Question about Microwave Ovens
The microwave is not heating or cooking. this will be the second time that i have to take it to be repaired and it is only 18months old. why is this happening?
  • Microwave Ovens Master
  • 17,129 Answers
If there is no action please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off.
Make sure that the program controller is working if not check power - step dwon suppy, the pads are responding- if not fauty pads- or the door switches ,if contact is not through the microwave willnot work.
Now keeping clear of the microwave, switch on , use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues , you can use the microwave safely
Posted on Sep 27, 2010
Not heating
Hello
Power Supply
Check whether there is a proper power supply. Look to see whether the cord is connected to a grounded 3-prong outlet and the cord is fully plugged in. If the electrical system is built-in and no power cord is visible, replace or reset the household fuse or circuit breaker.
Microwave Functions
Some basic microwave operational steps may affect whether the microwave is heating. Open and close the microwave door, as the unit will not function with the door open, and push "Stop/Clear" to cancel any previous settings, such as the timer, which do not heat the microwave oven.
Setting the Microwave
Once the power to the microwave has been reset, or verified as working, and the microwave is ready to run, select a new cook cycle and press "Start" to see if the microwave begins to run and cook food as expected. Allow the food to cook for the alloted time and then open the microwave door and check to see if the food has cooked or heated. Choose a longer cooking time and restart the microwave if food is heating but is cooking slowly.
Repair
If all efforts to troubleshoot the function and power to the microwave still do not get the appliance heating food as expected, there may be a repair issue that needs to be addressed. Contact professional technician for advice.
Oct 05, 2011 | Sanyo Microwave Ovens
My microwave want cook
Hello
and/or circuit breakers, particularly in the case of recent power failure, and reset if necessary.
Unplug the microwave, wait 30 seconds and plug back in to the power supply to reset the microcomputer.
Open and close the microwave door firmly and press "Stop/Reset." Select a new cook time and press "Start."
Ensure a proper cooking temperature and/or time is chosen, as low cooking temperatures or short cooking times may prevent the microwave from heating food appropriately. Press "Power Level" to ensure the microwave is cooking at 100 percent power.
Contact an authorized service technician if the problem is still unresolved.
Oct 04, 2011 | Sanyo Microwave Microwave Oven
Microwave will not cook or heat anything. Cooked a bag of popcorn just fine, tried to cook a second one and nothing happened. I thought the bag of popcorn was bad but it won't even heat water.
sounds like the magnetron has went out...this is the device that actualy converts the electricity into a heating source ... it is a common problem and can be costly,,it is not very hard to change just requires pulling the microwave if it is a cabinet mount and taking the exterior cover off and getting to the magnetron...the problem is the cost of the magnetron is normally somewhere in the range of a $100.00 and your time alot of people choose to get another one due to not being that much more expense and the work involved to repair yours.... good luck hope this helps...
please vote.....
Jan 03, 2011 | Frigidaire GLMV168K Microwave Oven
Interior bulb needs to be replaced. What needs to be removed to gain access? Thanks
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open. However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp.
Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
If the light is not operating properly, you will want to have it checked by an authorized service technician. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Check here
http://www.geappliances.com/search/fast/infobase/10000007.htm
Aug 25, 2010 | GE Advantium 120 Convection/Microwave Oven
I have a 15 year old Toshiba microwave which I may need to replace. It can be set to cook in single seconds (eg for 23 or 38 seconds) a facility I find essential. Many new microwaves it seems can only be...
I believe the dial on Hobart microwaves allows you to manually enter any amount of time by spinning the dial for the desired time, and programmable buttons to save the time settings. HL1600 is 1.5 cubic foot, 44 liters
Feb 11, 2010 | LG LMVM1935 Convection/Microwave Oven
I have a Maytag microwave, model# MMV5165BA and it has no heat.Everything displays and vent works but no heat.Can you suggest anything before I toss it out?
If it operates as normal but items don't seem to get hot it probably is a Magnatron failure (microwave producer). More times than not the repair / replacement of a Magnatron these days is not worth the investment, especially if the microwave is 4 years old or older ! You should be able to replace your microwave with a similar featured microwave / hood for about $300 to $400. You might try a JVM1750DMWW by GE great micro/hood for about $300, includes one touch sensor cook capabilities,300 CFM vent fan,removable rack,option to turn the turntable on or off, 1000 watts of cooking power. Good luck !
Nov 28, 2009 | Maytag MMV5165 Microwave Oven
Sharp microwave losing cooking power
If the supply voltage is low it will take long time to heat foods. The second reason is the Magnetron. Since it is in the warranty period you can call at the sharp authorised service center. They will do it free of coast.
May 04, 2009 | Microwave Ovens
GE Microwave won't heat or cook - one year old
More than likely the magnetron has failed. This could be for a number of reason. Do you use your microwave to heat wheat packs or warm plates? If so, you may have dried the magnetron out (they use the moisture in whatever you're cooking to heat it, and plates/wheat bags have no moisture).
I'd say a trip to your local Microwave repairer could be in order. It could also be the High Voltage Fuse which has failed. Either way a repairer will be able to tell you!
Mar 25, 2009 | GE Profile Spacemaker Over-the-Range...
Lg microwave LMV1650ST
don't try to fix this yourself, faulty microwaves should be repaired professionaly or replaced.
Oct 23, 2008 | LG Microwave Ovens
Microwave runs for 3 seconds and shuts off
This is an inverter-driven model, and this is one way the inverter fails. Often it will tick, too, but the cooling fan may be too loud to hear ticking. If you haven't had smoke, then it may not yet catastrophic. I would bet that a thorough resoldering would take care of it. A good technician can troubleshoot and repair this, as needed, but often they will just replace the inverter. Sometimes that's actually cheaper. Troubleshooting an inverter is way too much for someone without good solid technical experience. I would call a shop and ask for an estimate to replace the inverter. Good luck.
Oct 13, 2006 | Panasonic NN-S252WF Microwave Oven
Microwave Ovens Logo
21 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
