Question about HP Computers & Internet
I have altec lansing speakers, however, the song keeps cutting on and off when playing youtube. I have an hp special edition (not very new)
    Sergeant:
    Champion:
  • 214 Answers
the songs keep cutting ON and Off because of your slow Internet Connection.
You can download that song first then Listen. It will be work perfectly fine.
With regards
FIXYA team
**Please post your feedback and Vote if the problem resolved as per your satisfaction**
Posted on Sep 27, 2010
I need a software so i can use my new altec lansing atp3. i lost my cd.. please help.
According to the manufacturers site these speakers are plug n play so you shouldn't need drivers. What sort of software do you require?
Mar 20, 2011 | Altec Lansing ATP 3W Computer Speakers
Keeps shutting off on its own
I am having the same problem. It appears to happen more on low volume does that happen to you as well? I just called Altec Lansing. Mine may be under warranty still.
Altec said it may be the pins are bent slightly. Not sure i agree. One way to test is to hook up via the auxillary port and see if it still cuts out.
Jul 10, 2010 | Altec Lansing Inmotion-IM600...
Only one speaker works - altec lansing computer speakers ADA215
The solution is actually quite simple, due to a design flaw. Altec lansing designed a rather cheap mini din plug-in which can either be replaced or repaired depending on your skill and patience level. Your ground contact is fine BUT the positive contact is not making connection due to the fact that the plastic housing has broken away and pulled the contact with it. This can be super glued back into place or just replaced with a new mono minidin plug-in.
Mar 09, 2010 | Altec Lansing ADA 215 Computer Speakers
My altec lansing ATP3 right satellite speaker cannot operate...
Speaker is bad or the cable may have come loose. Has it been knocked around? If so it may have pulled the cable loose inside the speaker, try playing a song and wiggle the wire and push the wire in gently to see if it starts to play if it does you have found your problem. If not then the speaker is bad and I don't remember if you can pull it apart and buy a new speaker to install in it. Thanks for using Fix-ya and if this helps please rate this free question.
Avid101
Aug 20, 2009 | Altec Lansing ATP 3W Computer Speakers
Altec Lansing VS 4121
It is unlikely that this is a problem with your speakers more likely that it is a problem with the DVD player itself. I would recomend trying another DVD player.
Regards, Andrew
Sep 17, 2008 | Altec Lansing VS4121 Speaker
No sound
check the plug that goes directly to the altec box. or it could be the wire is the culprit..
Apr 08, 2008 | Altec Lansing VS4121 Computer Speakers
Altec lansing
I had the same problem. After numerous calls to Altec Lansing they sent me out a new one. The new one doesn't have the same connector on it. I called tech support only to hear that they discontinued the 621 and don't make parts for it. Sorry, you are probably out of luck.
Oct 26, 2007 | Altec Lansing 621 Computer Speakers
Altec VS4221 not working with Gateway
I am guessing that the speakers our connected to the input port.. make sure it not plug on the input port...
Jun 16, 2007 | Altec Lansing VS4121 2.1 Channel Powered...
Computers & Internet Logo
97 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
