HOW TO IGNITE THE PILOT - Heating & Cooling
  • 43,501 Answers
For a competent expert to be able to answer your problem, you will need to givea specific make and model of your unit.
Also include as much as possible about what you have already tried to do toresolve the problem along with exactly what is not working or what the unit isnot doing that it is supposed to do.
This will help us experts to be able to give you the correct advise the firsttime, without having to guess so much as to what is actually happening.
Thank you!
heatman101
Posted on Sep 28, 2010
Propane "Country Stove" pilot will not ignite
Clean the jet of the gas supply. Clean off the pilot light jet. Clean the tips of the igniter. Carefully clean all of those things with a little rubbing alcohol. Make sure the pilot jet is not clogged!
Jan 13, 2013 | Heating & Cooling
I have an imperial fryer. Pilot is on but main burners don't ignite. Pilot looks normal & thermostat clicks when turned
Number 5 is your thermopile/pilot generator. It is a pilot generator that does 2 things. It holds open the valve with a safety magnet and it operates the safety valve solenoid whenever the control stat calls for heat. Overtime they get weak and will hold the pilot but not operate the valve solenoid. I would replace that pilot generator.thermopile and party on!
Jul 30, 2012 | Imperial IFS40 Deep Fryer
Pilot lights but gas does not ignite main burners
After lighting the pilot, has the control knob been turned to the ON position? If left in the Pilot position, the burners will not ignite.
May 31, 2011 | Heating & Cooling
Fails to ignite,sparks but pilot will not ignite. have had problems with pilot going our for about three months. Thought attic air flow was the problem. closed off air vents in area of heater. problem...
Sometimes the pilot orrifice get plugged up and need to be taken apart and cleanned,,,,,, adjust the pilot flame on the gas valve, or check gas going to the unit to see if the in-line gas valve is opening and closing.
Dec 09, 2009 | Ruud Heating & Cooling
I have a model 3E381E overhead heater. the pilot tries to lightbut there is no gas coming thru to ignite. there is sufficiant gas in place as there is a water heater directly below running off the same gas...
you have a clogged pilot orifice you will need to remove from valve and apply pressure to it to clear. compressed air with a fitting to make sure it goes thru the tube
Dec 04, 2009 | Heating & Cooling
Pilot Flame will not ignite
Clean the pilot tube of rust or other debris.
Jul 10, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Main burner will not ignite Tempstar(NTC5075BFD1)
try cleaning the pilot oriffice it sounds like the flame is weak
Jan 15, 2009 | Goodman GMS90703BXA Heater
Wather heater will not ignite
You'll probably need to ignite the pilot light before it will allow gas to flow for the heater to ignite and warm the water.. Most controls have a Pilot position that you switch it to , than using a long match .. locate the pilot light in the access opening at the bottom and get the pilot light to stay lit.. Hope that helps...
Aug 16, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
