Question about LG Dishwashers
I've just bought the new LG Direct Drive, the problem is when I put it on ECO cycle it takes 3hrs 28 min to complete a cycle. Is this normal, I was under the impression a cycle should be about 30 min
  • LG Master
  • 17,130 Answers
Make sure that the water inlet pressure is good and there is no restriction ,
Now it is normal that the wash cycle is long as the dishes are put into and set to be done overnight.
But it will be good to clarify if the ECO wash takes so long as 31/2 hours, which could be fine with a high level wash.
Call LG Dealer to confirm as the set is new.
Posted on Sep 27, 2010
Why does my LG WM1814CW's timer get stuck during cycles, A 28 Min cycle will take 45 Min.
It could likely be that this is during a fill portion of the wash or rinse cycle, and the water inlet is restricted not allowed the full flow into the tub. If this is the case, check both ends of the hose connections for a plugged / restricted filter. run some water into a container with hose off to purge any additional minerals from the intake.
Jun 16, 2014 | LG WM1814CW Front Load Washer
HOW DO I RESET MY WASHING MACHINE IT IS STUCK ON 28 MINS
Hi. is it stuck on the rinse cycle & won't move on,
Is your machine an IW Eco intuitive Q.
Please let me know your machine model.
Feb 03, 2013 | Fisher and Paykel Washing Machines
Front loader machine stuck before spin cycle
This is an issue with the pressure switch, it is having issues detecting the water level.
Mar 11, 2012 | LG Washing Machines
LG washing machine direct drive when i put it on it washes and goes down to 9 mins then stops, sometimes an error code comes up UE? CAN U HELP PLEASE
It means Unbalanced Error, it means the machine cant balance the load during the spin cycle, normally happens if there is too little a load i.e 1 or 2 things or overloaded. It is designed to protect the bearings. If it happens with a normal load try stopping it and re-arranging the load by hand and putting it on a spin only cycle. Hope this helps.
Feb 28, 2011 | Washing Machines
My Maytag Neptune FAV6800AW top load washer only runs for the first few minutes of the cycle, it will not spin..it just stops..we've tried two cycles, the quick wash...it starts at 33 mins and then stops...
I'm and owner and will try to help. Are you handy and do you want to try a DIY fix?
From the wash times is sounds like the washer is agitating the wash load (tumblers are rotating the wash basket load) is that correct?
If so see if the machine will complete a Spin Only cycle with no clothes in the wash basket. Set the Spin setting to Spin/Hang dry seting and start the cycle. It should take about 10 min complete. Does the Spin Only cycle complete with no clothes in the wash basket?
Some handy links if you are going to DIY.........Service Manual for reference.
Sep 17, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Works fine when under the light but stops when I wear it.
Your capacitor will needs to be replaced. This usually has to be done about every 5-8 years.
Sep 18, 2009 | Silhouette Citizen Eco-Drive Watch
My 32" LG takes about 3hrs to get a picture when turned on
Most likely you have capacitors in the power supply that have dried out or as we say vented. If your handy and want to replace the power supply I suggest " Shopjimmy.com ". If not, then take into your local service center for an estimate first.
Jun 07, 2009 | LG 32LG30 32 in. LCD HDTV
Eco Drive Titanium
Put watch in direct sunlight, in a window for 8 hours. If battery indicator shows the watch is fully charged then you may need to look at what mode your watch is in.
Nov 09, 2008 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Time remaining stays at 1 min for 20 min
This may happen if using the Super-eco program.
It is designed to extend the washing time / cycle, but is less intesive in rotations. It's more a long gentle soak than a quick scrubbing action.
Thank you for using Fixya! If this provided a solution, please rate as such. Thanks.
Jan 03, 2008 | Maytag EPIC MFW9700S Front Load Washer
Dishwashers Logo
205 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
