Question about Dual Presidian DVD Recorder
Error message e-25 this program is not allowed to be recorded
I have a dvr from direct tv , i have a presidian 16-163. i have been recording
craft shows to dvd, all of a sudden i started getting these error messages.
i hooked up a zenith recorder ang get the same message, this a just regular cable shows.
thank you
bev.bbonita@netzero.net
5 Suggested Answers
SOURCE: I HAVE A 4 YEAR OLD PRESIDIAN DVD/RECORDER. I CAN
I SHUT THE CONVERTER BOX OFF BEFORE TRYING TO START RECORDING
Posted on Oct 01, 2009
SOURCE: presidian dvd recorder pdr 3222
10 lbs sledge
Posted on Apr 12, 2008
SOURCE: Presidian PDR 3222 not recording when record button pressed
I am beginning to think the machine works with slower discs but a firmware update will enable the machine to function with the newer "16x" and other discs. Unfortunately, neither Presidian nor the "real" manufacturer (whose name slipped my mind) seem to currently have the update available on their web sites.
Posted on Sep 28, 2008
SOURCE: I have put a dvd to record but it says disk error, what can I do?
Cleaning lens (manually) seems to have worked. But, I'm still irritated about having so many unnecessary variables to deal with. The pattern is clear and long. And the landfills are full of hard working people's money.
Posted on Jan 22, 2009
  • 9 Answers
SOURCE: I have a presidian dvd recorder, that i haven't
You likely have two video input options, s-video and composite (also known as RCA or A/V). All you need to do is change which connector your using in the settings. Look for a button on your remote that says SETUP or OPTIONS. Once you push it, you should get a settings menu. Look for something like REQUIRED SETTINGS or SYSTEM SETTINGS. Play around with it, and you will find the option to select between the connectors.
I hope this helps! :-)
Posted on May 03, 2011
How to connect Presidian DVD Recorder Presidian DVD Recorder 3222 directly to TV
I need to know this too, I have a picture but no sound, I've tried every hok up that I can think of
Mar 08, 2013 | Televison & Video
How do you hook recorder up to tv and dvr cable box
Simple. Connect the composite output from the VCR to the composite input on the back of the Presidian. Then connect the coaxial output from the back of the DVR to the coaxial input on the back of the Presidian. Then connect the coaxial output from Presidian to the coaxial input on the back of the TV. Turn everything on and enjoy! :-)
Jan 05, 2011 | Dual Presidian DVD Recorder
I have a Pioneer DVR5100H which was set up to record Analogue programs - can I change the set up to accept digital programs. I have tried auto setup but it doesn't pick up any programs?
You can't record digital programmes with this recorder unless it is connected to a digital tuner, e.g. a Freeview box or Sky digibox. This recorder has a built in analogue tuner which allows it to record analogue transmissions. Recorders which can record digital transmissions have a built-in digital tuner and usually have a DVB logo (actually looks more like DV3) on the front.
If you want to record digital programmes using this recorder, you need to connect it to a Freeview or Sky digibox, preferably with a scart cable. It is not sufficient to connect it to a TV with a digital tuner or built in Freeview as the player does NOT record directly from the TV, it must be connected directly to the transmission source. A basic stand-alone digital tuner (Freeview box) can be bought for as little as £10-15.
Regards,
BElectric
Nov 18, 2010 | Pioneer DVR-5100H DVD Recorder
LOST MANUAL
Go to direct Navigator on remote or functions it will lead you into step by step directions for recording and programming the dvr remember you must hook up a digital tv tuner because the dvr is analog and will not record tv.
May 30, 2010 | Panasonic DMR-E85H DVD Recorder
Sep 30, 2009 | Dual Presidian DVD Recorder
I have an error 25 on my dvd recorder
Technically, E25 is a copy-protection error, but I have some additional background on this issue. On the one hand, it could be a legitimate copy-protection error - you are trying to record from a copy-once or copy-protected source - this is especially true if you are trying to record from a Cable/Satellite Box that has a DVR box - since copying to the DVR is considered the first "copy," the Magnavox will not allow you to make a "second" copy.
On the other hand, Magnavox/Funai players see all programs recorded in V mode (as opposed to VR mode) as "copy-prohibited". It records all +R discs in VR mode automatically, so the solution in this case would be to record on a compatible -R disc (or vice versa).
There are two simple fixes for this issue in either case:
1) If you are using a +R disc, switch to a -R disc. If you are using a -R disc, switch to a +R disc. Simply switching the disc type will "fix" Magnavox recorders (long story).
2) If your TV has a "Video Out" or "Monitor Out" (most TV's don't), you can connect a yellow video cable from the OUT of the TV to the Video IN on the back of the Magnavox. This will permanently resolve your problem by fooling the recorder.
Here is additional info about the type of disc to get:
IDiscs that have been tested and are proven to be compatible with this recorder:
VERBATIM DVD+R 8x, VERBATIM DVD+RW 4x
VERBATIM DVD-R 8x, VERBATIM DVD-RW 2x, MAXELL DVD-R 16x, JVC DVD-RW 4x
IWe strongly recommend for good recording quality:
TDK DVD+R 4x/8x/16x, SONY DVD+R 4x/8x/16x, MAXELL DVD+R 4x/8x/16x, SONY DVD+RW 4x,
MAXELL DVD-R 8x/16x, MAXELL DVD-RW 4x
Good Luck!
-Tha Mp3 Doctor
Feb 01, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Panasonic DMR-ES30v Combo- Message of "Check disc for error"
Pay TV in Australia will record "no problem" BUT BUT when it is a pay per view or Box Office etc it will be blocked in a similar way as Macrovisin that is recognized in the encoding of the recording device that the signal is passing through. The result point blank displayed you are not allowed to record this program or it is blocked or distorted part of the way through the recording etc...
Dec 31, 2008 | Panasonic DMRES30V DVD Recorder/VCR Combo
Jul 01, 2008 | Dual Presidian DVD Recorder
i have a presidian dvd recorder and when i put in
a new blank dvd-r disc it only gets it prepared up to
21% and tthen it stops and opens
Nov 25, 2007 | Emerson EWD7001 DVD Player
Televison & Video Logo
756 people viewed this question
Top Dual Televison & Video Experts
Jonathon summesfield
Are you a Dual Televison and Video Expert? Answer questions, earn points and help others
