Question about Electrolux Dishwashers
Got an Electrolux ESF 620/621 dishwater but it's broken. The power light comes on but the programmer light won't come on and the cycle won't start.
4 Suggested Answers
SOURCE: dishwash machine electrolux esf 6121
Easy fix, had same problem on our. behind the red lights there is the electrc stuff, when you open/close the machine the solderings crack. remove screws until you can get off the panel, then there is some small hooks that hold the board, loosen all contacts and take out the board, check the solderings around the relais and re-solder them, i resoldered all spots on our board.
Posted on Jul 24, 2010
  • 59 Answers
SOURCE: Im not getting any heat
The heater element should be tested first. Use an ohm neter the reading should be around 30 ohms. If thats ok test the thremostat that is directly connected to the element. This should read zero ohms. if that testsok the check that there is the correct voltage to the heater. This procedure should only be performed by a licensed qualified person because you are dealing with live power. If there in no voltage to the heater test the wiring from the controller, then test whether the controller has power leaving it . Perhaps a technician should be called.
Posted on Sep 05, 2010
ginko
  • 19396 Answers
SOURCE: I moved in a new
Hi.
I uploaded the owners manual here: Click to open the manual.
Best regards.
Ginko
Posted on May 18, 2011
Electrolux ESF 65010. How can I erase failure code if the problem is solved and start test program?
Here's the manual link
WWW.manualslib.com/manual/602210/Aed-Electrolux-Esf65010htlm?page4#manual
Apr 10, 2017 | Electrolux Dishwashers
Hi, My Electrolux dishwasher ESF 45030 has got locked and the control panel is not working anymore, could you please help me to fix it?
All of the manuals I can find are in a language other than english.
Not much help here.
if there is a child lock under a button or two hold it/ them down for 3 seconds or until you get the controls to light up.
Apr 18, 2014 | Electrolux Dishwashers
Hello - The issue may lie with the door latch; a door switch is used to start and stop your dishwasher. It's a safety feature that won't allow water to flow with the door open. With a faulty door switch, there is a chance your dishwasher won't start at all. Dishwasher door switches are about an inch long. They are usually black but can be red. There are metal prongs on the body of the switch called terminals. Some door switches have two terminals and some have three. If your door switch is OK, check the timer assembly. This controls when and how long power is sent to other controls on your dishwasher. If these controls don't receive power, they won't work. The timer assembly contains a motor. Check this motor as well. It is often cheaper just to replace the timer motor rather than the complete assembly. My last suggestion is to check the cycle selector switches. These switches indicate cycles for washing, drying, and setting the temperature of the water. If one of your switches is the problem your dishwasher may not start. Dishwasher cycle selector switches tell the timer which cycle to run by opening and closing electrical circuits. Most selector switches are six to eight inches long. They are usually black and have terminals. By testing each one of these parts with an ohmmeter you should be able to determine why your dishwasher is not working. It is possible for other parts to fail but these are the most common parts to check. If any proves to be ineffective, I strongly suggest contacting a professional to move forward accurately.
Nov 05, 2012 | Electrolux 24 in. ESL4125 Dishwasher
Electrolux Eco Valve EWF1087 washing machine,will not programme?Won't accept Quick wash cycle, then stops halfway through
8 November, Today I picked this model off the footpath, yet to set it up I hope it works LeonZ -Reservoir, Vic.
Nov 05, 2011 | Electrolux EW1000i Front Load Washer
I have an electrolux EWX14440W Washing machine,
could be your door interlock is faulty
Mar 01, 2010 | Washing Machines
Dishwasher full of water
Check all areas stated below to address this issue.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer/Control
Replace if defective (note: uncommon problem).
Jun 18, 2009 | Electrolux Dishwashers
Dishwash machine electrolux esf 6121
Mar 01, 2009 | Dishwashers
Dishwasher wash options
www.frigidaire.com look up your model for a download of the manual
May 10, 2008 | Dishwashers
Dishwashers Logo
145 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Garth Jackson
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
