Question about Caterpillar Electrical Supplies
What can cause a low fuel pressure alarm, and a incorrect actator position alarm on a 3500B gen ste. Tahk you. Clay
    Prodigy:
    An expert who has answered 500 questions.
  • Caterpillar Expert
  • 573 Answers
Low fuel pressure under load will cause a shutdown but will cause the governor actuator to hunt before it does shut down, check presssure and demand regulator
Posted on Nov 17, 2013
2010 CRV, just shy of 30,000 miles. Will not start. Has been in the repair shop 4 times in 7 or 8 months. New Alternator, new battery. What is causing this???
has there been any fault codes reported or has anybody bothered reading the fault codes
reasons for not starting include
cam/ crank position sensors--- broken wiring , faulty harness connections, sensor position adjustment incorrect
low fuel pressure --- pressure regulator problem, fuel pump relay problem, fuel pump
immobilizer problems --- fob battery low on charge , problem immobilizer system
ignition control module--- wiring , faulty internal components
gear position switch---park or neural out of adjustment--wiring problems
a battery may be causing the problem--- but check ground points for tight and clean-- if you are saying that occasionally it will not start, it could be a problem starter motor with a bad commutator bar
it has been back for a number of times but the replaced items indicate that the shop is using a replace parts to find the problem rather that a fault code systematic approach to trouble shooting and problem solving
might pay to find an accredited service shop with experience on your make of vehicle
Jan 10, 2017 | Honda CR-V Cars & Trucks
Received a P219a code read out for my 2012 toyota corolla what can I do?
P219A - Bank 1 Air/Fuel Ratio Imbalance
Possible causes - Leaking or contaminated fuel injectors - Low fuel pressure or running out of fuel - Leaking evaporative emission (EVAP) canister purge valve - Exhaust or intake air system leaks - Exhaust gas recirculation (EGR) system - Positive crankcase ventilation (PCV) system is leaking or the valve is stuck open - Ignition system - Incorrectly seated engine oil dipstick, tube or oil fill cap
Dec 23, 2016 | 2012 Toyota Corolla
Replace or remove cat.
Possible causes
- Intake air leaks
- Faulty front heated oxygen sensor
- Ignition misfiring
- Faulty fuel injectors
- Exhaust gas leaks
- Incorrect fuel pressure
- Lack of fuel
- Faulty Mass Air Flow (MAF) sensor
- Incorrect Positive Crankcase Ventilation (PCV) hose connection Help with this Tech notes
If the P0171 is combined with the P0174 code, it's very likely that the problem is caused by an intake leak. If there are no intake leaks, the next step is to replaced the air filter and clean the air flow meter. If the problem persist the front oxygen (O2) sensor may need to be replaced.
The P0171 code could also be caused may be caused by one or more of the following: debris on MAF sensor causing an incorrect reading, improper oil level, low or high fuel pressure or Engine Control Temperature (ECT) Sensor reading inaccurate.
Read more: http://www.helpforcars.net/obd_codes/p0171_chevrolet.html#ixzz3tjvehfyV
Dec 08, 2015 | 2004 Chevrolet Avalanche
Ford engine codes p1132 1152 p0316 p0712 p0301
P0316 is Potential Causes Potential causes of this misfire code may include: Damaged or defective Crankshaft Position Sensor (CKP) CKP sensor wiring or connector fault
Read more at: https://www.obd-codes.com/p0316
Copyright OBD-Codes.com Common Problems That Trigger theP0301
  • Worn out spark plugs, ignition wires, coil(s), distributor cap and rotor (when applicable)
  • Incorrect ignition timing
  • Vacuum leak(s)
  • Low or weak fuel pressure
  • Improperly functioning EGR system
  • Defective Mass Air Flow Sensor
  • Defective Crankshaft and/or Camshaft Sensor
  • Defective Throttle Position Sensor
  • Mechanical engine problems (i.e.-low compression, leaking head gasket(s), or valve problems A code p1132 Possible causes - Faulty Upstream Oxygen Sensor Bank 1 - Fuel pressure high or low - MAF sensor dirty/defective - Vacuum leak on engine - Leaking fuel injector or fuel pressure regulator - Faulty Powertrain Control Module (PCM)
    Read more: http://www.autocodes.com/p1132_ford.html Try you tube !
Jul 22, 2014 | Ford Taurus Cars & Trucks
Lost instruction manual for G Shock 3500B and forgot how to reset alarms............can you help..
Try this web site:
http://www.casio-europe.com/euro/watch/gshock/gw-3500b-1aer/
or:
http://forums.watchuseek.com/f17/gw-3500b-1a-owners-519105.html
Jan 20, 2013 | Watches
No power from engine
P0174 DODGE - Fuel System 2/1 Lean fuel mixture
Possible causes- Intake air leaks
- Exhaust gas leaks
- Lack of fuel
Nov 07, 2012 | 2004 Dodge Ram 1500
Scanned my computer , came up with a PO 171 and 174 what does this mean?
P0171 AND P0174
P0171 - System Too Engine Cylinder Lean Bank 1xicon.jpghttp://engine-codes.com/p0171.htmlForum CodePossible causes- Intake air leaks
- Exhaust gas leaks
- Lack of fuel
- Incorrect Positive Crankcase Ventilation (PCV) hose connection Tech notes Dirty air filter of faulty air flow sensor are common causes for the P0171 code of the problem.
P0174 FORD - Fuel Injection System Too Lean Bank 2xicon.jpghttp://engine-codes.com/p0174_ford.htmlForum CodePossible causes- Intake air leaks
- Exhaust gas leaks
- Lack of fuel
- Incorrect Positive Crankcase Ventilation (PCV) hose connection Tech notes The codes is usually set when there is an intake leak after the air flow meter, before replacing any parts check for loose or broken hoses and intake gasket leak. On Ford some models dirty air filter, and dirty or faulty air flow sensor are the cause of the problem.
Jul 27, 2012 | Cars & Trucks
Sputterin loses power at 35mph
Possible causes:
Clogged fuel filter Low fuel pump pressure
Defective Catalytic converter Defective EGR valve
Incorrect fuel pinched/kinked fuel line
Malfunctioning Throttle position sensor Defective MAP sensor
Vacuum leak
...if your check engine light is flashing, then you are burning excessive amounts of gas which would indicate a rich condition.
Aug 26, 2011 | Jeep Grand Cherokee Cars & Trucks
VERY ROUGH IDLE NO EXCELERATION
Try a few if these ideas...
Priority Action Part Type Cause
1 Inspect Spark Plug Fouled, Damaged, or Broken Spark Plug(s).
2 Inspect Hose (PCV) Clogged or Collapsed PCV Hoses.
3 Inspect Wireset Worn, Damaged or Faulty Spark Plug Wire(s).
4 Inspect Distributor Worn, Damaged or Faulty Distributor.
5 Inspect Catalytic Converter Clogged or Faulty Catalytic Converter.
6 Inspect Fuel Pump Low Fuel Pressure.
7 Inspect TimingSet Slipped TimingChain or Worn TimingGear(s).
8 Inspect Knock Sensor Improperly Connected or Faulty Knock Sensor.
9 Inspect M.A.P. (Manifold Absolute Pressure) Sensor Faulty M.A.P. Sensor.
10 Inspect Throttle Position Sensor Faulty or Incorrectly Connected Throttle Position Sensor.
11 Inspect Mass Air Flow (MAF) Sensor Damaged, Loose, or Faulty Mass Air Flow Sensor or Circuit.
12 Inspect Air Cleaner Temperature Sensor Damaged or Faulty Air Cleaner Tempature Sensor.
13 Inspect Fuel Injector Pressure Regulator Faulty Fuel Injector Pressure Regulator.
14 Inspect Piston Ring Set Worn or Broken Piston Rings.
15 Inspect Timing Specification Incorrect Ignition Timing.
16 Inspect Fuel System Pressure Incorrect Fuel Pressure Being Delivered to Carburetor or Fuel Injection System.
17 Inspect Fuel Filter Clogged or Dirty Fuel Filter.
18 Inspect PCV Valve Plugged or Damaged PCV Valve.
19 Inspect Valve Burned, Worn, or Sticking Exhaust Valves.
20 check idle stop solenoid - if faulty, could cause rough idling
21 inspect distributor cap/rotor - if burnt, could cause loss of acceleration
Apr 18, 2011 | Chevrolet Cavalier Cars & Trucks
2002 Interpid 2.7 L died on road now no start!
sounds like a bad ecm aka computer to me.have ecm checked
Aug 15, 2009 | 1999 Dodge Intrepid
Electrical Supplies Logo
121 people viewed this question
Top Caterpillar Electrical Supplies Experts
gbob59
Lawrence Oravetz
ray gallant
Are you a Caterpillar Electrical Supply Expert? Answer questions, earn points and help others
