My notebook will shut off when i take my adapter off or with out it,what do i do?
  • lovejacquita Sep 27, 2010
    the battery is working fine.
  • 17,130 Answers
You battery is bad and needs to be replaced. Cheeck the voltage at the terminals of the battery with the adapter switched ON.
If present and good , then the battery is bad as it is not charging.
Posted on Sep 27, 2010
My laptops shut down when i put the adapter and doesn't get start up , but it's work normally with betray
Problem description:The laptop shuts off when AC power adapter is plugged in. The laptop works fine on battery power but as soon as you connect it to AC adapter, the laptop turns off.
Possible cause:1. Power adapter failure.
2. Motherboard failure.
Possible troubleshooting steps and repair solution:First of all, test the power adapter. Make sure the adapter outputs correct voltage. It's possible that the output voltage is not correct and the laptop shuts down to prevent the damage. Test your laptop with another known good power adapter.
If the problem still exists, even after replacing the adapter, most likely it's the motherboard failure. Replace the motherboard.
Reference: http://www.chargerbuy.com/blog/laptop-shuts-off-when-ac-adapter-plugged-in/
Sep 13, 2011 | Toshiba Satellite M205-S4806 Notebook
My battery is set up to charge to 80%. How to I change it to charge a 100%?
It possible that you battery needs to be calibrated. Here are some steps that may help resolve this issue:
  1. Connect the AC adapter and allow the battery to charge to 99% - 100% of capacity.
  2. Disconnect the AC adapter from the notebook PC.
  3. Click Start , enter power in the Search field, and then selectPower Options from the list.
  4. Select Create a power plan from the left sidebar.
  5. Click in the Plan name field and type Calibrator . Then, press Enter .
  6. Select Never for all topics in the On battery column.
  7. Click Create to accept the values and force the battery to consistently discharge.
  8. Allow the battery to discharge completely until the notebook PC shuts down.
    9. Connect the AC adapter and restart the notebook PC.
    10. After calibration, return to the Power Options dialog box (Step 3) and select your default power plan setting.
  9. After calibration, return to the Power Options dialog box (Step 3) and select your default power plan setting.
Jul 11, 2011 | Computers & Internet
Shut down note book HP ZE5270 AFTER 1 HOUR
Change the settings in your control panel = power control or supply.
Good luck.
Mar 01, 2011 | HEWLETT-PACKARD Pavilion Ze5270...
Lenovo y410 laptops turns off suddenlty while using it for long hours
hi
is the computer dissipating excessive heat from bottom ? is the heatsink fan working (is it blowing out air from fan on the side ? if not, then replace the heatsink fan. This shut down occurs to advise you that something is not working well , and to avoid damage to the CPU and/or mainboard, its letting you know that.
if the fan is working fine-- are you on the computer while the AC adapter is NOT plugged in ? Are you fully charging the battery before you use the notebook without the AC adapter ? If you are NOT using the AC adapter, running on battery life only, then do this : shut down the notebook, disconnect the power adapter, remove the battery back up from rear of notebook.
reconnect the AC adpater and start the computer -- perform normal function on the computer, run it and work with it for a few hours. if the same issue occurs, (unwanted shut down) , then perhaps the AC adapter is faulty, which is not charging the battery to full capacity.
let me know what happens-- i'd appreciate your feedback w/o receiving bad rating
Nov 15, 2010 | Lenovo 3000 Y410 Laptop
Was working on computer, it shut off. Now it will not power back up. Hp want to charge me to fix problem over the phone
Please try with this steps :
1. Disconnect the AC adapter and remove the battery from the notebook .
2. Press and hold the Power button for 30 seconds.
3. replace the battery and connect the ac adapter
4. turn On the notebook and check
Jun 13, 2010 | HP Pavilion dv8000t Notebook
C700 laptop's display problem
I have the same issue.
Problem appears only while working with power adapter.
When I turn off power adapter (so notebook is working with battary) everything is OK.
It is somehow connected with shutting down. If disconnect power adapter durring shutting down - next time you will have problems with grey screen.
Don't know how to fix it.
Usually solve by making several reboots and to turning on/off power adapter.
Apr 23, 2010 | Compaq Presario 700 470024-192 Notebook
Notebook keeps shutting off even with the adapter plugged in
The most common problem for PC's shutting themselves off is due to heating issues. I would check the vent holes on the computer and ensure that they are free of dust. You can turn the comptuer off and use your vaccum to clear the vent holes or better yet use compressed air (available almost anywhere) and blow out all the air. I do have one question though, does your laptop work when it is not plugged into the AC adapter?
Jul 29, 2009 | ASUS Eee 4G Notebook
Lenovo 3000 N200
sounds like the mother board maybe on its way out - is it under warranty?
Jul 24, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Notebook cannot power up
Any lights on the A/C power adapter ?? If not, then the power adapter is faulty. If the adapter is OK, the power connector on your Lifebook is faulty. Good luck
Jun 21, 2009 | Fujitsu Siemens LifeBook E4010 Notebook
When ac is plugged in the power light blink & notebook unresponsive
Sounds like your ac adapter (brick) is bad and not supplying correct voltage/amperage.
Apr 03, 2008 | Toshiba Satellite 2805-S603 Notebook
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
