I wish to know if it is possible to boot an ASUS N61J from a HDdrive and/or a a USB key , connected to a USB port , and how to set up the Boot order of this laptop. Regards ,
  • 32,281 Answers
You can check this possibility by going into the BIOS configuration and go to the BOOT UP device order. If the USB port is available and you can change the boot order so that the USB port is the first boot device then you can boot up from a USB memory/flash device.
The normal boot up sequence usually allows the hard disk as the first or second boot device (the CD/DVD may be the first boot device). It does not matter if the CD/DVD is the first boot device, if there isn't a boot CD in the CD/DVD drive then it will automatically go to the next boot device usually the hard disk.
Posted on Sep 27, 2010
Asus got boot problem, it says check cable connection and PXE - MOF: exiting intel PXE ROM and smthn about atheros boot system please help
A PXE error typically means that the Boot Priority in the BIOS is set incorrectly and the computer is trying to boot from the LAN port.
Make sure that the hard drive (HDD) is the first boot device and the LAN port is the last boot device.
Atheros is the name of the Ethernet port driver.
See the discussion about Windows 7 and a solution for Windows 8 as well.
PXE M0F Check cable connection
Feb 11, 2015 | ASUS Computers & Internet
Usb boot
If you have set it to boot FIRST from the USB drive, I would suspect that your USB drive is not bootable. Either that or it is defective.
Another cause could be a bad USB port.
Apr 29, 2012 | ASUS Eee PC 904HD
The motehrboard bios doesnt boot from usb to install windows, how can i update the bios to boot from the usb?
Insert your USB jump drive into a USB port on the computer containing the bootable program. Copy the information to your jump drive, then insert the drive into a USB port on the computer you wish to boot the program from.
Power on the computer. When the computer begins displaying its startup information, hit the key indicated on screen to enter the computer's BIOS (the "F1" or "Delete" keys are commonly used to access the BIOS).
Browse through the menu options in the BIOS to locate the computer's startup and booting options to locate the "CMOS" menu, which is where you'll have the option to set which devices will boot at startup.
Browse though the list of bootable option---they'll be ordered as "First Boot Device," "Second Boot Device" and so on. Set the USB jump drive as the first bootable option---your BIOS may refer to the drive as a "USB Removable Floppy Disk."
Save and exit the BIOS. When your computer restarts, your program will boot first before your operating system.
Feb 17, 2011 | Intel QDI P2PE/800 Pro 82845PE Socket 478...
How to recover linux for EEE PC 4G
Simple, You need to get a USB - DVD Dongle, & your backup DVD that came with your unit. Inset the DVD, and boot of it, you need to access the BIOS and set the drive boot Up options, to boot from external USB connected, DVD, it MUST be all plugged in to show this. Then save settings and reboot. Follow instructions & then it will simply perform a complete restore. Now if you can't or don't want to use a USB-DVD, then you will have to make a Bootable USB Key, transfer the contents of the DVD to it and set to boot from that and do so, and install that way. There are a number of tutorial showing you how to do this.
look below...
http://eeepc-albkwan.blogspot.com/2009/06/create-asus-eeepc-system-recovery-usb.html
Feb 18, 2010 | ASUS Eee 4G Notebook
I'm trying to boot to USB from my P4P800 SE. The problem seems to be that I have to enable some type of emulation in the BIOS. Is there any way around this?
some bios are able to boot with the (f12) key and then you pick which device you wish to boot with otherwise you must enter the bios and set the first boot device to boot your usb
Dec 05, 2009 | ASUS P4P800 SE (890552603657) Motherboard
Boot usb cdrom a8n sli deluxe
Press Deleate key at boot enter bios goto boot settings set 1st boot devise as usb press F10 and enter to save changes
Nov 14, 2009 | ASUS A8N-SLI Deluxe Motherboard
USB MOUSE x PC BOOT
Could be a problem with your system BIOS, enter the setup while your computer is booting (before it gets to windows) by hitting the F12 key probably. Make sure that the boot order is HDD first, not something else.
Aug 31, 2009 | Laser LX710 Keyboard and Mouse
Boot system from external hard-disk with USB2
You can check the bios and make sure that it is set to boot from USB. Turn computer off. Turn back on and immediately press F2. This will get you into the BIOS. Look around and find boot properties. Set the boot first to USB. If you do not see the USB option, then your motherboard doesn't support the boot from USB option.
May 09, 2009 | ASUS P5GD2 Deluxe Motherboard
On startup my keyboard doesn't work
Hello iko_gan,
This is actually a problem with USB Keyboards, Make sure that your BIOS is set to boot with USB making USB part of the boot sequence as opposed to an OS driver driven function, and if possible use the USB 1 port and not the USB 2 port. USB 2 is more suited for Hard drives. and why use all of your USB bandwidth for your key board.
This helped me solve my problem in this area.
Shuttle83
http://www.electron-age-technologies-llc.com
Mar 28, 2009 | Computers & Internet
Annot boot with printer connected via USB ASUS P5B
While booting press whatever key or combination required to enter BIOS setup and find the boot section. Disable USB from the boot devices list.
Dec 07, 2008 | ASUS Computers & Internet
Computers & Internet Logo
433 people viewed this question
David Payne
David Payne
