TM 9-1005-213-23&P - Computers & Internet
What's the best tyre pressure for tm 125 mx?
2002 TM Racing MX 125 Tire pressure - Questions - Fixya
www.fixya.com > ... > TM Racing > MX 125 > 2002 TM Racing MX 125
Free help, troubleshooting & support for 2002 TM Racing MX 125 tire pressure related topics. Get solutions for 2002 TM Racing MX 125 tire pressure related ...
Sep 10, 2015 | Motorcycles
I play Words with Friends free but I want to buy the "no ads" game. How do I do it? Will I lose all the current games I'm playing or will they transfer from the free game to the other?
Yes, all your progress will be safely transferred if you remove ads.
If you are playing on iPhone/iPod/iPad all you need to do is download the premium version to remove the ads between turns.
http://zynga.tm/3yF <--- for iPhone & iPod Touch
http://zynga.tm/3yE <--- for iPad
If you are playing on Android you need to:
1) Open Words with Friends
2) Open the "Menu" and then tap on "Store"
3) Once the Store is open, find the "No More Ads" item.
http://zynga.tm/3yF http://zynga.tm/3yE
Jul 06, 2015 | Video Game Consoles & Games
I have a EPSON TM-T88III running off WINDOWS 7 professional. I have upgraded from WINDOWS XP. MY CASH RECEIPT PRINTER IS NO LONGER PRINTING CORRECTLY. The printer is gone slow MY Fonts print croo
Go to Control Panel - Device Manager & find your Printer i.e. little arrow by the Imaging devices. Right click the T88 & click upgrade drivers, then clik the upper choice & it will go to Microsoft & find the correct driver for that unit & install it. (must be on line) That should solve your problem If not call Epson
I’m happy to help further over the phone at https://www.6ya.com/expert/wynn_5ba0205233ebfc15
Dec 14, 2014 | Epson TM-T88III Thermal Printer
Epson tm t81 can not gives test print and shows state is invalid
If epson tmt 81 is not printing test page then check for dip switch below the printer and also reinstall the printer driver & configure the port properly
Oct 02, 2013 | Epson TM-T88III Thermal Printer
I need drivers
Here is the driver link
http://www.barcodesinc.com/resources/APD_407EWM.exe
Download it & install it.
Dec 17, 2009 | Epson TM-T88IV Thermal Printer -...
TM-T88III print speeds and other issues
Try setting both switch 1-7 and 1-8 to ON for 38400 baud, set switch 1-2 to OFF to give a 4k buffer, set switch 2-5 to OFF to release the busy buffer at 256 bytes, set switches 2-3 and 2-4 to ON & OFF for medium print density and OFF & ON for dark print density or OFF & OFF for normal print density.
Also remember that the thermal TM-T88III also prints faster when the print head is cooler and slower when it heats up. The print speed is adjusted automatically depending on the voltage applied and head temperature. So make sure your power supply is providing a steady 24VDC at full load and has enough capacity to provide a peak of 7.7A in full speed mode. If you are using the printer in high temp and humidity you might want to swap the unit out for a Star Printer which performs faster and uses the same protocol or use a cooling fan.
Also make sure you use a good quality paper and that the humidity is within range at 10 – 90% RH although the paper performance will be greatly diminished at higher humidity levels.
Specifications:
High-speed = Approx. 150 mm/s {5.9"/s} max.; 47.2 lps, max. (3.18 mm {1/8"} feed);
35.5 lps, max. (4.23 mm {1/6"} feed, at 24 V, 28°C {82°F}, density level 1).
Low-power: Approx. 16.5 lps (4.23 mm feed {1/6"}); 70 mm/s {2.76"/s}
Ladder bar code: Approx. 42 mm/s {approx. 1.7"/s}
High-speed mode: Mean: Approx. 1.8A Peak: Approximately 7.7A @24VDC
Low-power mode: Mean: Approx. 1.2A Peak: Approximately 6.6A @ 24VDC
Operating temp = 5 to 45°C {41 to 113°F}
Operating Humidity = 10% - 90% RH
Aug 28, 2009 | Epson TM-T88III Thermal Printer
Computers & Internet Logo
136 people viewed this question
David Payne
David Payne
