Question about Intel Motherboard
I install os this time come blue screen the msg is beinning physically memory is dump
  • Intel Master
  • 11,800 Answers
Windows is corrupted - something went very wrong. Reinstall again.
Posted on Sep 27, 2010
Maybe the OS you installing was not supporting your PC
its either use different operating system or customize your windows using nlite
Posted on Mar 27, 2012
    Problem Solver:
  • 4 Answers
Install your window in FAT32 and also format your C drive then never give you this msg again.
Posted on Jan 08, 2011
When I install vista os the blue screen appear in monitor(Dumping physical memory in disk). i used (...80gb sata HDD) ...
The operating system is not compatible with the physical configuration of you computer...
this is the reason...
install XP and install a tranformation pack for vista to have a glossy look of vista in XP...
Aug 22, 2010 | Intel D845GVSRL 533MHz FSB 845GV Chipset...
Blue screen physical memory dump?
This is called the Blue Screen of Death or BSoD, this usually happen if u plug in or insert any new hardware. If u have recently added any new hardware, try it out, after plugging off the newly inserted hardware.
Jul 28, 2010 | Microsoft Windows XP Professional With...
Computer restarting again and again and shows a blue screen with "Beginning dump of physical memory." Also when i scan the system using kaspersky internet security antivirus it got restarted and i couldn't...
sometimes it happen because you have installed a driver recently and it is creating a havoc there. try to run in safe mode and restore the configuration to the previous one.
other options, is that a memory went bad. try to read what error is telling before the beginning dump of physical memory.
if one bank of memory is bad, try running your computer with one of the banks at the time.
Apr 23, 2010 | Microsoft Windows XP Professional With...
A blue screen pops up something about a crash dump
sounds liek you installed some hardware the pc did not like. plossibly memory that is not supported or video card that is not supported (some thing that a core item to the pc operation).
If this is not the case, one of these core items is faulty it sounds like. Another possibility might be some corrupted software like the OK throwing up kernal errors (blue screens). I would try to boot in safe mode to see if it happens there. If so, you will either have a hardware issue or OS one.. try the repair installation to see if it helps any. after that is looks like some hardware swapping.. hope that helps
Stan Skaggs
Nov 24, 2009 | Compaq Computers & Internet
Physical Dump of memory
Hi...
There are two thing you should try..
Check the memory.
Reinstall the OS.
Thanks
Kindly rate
Smith
Aug 13, 2009 | Dell Inspiron 1420 Notebook
Physical memory dump
This is not the problem of drivers it is the problem with the memory when one or more programmes try to occupy the same ram space at the same time if you want to get rid of this problem i suggest you to format your pc once and reload the os.
May 30, 2009 | Computers & Internet
Help am getting blue screen on my laptop...not loading xp
First of all if u r getting the blue screen what is the stop code and what is the error, is it saying physical dump of memory,or it says like stop code; 0x000000ed or something like that,in these case if it is just physical dump of memory and the main thing is from how long r u getting the blue screen,and did u install any new software or hardware,and what u can do is disconnect the ac adaptor and take out the battery from the computer and then press and hold down the power button without the ac adaptor and the battery for one minute and then turn on the computer and still if u get it then reseat the memory of the computer and then reseat the hard drive of the computer and still if u getting it then u need to repair the operating system with the help of the windows operating system disk and if u r ready to lose the data from the computer then u can reinstall the operating system and after reinstalling the os also if u get a blue screen then definitely u need to replace the hard drive of the computer.and if u don’t want to loose ur data u can repair the os with the help of windows os disk.,try it out it will definitely help u out…thanks
Jan 22, 2009 | Computers & Internet
My system display bluescreen and say physical memory dump then restart everyday minimium 5times
there are some reesons for this blue screen,first check for error dump files in your system(hope you use windows OS),which may be stored to send error reports to Microsoft,second thing is your C: drive may be almost full,owing to many installed programs,third thing you may have low RAM memory.
Oct 10, 2008 | Seagate 9w2874-500 200 GB Hard Drive
Dell Dimension 4600 Blue Screen
Usually this blue screen appears due a hardware issue or drivers conflict.
1) Try to boot in safe mode (hit F8 after starting up) and select "Safe mode"
If you don't get access try doing this:
2) Run the OS CD and use the option Recover Console (R)
This will fix the problem.
3) If the problem continues, you will need to install the OS again.
Oct 07, 2008 | Computers & Internet
Just use ORIGINAL OS CD and repair OS everything will work fine!
Dec 27, 2007 | Computers & Internet
Intel Motherboard Logo
105 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
