Question about HP LaserJet 1200 Series PCL 5e
Test print failed to print - HP LaserJet 1200 Series PCL 5e
  • 48 Answers
Follow the very simple instructions on This page
Note: You will have to check for Windows updates after you complete these steps.
THANKS, With Regards...... Vaishu
Posted on Sep 27, 2010
This printer runs the self test for more than 2 minutes. When it settles from self test, I try to print and it does not print when I command print. The printing queue is empty. I have tried to uninstall...
I under stood, its not self test its keep on intializing more than two minutes. Replace the DC controller, check system recognising the divice or not,if not you need to replace the formatter also at time..good luck..
Sep 05, 2011 | HP Hewlett Packard LaserJet 1018 Printer
Its not communicating with the computer will not print!!!!!
check that you are using the correct virtual usb printing port in your printer settings and swap it around if necessary and check if you can make a test print each when the test prints works you have got comms. dont forget to after each failed test to delete the failed file out of the printer que
Oct 13, 2010 | Lexmark X1150 All-In-One InkJet Printer
X8350 All-In-One InkJet Printer: printer does not recognize color cartridge...
Trying cleaning the contacts on the cartridge and clean the contacts on the printer use a
dry tint paper towel to clean the contacts. Then try to reinstall the cartridge using the
software. Try to print the self test. If failed try another cartridge if you dont get any
error then the cartridge might be defective.
Next, lets try to print the self test.
Begin by disconnecting the power supply from the wall (not the back of the printer) for at
least "30 seconds." This is essential. Then plug the printer back in and follow these
steps:
1. Press the "Copy" button.
2. Press the "Menu" button.
3. Press the down arrow button once or until the screen displays "Maintenance."
4. Press the check mark button to select the "Maintenance" menu.
5. Press the down arrow button three times until the screen displays "Print Test Page."
6. Press the check mark button to select this. The Self-Test will start printing.
The self-test should at least print out a set of either black or color bars, if not both
(if you have a printer with both color and black installed simultaneously.) Should this
test fail, try it again without cartridges installed. If the self-test still fails to take
paper in and make sounds like the carrier is moving across the paper, this is a hardware
issue, and the printer will require service. If the self-test completes without any
cartridges installed, run the self-test again with the color cartridge installed. (If you
have both black and color cartridges, after this test, run the test again with just the
black cartridge installed.) If you find that either cartridge causes the self-test to fail,
please let me know.
your's tech expert
Jeeth
May 18, 2010 | Lexmark X8350 All-In-One InkJet Printer
C6180 failed alignment test, will not print color properly
All colors need to be present to pass alignment. Usually what I see is the yellow is empty. You can blot the print cartridge on a damp paper towel to verify the inks are working and this also cleans the head.
Jun 29, 2009 | HP Photosmart C6180 All-In-One InkJet...
Xerox Phaser 6350 printer freezes up and restarts by itself.
Hi dpluu:
Try this procedure:
Engine Test Print
Isolate printer hardware problems to either the Engine Control or Image Processor
Board by running the Engine Test print. If the print is successfully printed, focus on
the Image Processor Board or its components (RAM, Hard Drive, Configuration
Card, etc.). If the print fails, refer to Section 4 for print engine troubleshooting help.
1. Press the Test Print button located on the Rear Panel.
2. The printer prints the 600 x 600 test print unless an error status from the Engine Control Board is present. The test button is in the back of the printer and say's Test Print.
Hope this helps
May 22, 2009 | Xerox Phaser 6350/YDT Laser Printer
Lexmark x5495 all in one.paper does not come out when printing
It seems there is a possibility of a problem with the printer itself, or perhaps the cartridge. You should first self-test the printer. Since we are unsure where the problem exists, we must do eliminative troubleshooting to rule out parts of the printing system. The self-test allows us to rule out software and the cable by testing the hardware by itself. Please note that this is not a "fix," but rather a diagnostic test to determine if your hardware is at fault.
Please begin by disconnecting the power supply from the wall (not the back of the printer) for at least "30 seconds." Then plug the printer back in.
Next, try this printer self-test by following the steps given below:
1. Make sure the printer is in “Copy Mode.”
2. Press the “Menu” button once.
3. The screen will display “Copy Menu: Copies”.
4. Press the left arrow button once. The screen will display “Copy Menu: Tools”.
5. Press the check button once. The screen with read “Tools: Maintenance”.
6. Press the check button once. The screen with read “Maintenance: Ink Levels”.
7. Press the right arrow button until the screen reads “Maintenance: Print Test Page”.
8. Press the check button once. This will start the Self-Test. Once the page has printed, the printer will stop. The test is not continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed). If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues - we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
May 15, 2009 | Lexmark X5470 All-In-One InkJet Printer
Error1102 occurs after new ink cartridges are installed
To clean the NVRAM, please follow the steps given below:
1. Press the "Up-Arrow" button and "Menu" Buttons Simultaneously.
2. Press the "Down Arrow" button until the LCD displays "Clean NVRAM."
3. Press "Select." The LCD should display “Success” or “Failed.”
If it is successful, please try this printer self-test by following the steps given below:
1. Press the "Menu" button.
2. Press the down arrow button 9 times until the screen displays "Print Test Page."
3. Press the "Select" button to begin printing the self-test.
You should see text followed by a thick 1-inch black bar. Under this bar, should be a process gray bar about a 1/2-inch thick. Below this line should be a set of railroad like bars of cyan, magenta, and yellow.
Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
Apr 21, 2009 | Lexmark P4350 All-In-One InkJet Printer
Won't print says its busy
You need to clean NVRAM on Lexmark X7550 printer. Please follow the steps given below:
1. Power "Off" the All-In-One.
2. Press and hold the number button and turn the All-In-One back on. Press and hold the "Color Start" button and the "Check" button at the same time and turn the printer ON.
3. Release both the buttons once the printer is ON.
3. Press "Down" arrow button to go to the "Maintenance" menu entry. Press "Check" button.
4. Press "Down" arrow button until you reach "Manufacturers Test." Press "Check" button.
5. Press "Down" arrow button until you reach "Clear NVRAM." Press the "Check" button. The printer will restart by itself.
6. You will be prompted to go through setup again and to print an alignment page.
1. Turn the printer ON.
2. Press the down arrow button till the screen displays “Maintenance.“
3. Press the "Check" button.
4. Press the "Down arrow" button till the screen displays “Print Test Page.”
5. Press the "Check" button.
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
Apr 19, 2009 | Lexmark X7550 InkJet Printer
Print cartridge missing
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please snap the cartridges back into the cartridge carrier.
1. Please turn OFF the printer.
2. Press and hold the "Color copy" button.
3. Now, turn ON the printer.
4. Once you see "0" on the display, release the "Color copy" button.
5. Press the Up arrow button until "2"appears on the display.
6. Press the "Black copy" button to start the self test. Once the page has printed, the printer will stop printing.
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed by itself. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let me know.
If the self-test prints, but has lines or smudges or other print quality issues, let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
Apr 13, 2009 | Lexmark X2650 All-In-One InkJet Printer
Lx 300+ detected by xp but test page fails
hello,
please go to bios setting and change parallel port type spp+epp or epp or normal try to change type and try again.
Oct 14, 2007 | Epson LX-300 Matrix Printer
Computers & Internet Logo
96 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
