Question about Samsung ML1740 Laser Printer
Within a couple of months, the printer started giving very light copies with broken letters
  • Samsung Master
  • 32,281 Answers
A low level toner will cause this fault. Try replacing the toner cartridge with a new one.
Posted on Sep 27, 2010
I just bought a brand new printer a couple months ago. It recently started only printing every other or every couple lines of print. If I type up a letter it will print one line and then skip a line. ...
Do a head cleaning at least 3 times and then print a test page and see what you get. Also in printer settings see if you are on "Default" or you changed it somehow........
Nov 26, 2013 | Epson WorkForce WF-2540 All-in-One Inkjet...
Getting black strip about 9/16"
it may be due to either malfunctioning of the scanner tube within the printer itself or whenever you copy a certain page the lid is not properly pace resulting to excess light on that side giving you black line when the copying is in process
Mar 06, 2011 | HP Officejet 5610 All-In-One InkJet...
Printer stops when printing should begin with red light in status
There is a few reasons that cause the status light to turn red, paper jam, paper empty, toner cartridge empty, cover open and waste toner cartridge full. The PC Smart panel utility should give you an exact fault condition. Hope this helps.
Jul 08, 2010 | Samsung CLP 300 Laser Printer
KP-51WS500 it started a couple months ago the
Hi, that is look like ,,you have defective convergence module if it is a dlp it is probly the light bulb,
hope that will help you to find a good tech
to fix it.
have a nice day
May 05, 2010 | Sony KP-51WS500 51" Rear Projection...
I need to know how old this dryer is Model 66814690 serial MG 1316480
The date of manufacture (month and year) are calculated by the first two letters of the serial number. The first letter being the month and the second letter is the year. The year letter code rolls over each 12 years so you have to know the age within 12 years. The link below will give you the guide to calculate.
Date Codes
Sep 23, 2009 | GE DWSR405EBWW Electric Dryer
Copies are light even with a new cartridge? The copier which our agency purchased within the past year began producing very faint ink print. We purchased a new cartridge and after installing today,the...
different models of copiers run different ways, some lasers write the white part of the page in others it writes the black. some machines use corona wires to charge the drum and some use rollers. Copiers are by no means a simple device, that is why they can cost anywere from a couple hundred dollars to half a million.
Jul 30, 2009 | Canon Office Equipment & Supplies
Letter after o broke
Go to start menu, accessories, system tools, character map. In here you can either copy and paste what you need or hold your mouse over a letter and it will give you a unicode command you can use to type that charater on your number pad.
May 28, 2009 | Sony VAIO Notebook
Prints faint copies
If the print rubs off the page, this means the toner is not being fused to the page. Fused......this is done by the fuser. This would have nothing to do with light print.
The dell (1600n and 1815n /1815dn) printer drivers has a toner saver mode, which can contribute to light print.
To turn Toner Save Mode off, (Windows XP) perform the following steps:
  1. Click the Start button, click Settings, and then click Printer and Faxes.
    The Printers and Faxes window appears.
  2. Right-click Dell Laser MFP 1600n, 1815dn, and left-click Printing Preferences.
    The Dell Laser MFP 1600n, 1815dn Printing Preferences window appears.
  3. Click the Advanced button.
    The Dell Laser MFP 1600n, 1815dn Advanced Options window appears.
  4. Click to highlight Toner Save.
  5. Click the drop-down list and change it to Off and click OK.
  6. Click OK.
One thing that you mentioned in your post "it takes the printer forever to warm up". The fuser does have to reach operational temperature in order for it to fuse the toner to the page. So it is possible that you are having fuser problems, because of the time it is taking for it to warm up. Another thing that can contribute to the warm up time is not plugging the laser printer directly into a wall outlet. This would be true for any laser printer, not just a Dell laser printer. The low voltage power supply is what works the fuser, along with sensors and other motors in the printer.
Replacing the fuser and or the low voltage power supply in this model of printer is not an easy task. If using a Dell branded toner cartridge and checking the toner saver mode does not fix the issue. Then you would be looking at more expense then the machine would possibly be worth.
May 04, 2009 | Dell 1600n All-In-One Laser Printer
Toner Low Light on within 2 months of replaced toner cartridge
Yields for cartridges are based on a page being only 6% covered. Most letters are about 10% coverage. If you print anything with lots of print (especially bold) your yield will reduce drastically. The same thing goes for pictures.
Nov 25, 2008 | Dell P1500 Laser Printer
Paper size detected is not supported when making a copy
When I saw that so many other people were also getting this error message, I thought sure there would be a solution posted by somebody before too long. Guess no one could figure it out!
The problem continued and was getting extremely irritating so I went and spent a couple of hours on HP's support site and finally figured out what to do, even though I never did find the exact error message we've all been getting.
Basically, the fix is to change the paper size default setting in the Copy Menu from Automatic to Letter. You do this by pressing Copy, then #6, select Letter (which is #2), and that will bring you back to the Copy Menu. Scroll down through all 10 selections until you get to the bottom which is Set New Defaults and select this.
I've tried making several copies and it has worked every time now...no error message in sight! However, if you're trying to make copies onto paper other than standard 8.5x11, you'll have to select that with each individual job since there will no longer be an "Automatic" detection.
Hope this helps everyone else who has had this annoying problem!
Nov 07, 2007 | HP Photosmart 3210 Printer
Samsung ML1740 Laser Printer Logo
70 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
