimeter to verify that it is working properly and supplying the receiver with full power. Multimeters are widely available through electronics supply shops, hardware stores and various online retailers. Different multimeters give different readings, so check your operations manual if you are unsure how to test a power cable for continuity. Replace the power cable with a working one of the same type if the original cable is not working properly.
Connect the multimeter to the pins where the power cable connects to the amplifier if the cable is working properly. This is the same area from which you disconnected the power cable in the first step. This is a particular process and all multimeters use different readings to test for pin-out continuity.
Check the fuses on the back of the amplifier if the multimeter shows a correct reading when you test the power cable and power connection on the back of your amplifier. Look carefully for a cracked filament within the glass tube; even a small crack can result in power failure or intermittent operation. A blown fuse will generally look gray or black around the edges or inside the glass tube. Blown fuses will not provide power to the amplifier and are a common cause of no power or a single dead channel, depending on the location and type of fuse.
Tips & Warnings
Opening the amplifier is not recommended, as there is a risk of electrical shock and you may void the manufacturer's warranty from Yamaha or any warranty provided by the retailer you purchased the amplifier from.
Always replace fuses with the same voltage fuse. Using the wrong type of fuse can damage your amplifier.
Do not try to open the receiver and fix the power supply if you believe that you have a power supply problem. This is generally quite dangerous if you do not know exactly what you are doing or are not working with the proper tools.
Hope it helped..
Feb 18, 2011 | Audio Players & Recorders
Darrell ,testing 240v with adigitor q1563
Hope this helps!
Rob
Sep 22, 2009 | Actron Digital Multimeter Tester
Tuning digitor tv
And this relates to camera lenses in which way???
Jul 04, 2008 | Cameras
I have a digitor answering machine. Can you help me with an instruction booklet please?
I have a digitor answering machine F-8013 serial no 60628950 given to me by a fried but I have no instructions. Is there a manual that I can download?
Jul 02, 2008 | Uniden Cordless phone EXS9950
Actron Digital Multimeter Tester Logo
794 people viewed this question
Top Actron Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Bill Boyd
Are you an Actron Measuring Tool and Sensor Expert? Answer questions, earn points and help others
