Question about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
I can't boot my computer. error appear: file in system32 is missing that's why my computer do not continue booting.
  • Microsoft Master
  • 11,800 Answers
The file is missing because Windows was corrupted. The only way to fix that is to reinstall. If you have files that you can't lose then before reinstalling boot from a Linux live-cd and copy them.
Posted on Sep 27, 2010
    President:
  • 2,291 Answers
Once you enter the setup and it loads the entire program, then you need to press the R key, which is for repairing the windows installation. This action will take you to the dos mode where further processing will be done. In the dos mode, system will ask you about installation place. Most of the people install their operating system in the C drive, which comes at number 1 option, so you need to press option 1. However, if you have so many partitions or you have installed the operating system then you need to choose the option according to your drive name. Here you need to enter your password as well, but if you have not set any password then you can simply press enter.
*Then there will be a c:\WINDOWS> command in a dos mode where you need to write, "Copy d:\i386\ntldr c:\windows. However, if you have different place of your installed operating system then you will write the address of that drive. This is the whole process and now you can eject the cd and can press exit to restart the system. Now this process will copy the correct NTLDR file from installation disk to your hard drive by making your system in the working condition.
Remember to fix your Windows registry with Reg In Out Registry Cleaner and PC Optimizer
Hp compaq 530usdt windows\system32\conf\system. File missing or corrupt
insert original win installation cd and reboot... when in boot mode make sure you are booting from CD, not from disk, when message asking that you "boot up from cd " appears, just press any key, and folow procedure, but do not install a new copy of windows ! There must be "repair your computer" option on your CD, for Win Xp - it is "recovery console" ! When repairing finishes restart computer and boot from disk (just do not press anything when you see message "boot from CD..." and let windows from HDD configure it self).
Mar 10, 2014 | Computers & Internet
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
Dell Latitude 810 will not boot. When computer is turned on a black screen appears with the message "Windows could not start because the following file is missing or corrupt: <Windows...
Boot to the WIndows XP CD (Press spacebar when prompted to press any key) at first prompt in setup, press R to enter recover console.
At the C:\Windows\System32\> prompt type bootcfg /rebuild then press enter
http://support.microsoft.com/kb/330184
reboot see if error resolved.
If not then try running diagnostics by pressing Fn plus power button, see if there is a HDD malfunction
Jul 16, 2011 | Dell Latitude D810 PC Notebook
How to repair missing wininet.dll?
If you see an error related to the wininet.dll file being deleted or missing, copy this file from the c:\windows\system32 directory of a working Win XP Pro
or Win Vista computer onto a flashdrive, then use the following procedure to copy it onto the failing system.
  1. At the boot screen (the first thing to appear at power-up), hit the F8 function key.
  2. Select 'Safe Mode with Command Prompt' and continue.
  3. In the command prompt window, type the letter of your flash drive, either d: or e: until the drive appears as e:> in the prompt window.
  4. Type 'dir' to see the wininet.dll file on that flashdrive.
  5. Once you see that file, type 'copy wininet.dll c:\windows\system32'.
  6. Unplug the flashdrive and reboot the failing PC.
Once you succeed in reviving the failed computer, go to c:\windows\system32 and right click on the wininet.dll file then copy and paste it to a save name (recommended name: wininet-copy.dll). This allows direct copy of that file back into wininet.dll if the problem reoccurs.
If you suspect an anitvirus engine or some other application deleted this file - and if it occurs again, make note of what was being performed, immediately before the failure mode. This will lead you to the offending program needing attention.
Good luck, hope this helps.
Aug 07, 2010 | IBM NetVista PC Desktop
Keep getting this message <window
  • "Windows could not start because the following file is missing or corrupt:
    <Windows root>\system32\hal.dll.
    Please re-install a copy of the above file."
  • "<Winnt_root>\System32\Hal.dll missing or corrupt:
  • "Cannot find \Windows\System32\hal.dll"
  • "Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears. CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
    Please let me know you have any further questions or concerns.
Thanks.
May 08, 2010 | HP Compaq 6720s Notebook
Error says file: systemroot\system32\config\system
Can you boot into Safe Mode? Restart the computer and hit the F8 key continually until you get to the Advanced Boot options and choose Safe Mode. Here you can run System Restore. If you can't, then boot off of the Windows XP CD and get to the Recovery Console. Here you would type in chkdsk /f/r and hit enter. The Check Disk utility will try and fix any errors in the file system.
Mar 19, 2010 | Computers & Internet
C:\windows\system32\hauurjab.dll is missing on my
Just google the error msg and you'll find the solution for it. At most times, ppl recommend you to delete this particular registry file that is associated with this dll file. But if I were you, i would better reinstall the operating system. Just google the error and give a try. Best o'luck.
Hope this helps, If so, rate me.. ,thanks - billa
Sep 05, 2009 | Microsoft Windows XP Home Edition
File Missing or Corrupt system32\hal.dll
Ok, that means the file boot.ini is not pointing at the right partition to boot. Make sure that in the boot.ini, in parentheses is the correct number, which is always one below the actual number!!!!!!!!!!!! I mean, partition number one has the number 0 for Windows.
If you can't boot from that disk, maybe you can put it in a computer, as a slave disk. I had the same problem because I installed Linux in another partition and Windows didn't like it.
Nov 30, 2008 | Western Digital Scorpio WD800UE 80 GB Hard...
Error: windows root>\system32\ntoskrnl.exe
Issue: NTOSKRNL.EXE is missing or corrupt.
Related errors:
Below is a listing of the full error message that may be related to this error.
Windows NT could not start because the below file is missing or corrupt:
C:\Winnt\System32\Ntoskrnl.exe
Cause:
  1. Keyboard issue
  2. Miscellaneous corruption
  3. Corrupt boot.ini file.
  4. Missing boot.ini file.
  5. Missing or corrupt ntoskrnl.exe file.
  6. Windows NT installed on a partition bigger then 7.8GB
  7. Corrupted hard disk drive or severely corrupted Windows.
Solution: Keyboard issue This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or simply just disconnecting the keyboard from the computer.
Miscellaneous corruption Before trying any of the below recommendations it's recommend that you attempt to load the last known good configuration. Additional information about doing this can be found on document CH000626.
Corrupt boot.ini file This issue is often caused when the boot.ini is missing or improperly configured. This issue often arises after a user has recently added or removed an operating system on the computer or added or removed hard disk drives in the computer. Make sure the line pointing to the operating system and it's drive and partition is properly configured in the [boot loader] and [operating systems] section. Additional information about boot.ini can be found on document CH000492.
Missing boot.ini file Microsoft Windows XP users: If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue. Additional information about rebuilding the boot.ini can be found on document CH000648. Microsoft Windows NT and Windows 2000 users: To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
  1. Boot the computer with your Windows NT three setup diskettes or the Windows 2000 setup disc.
  2. In the setup menu, type R to start the repair.
  3. When prompted for the ERD diskette insert the diskette and inspect the startup environment.
Missing or corrupt ntoskrnl.exe file If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
  1. Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
  2. Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key.
  3. In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
  4. Select the operating system you wish to fix, and then enter the administrator password.
  5. Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
  6. You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
  7. Type exit to reboot the computer.
Windows NT installed on a partition bigger then 7.8GB If you are running Microsoft windows NT 4.0 on a partition larger than 7.8GB this issue can occur if the boot files are located outside this limitation. When this error occurs your computer will have the error message as shown below. OS Loader v4.01
Disk I/O error status=00000001
Windows NT could not start because the below file is missing or corrupt: winnt\system32\Ntoskrnl.exe
Please reinstall a copy of the above file. If your system partition is larger than 7.8GB you will need to delete the partition and recreate the partition to 7.8GB or less. Additional information about this issue can be found on Microsoft KB Q224526.
Corrupted hard disk drive or severely corrupted Windows Attempt to check the hard disk drive for any errors by running the chkdsk error. To do this follow the below steps.
  5. Once at the recovery console type chkdsk /r
  6. Once completed type exit and see if issue is resolved.
If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you attempt to reinstall Windows. Additional information about erasing the computer and starting over can be found on document CH000186. Finally, if during the Windows installation you encounter errors it's likely that your hard disk drive is bad.
Oct 18, 2008 | Computers & Internet
How do I...
Related errors:
Cause:
Keyboard issue
Solution:
Keyboard issue
OS Loader v4.01
Oct 09, 2008 | Dell OptiPlex GX110 PC Desktop
Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
