Question about Samsung DVD-P244 DVD Player
My samsung DVD player stops playing a movie after a few seconds of play but the fast forward play is normal Why?
bananaman
  • 10 Answers
SOURCE: samsung dvdr-120
try checking on the recording mode of the DVD. V recording mode produces more compatible DVD disc. Stay away from VR mode. You may refer to your manual.
Posted on Sep 12, 2007
peepnklown
  • 175 Answers
SOURCE: Play divx movies
Usually, DVD players that play DIVX are very specific on which version it will play; you might want to check this link out: https://vod.divx.com/how/
Oddly enough the P350H manual says nothing about DIVX playback.
Posted on Nov 10, 2007
  • 31 Answers
SOURCE: doesn't read dvd's
This problem is down to failure of the laser and an only be solved by replacing it. Samsung are aware of this fault but will only offer a free replacement if the unit is still covered by it's warranty.
They do offer a replacement service but charge £94 for it.
Posted on Mar 06, 2008
SOURCE: SAMSUNG DVD RECORDXER 120
Do you mean rso on the payer? You should have a button on the front of the dvd maked rso, press this three times to cancel the rso,it should then play.I hope this helps. Jamie
Posted on Mar 02, 2009
SOURCE: Samsung DVD-SH853M HDD/DVD Recorder/Digital Receiver
Make sure you are not using DVD+R dics - the player won't play these. It is OK with DVD-R.
Posted on Jul 02, 2009
How to bypass cinavia on my samsung BD-H5100
You can't bypass it...............
Nov 06, 2014 | Televison & Video
Cassette is stuck. Cannot eject
Sounds like the tape is dragging and the spindle wont release it because of the torque on it. Can you rewind or fast forward to see if it releases?
Sep 09, 2012 | Samsung DVD-V4600 DVD Player/VCR
The VCR shuts off after just a few seconds of playing or rewinding or fast forwarding. The tape goes in, and when you push play (or any direction), the unit will try and play it and then it will shut the...
There is a part that is called an idler wheel assembly that is critical for play, rewind, and fast forward, and may have stopped working. The second possibility is that the drive belt that runs the idler assembly has broken or come off.
Jan 01, 2011 | Philips DVDR3435V/37 DVD Recorder/VCR
I bought a Samsung BD-C6500 to play MKV movies, it does, but the player stops right in the middle of the movie, so I have finish watching on my computer. Any solution ?
It sometimes does it on certain Mkv movies you will notice it will be the ones you cannot fast forward ,it does it on 2 of the other players try it from the begging
Oct 30, 2010 | Samsung BDC6500 BluRay Player
I have bought samsung dvd player h1080 and it seems that it is region 1 how can i make it region 2. thanks
After searching the best known region hack databases I have found one process for your make and model. I can not assure you that it will work 100% but it's the only known process.
Turn on the Player with no disc on the tray. The tv screen and the dvd lcd will display "No Disk"
2. Press the "Repeat" key on the Samsung remote control
3. Press the keys: "5 7 5 3 8" on the remote. Number 2 appears on the screen for a short time.
4. Press "9". Number 9 is displayed on the screen.
5. Press the "Open/close" button in the remote. The tray will open. Leave it open for a few seconds.
6. Just press the "On/off" button in the remote.
7. You now have a multi-region dvd player!!
I hope this works for you, thank you for choosing Fixya!
Aug 29, 2009 | Samsung DVD-H1080 DVD Player
Sound and video playback do not match
No button or any control to rectifier this problem. Depend the movies quality when you fast forward the system control and audio video processing or it call out MPEG2 chipset they run like double speed sometimes it not fast enough then you end up with sound and video not SYNC however you can fix that by remove AC lead for 30sec then plug in back now it should work OK or when you fast forward use X8 or X16 NOT X32 times specialy with DVD copy
Alternatifly if your DVD player still under warranty it might have a update firmware to correct this problem
Cheers
Nov 01, 2008 | Philips DVP5140 DVD Player
Jsi js4110
The only operations available on the JSI JS4110 without a remote are play, pause, stop, and eject. Since this DVD player "remembers" position of the movie, a different DVD would have to be inserted and played to start that movie over from the beginning. As for fast-forward, this is only available with the remote.
May 13, 2008 | Philips PM3S Remote Control
Panasonic DVD-S47
There are DVD players that have a feature that automatically skips the menu and plays the largest title on the disc (typically the movie). It's usually not an advertised feature. maybe pressing "play mode" on the remote can fix that. Since you're having more problems, it will probably take more then disabling that feature, or you might be looking at 2 separate issues. What happens if you take the battery out of the remote? does that stop it? and what happens when you press FF on the player itself? this should tell you if the problem is specificaly with the remote, or with the player itself. Best thing to do though is use the warranty if its still valid, or consult the shop on repair options. Good luck
Mar 22, 2006 | Panasonic DVD-S47 DVD Player
Samsung DVD-P244 DVD Player Logo
54 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
