Question about Pinnacle Solene SLP10 Baitcast Reel
On my pinnacle le pls10 reel it reels in fine but i cant stop the line from pulling out the handle and spool turn i think something might be missing were can i get a free diagram so i can check it out
5 Suggested Answers
  • 14 Answers
SOURCE: parts list,prices,and diagram(exploded view)
i have a manual on a pinnacle inertia reel.if you cant get the schematics from (www.pinnaclefishing.com/www.silstar.com,i would be more than happy to mail the one i have to you.just let me know.i have an extra copy ...
Posted on May 15, 2009
  • 509 Answers
SOURCE: when casting spool keeps spinning after line has
There should be an adjustment on the reel to set it so the spool stops.
Posted on Jun 22, 2010
  • 45297 Answers
SOURCE: I have a Pinnacle Inertia reel . It is time to
http://www.pinnaclefishing.com/shop/t-partsdiagram.aspx not sure it willl help but worth a try
Posted on Nov 01, 2010
  • 3 Answers
SOURCE: Cant cast the pinnacle platinum plus lp 100
Sounds like your drag is too loose. Best way to get used to setting a baitcaster, in my opinion, is to put a 1/2 ounce weight on the end of the line and engage the spool. The line should drop to the ground freely, but not full speed - if too fast, the spool will continue to spin and you'll get that dreaded birdsnest. If it doesn't reach the ground, you need to loosen it more. Once you have it set, keep that weight on and go practice, using the thumbing process Parorae noted in the previous answer.
They take some getting used to for sure!
Posted on Jan 01, 2011
I have the 1276sli abumatic spincast reel. The issue is when am reeling the line in there is bump in the handle always at bottom as i crank the line in under load.
Hey michael,
Sometime when you add line to a spincast reel, where you tie the knot and wind line onto the reel, it makes a bump in the spool, this "bump" in the spool sometimes hits inside the reel everytime it makes a rotation....
May 18, 2017 | Fishing
Howtoseyupaspincastingreel
use 10# test line or heavier. use 3\8 oz lure or heavier. set magnetic control to "5". tighten small silver knob under the reel handle down until the spool will not turn when you push the thumb bar. loosen the same silver knob while you have the thumb bar pushed and adjust the knob tension so that the spool stops turning when the bait hits the ground. this is basic tuning for any baitcasting reel.
Jul 08, 2012 | Abu Garcia Pro Max Baitcast Reel
I have a Ryobi spinning reel SX4N,in excellent shape. Ineed to know how the springs go onthe bail to makr it work. Thanks
With the new line threaded through all of the fishing rod's eyelets, open the bail. You open the bail by pulling it over across the spool, until it locks in an open position. Tie the line in a knot around the reel's spool, and loosely wrap the line around the spool at least 7 to 8 times, then pull slowly on the line, to tighten the line that is wrapped around the spool.
Holding the box or spool of fishing line between your feet, so that it will remain close to you, start reeling in your casting rod. When you start reeling it in, the bail automatically closes, and makes the line wrap onto the spool properly. Reel the new line in until the spool is about 75% full, or to the lines marked inside the reel's spool. Cut the new line about 8 feet from the outer-most eyelet of your fishing rod.
Hope this solution has been helpful?
Jul 08, 2011 | Sport & Outdoor - Others
How do you get sides apart to lubricate the reel? I've taken the 3 screws out and handle off, but still seems like there is a hidden screw some where.
Look VERY carefully at the level wind, Usually from underneath. You should find something like a clip or tiny screw holding the tracking pin in place, (jewellers screwdrivers can be handy),
Aug 26, 2010 | Pinnacle Solene SLP10 Baitcast Reel
Cant cast the pinnacle platinum plus lp 100 fishing reel more than 15 feet because the line tangles. Any suggestions?
Aug 04, 2010 | Pinnacle Solene SLP10 Baitcast Reel
Bird nesting I think something is missing like a washer on the spool shaft under the cap and I don't know what should be there
common problem especially with new users who are used to fixed spool casting, when casting with a multiplier you should keep your thumb over the drum so you can slow down the drum as your cast slows to fall in the water, if you had a drag washer you wouldnt be able to cast, you will get the hang of it with practice, but even with 30 odd years of use i still ocaisionaly get a nest.
Jul 06, 2010 | Pinnacle Inertia Baitcast Reel
How do you put line in
Run your line through the guide and tie around spool using a good double loop knot
Oct 14, 2009 | Pinnacle Inertia Baitcast Reel
SHIMANO FISHING REEL
The drag is set by turning the knob which secures the spool to the reel.
To cast, hold the line against the rod with index finger on right hand. Then flip the bail open which frees the line to come off the spool. The bail, when it gets to a certain point will lock open. When casting, release your finger on the line when the rod gets to 11 o'clock.
Flip the bail back by turning the reel handle -- the bail will pop back over the reel -- then you're ready to reel it in.
The bail is the wire-like device on the top of the reel.
There is probably a button/switch for turning anti-reverse on & off -- when on, this keeps the reel from turning backwards when force is applied to the line.
I think those are the highlights.
Charlie
Sep 10, 2009 | Shimano REELS TYR20 Tyrnos Lever Drag...
Put string on tb425cs troy bilt trimmer
there are two ways to install the string..the cool way is without pulling the inner reel off the trimmer..just leave it in place..cut (2) approx.two arms length (thats spreading your arms out like airplane wings) of .095 string..now, align the arrow of the inner reel (it turns counter clock-wise..the arrow points outward) with the arrow on the outer spool (pointing inward)..holding the spool and reel together so the inner reel doesnt move, push one of the cut strings through the eyehole in the side of the outer spool, and it should come up to the right, through a slot next to a small round hole the diameter of the string..if it doesnt, it just missed the exit (as i call it)..pull out and try again..let about an inch come thru..now take that end of the string and push the line into the little round hole until it stops, which should be about a little more than 1/8 of an inch..hold it in while pulling the excess line outside the spool to keep it in place..now do the same with the other string for the other side..once you have both lines in place, turn the inner reel counter clock-wise to draw in both lines through the eyeholes of the outer spool..you may or may not get all of the line to wind in..not a problem..you will still have enough to do what you need to do..just cut off the rest..one problem you may or may not have that i do most of the tyme is that it gets hard to turn the inner reel..one solution is to bump the top of the 'bump knob' with your fist, then pull both strings at the same tyme, then continue to turn..this method is quicker and easier than the second way of having the inner reel out and trying to wind both lines at the same tyme and trying to place the reel back in the spool..hope this works for you...
May 10, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Pinnacle Solene SLP10 Baitcast Reel Logo
134 people viewed this question
Top Pinnacle Fishing Experts
Tom Chichester
Steve P
Steve P
ray gallant
Are you a Pinnacle Fishing Expert? Answer questions, earn points and help others
