Question about A4tech PK-635 Webcam
How to install it w/ out cd drive? - A4tech PK-635 Webcam
  • 11,800 Answers
Get the installer from here
http://fileml.com/295n84
Posted on Sep 27, 2010
  • Azrael SRL Sep 27, 2010
    Sorry, expired link. Here's a new one
    http://www.driverstock.com/A4Tech-PK-635...
Hi I have cf-19 I need to install mapping software that requires a resident cd drive to install. Will any usb cd/dvd drive work?
As long as it is a plug&play drive it should work just fine. It's hard to install a USB CD/DVD Drive that isn't plug&play.
May 02, 2011 | Panasonic CD FOR TOUGHBOOK (cf-vcd721w)...
How to install cd-rw/crx320ee drive
installing CD drive no need installation driver, just install it like install Harddisk drive but you need to open the slot for your CD drive (dont forget to screw it). after u finish install it just reboot your computer, then the CD will automatically installed.
hope this useful.
Feb 18, 2011 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
I have em350 and it has no cd/dvd driver .. how can i install windows 7 ??
You can install Windows 7 Through USB Drive .
Here is the complete instructions of how to install through USB
Jan 30, 2011 | E-Machines emachines (emachinees) CD-ROM...
D drive will not load some disc programs in to the computer
If you are saying D drive is your CD/VDVD drive? If you are installing from CD/DVD drive then suddenly stop the installation/setup/loading you must check your disc drive. To check your cd/dvd drive insert a cd or dvd cleaner and start cleaning most of the cleaner has a movie inside of the disc and run for about 10 minutes. Then try again installing/setup/loading the program to your computer. If its still the same, replace your CD/DVD drive with a new cd/dvd drive because your cd/dvd drive is need to be replace. Have a nice day
Jan 26, 2011 | Computers & Internet
Hoew to install CD Drive
You want to install a CD Drive. Ok you are Following these steps....
  1. Unplug the power cable from your power supply and open your Computer case.
  2. Determine which drive bay you are going to install a CD-ROM into. You should pick on of the uppermost drive bays
  3. Before you install a CD-ROM, make sure you have the proper jumper settings. You are only installing a single CD-ROM, set the jumpers as MASTER. The jumper settings are different for each CD-ROM drive, so consult your owner's manual so you know which pins to cover up.
  4. Once you have the jumpers set, install your CD-ROM in the computer's case. How you secure the CD-ROM in one of the uppermost drive bays depends on your case. Some CD-ROM drives have to be screwed into the drive bay.
  5. Connect the power to the back of the CD-ROM drive, then connect the ribbon cable to the back of the CD-ROM drive. Your ribbon cable has three connectors, one in the middle and one on each end. The middle connector is a SLAVE connector that is used if you would install an additional CD-ROM or DVD-ROM drive.
  6. Connect one of the end connectors to the CD-ROM drive, and connect the other end connector to the appropriate spot on your motherboard. Note, hard drives and CD-ROM drives have the same style of connector on the motherboard. You want to connect your CD-ROM drive to the motherboard slot that isn't red or is the highest numbered of all the IDE slots.
  7. Power on your computer after you plug it in. Your computer should recognize the new CD-ROM. If it doesn't, go into your motherboards BIOS and search around for the IDE channels, they need to be set to automatically.
Thank U
Aug 28, 2009 | LG Computers & Internet
Soyo sy-p4vgm motherboard unable to access BIOS setup menu
Offcourse! first of all insert CD into CD ROM then boot from cd. Select your CD drive like d: or e: or f: etc and then press enter. Now give a commond format c:/u/v and press enter. After the formating drive you can install windows 98 so now reboot your system again. Then boot from CD once again and choose your drive and install windows.
2nd way, If everything could not be possible then you should boot from CD again then select your CD drive and type a command fdisk and press y or enter 2 times. Now you choose 4 number and press enter and check the drive format if it is not FAT32 its mean that you should press 3 and then press 4 and now press enter then press escape. Then press three button at a time Ctrl+Alt+Del now your system will reboot now once again Boot from CD and choose CD drive and type fdisk and choose 1 then choose1 and now press enter and once again press three button at a time Ctrl+Alt+Del now your system will reboot. Once again boot from CD and select your CD drive and now you can install windows 98 now insert CD into CD ROM then boot from cd. Select your CD drive like d: or e: or f: etc and then press enter. Now give a commond format c:/u/v and press enter. After the formating drive you can install windows 98 so now reboot your system again. Then boot from CD once again and choose your drive and install windows.
Thank You
Jul 30, 2009 | Soyo SY-P4VGM Motherboard
Re-installation of windows after format C:
1. Insert the Bootable Windows CD in the CD Drive 2. Then Power On your Computer and Boot from the CD. 3. Then proceed with the installation . For installing this you dont require to find C and CD Drive. hope this solves....
Jul 24, 2009 | Computers & Internet
I am not able to install it.The windows is recognising the LG player.
Hey,
Cd and dvd drives are installed automatically on windows when they are connected properly. if your drive is not installing then your computers windows has problems, I would insist that you use recovery cd's to restore the computer to original state or use the windows installation cd to install windows to the computer again.
Note that the cd / dvd drive may work outside of windows, so you may be able to install windows with the drive even though it doesn't work in windows. check bios if the drive is detected there or not.
heres some info on the bios, how to get there and how to use it.
http://www.youtube.com/watch?v=Tc1t3c5Yke8
you may need to change the boot order so that the cd starts before the hard drive.
May 05, 2009 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
Cd driver won't install
Make sure the CD drive is fine. When you insert the CD, does the CD drive's LED on at all? In Device Manager, did you see the CD drive is detected / working properly? Or if the CD drive is broken, Toshiba covers the warranty? If not, then you may buy a USB CD-drive.
May 09, 2008 | Computers & Internet
A4tech PK-635 Webcam Logo
Top A4tech Computers & Internet Experts
micky dee
Tony
Are you an A4tech Computer and Internet Expert? Answer questions, earn points and help others
