Question about Chi Mei Corporation CMV-221D LCD Monitor
Ii am looking for a driver for my monitor model A170E1 08 where can I download the driver?/
Dell 1900 fp monitor driver
Go to GOOGLE and type DRIVERS for your exact product and model of monitor, which will hopefully give you the correct drivers to download. Softonic would be one place to look. CNET would be another.
Sep 19, 2012 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
Hi I need the driver for my kworld vs-tvusb2800r
http://download.cnet.com/kworld-falcon-ii-video/3000-2110_4-161139.html update This package supports the following driver models:
  • KWorld Falcon II Video Capture
    if this driver package is not right
    http://download.cnet.com/2000-20_4.html
    on the home page you should see a search tab just type in what you are looking for
    (be precise)don
Oct 06, 2011 | KWorld V-Stream X-Pert (vs-tvusb2800r)...
Where to download drivers
Hi Mihail
You don't say what problems you are having with the monitor that you hoped drivers would help to resolve. Add a comment or a clarification request with more information about the actual problem might give you ideas for alternative repair strategies with a higher prospect of success than looking for Drivers.
Most display problems are rooted in either the graphics card or the graphics drivers. Monitor control only a very limited set of display properties, such as frame margin position, brightness, colour saturation and colour contrast.
Almost without exception, there are almost no monitors that require drivers to function with any Operating System. Virtually every monitor uses the Plug and Play .inf drivers built into Operating Systems. The graphics drivers are a totally separate issue from the .inf monitor drivers.
Accessing almost every driver download website that claims to have drivers available for download for specific models of monitor, will result, despite whatever optimistic stages at the beginning of the download process might indicate, in arriving at the actual driver download page only to find that no drivers are ever available after all. While driver download pages for some monitors might exist, no actual drivers are ever available to download from them.
If there is no physical defect with the button controls on the monitor, the asker should test the monitor at different graphics resolutions, test a different monitor cable and then test a different monitor. These are the only practical options available.
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can. If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Sep 17, 2011 | Hannspree HW191D LCD Monitor
I NEED A DRIVER 4 VS L883D
http://download.cnet.com/kworld-falcon-ii-video/3000-2110_4-161139.html?tag=api
This package supports the following driver models: KWorld Falcon II Video Capture
http://download.cnet.com/tv-nywhere-ms-8876/3000-2108_4-10199391.html?tag=api
This is the latest version of Conexant TV capture driver
these driver packages are not the right
(be precise)also the download software finder under that there will be a list place a tick in the box of any one you want/need
all software windows software mac software mobile and web apps
http://majorgeeks.com/downloads35.html
also this link will provide you with many freeware and share drivers
hope this helps you
Aug 03, 2011 | KWorld (KW-L883D) (KWL883D) Video Capture
Lost my driver software how can i get a copy off the web?
You don't need drivers for moniters because they are automatically installed when plugged into your pc. If you are looking for any software it may have come with, then you can download it for free from Viewsonics website/support section.
Feb 28, 2011 | ViewSonic VX910 19" LCD Monitor
154P1-L04 monitor has lines in my Dell 6000. I bought another monitor and it looks like a old photo negative and hard to read. Cepia look aswell
Either the video adapter is bad or the driver is corrupted. Go to dell.com and download and reinstall the software driver for your model. If it doesn't change the appearance, try the monitor on another pc/laptop. If still bad, monitor display is defective. Thanks
Jan 08, 2011 | Samsung LTN154P1L04 COMPATIBLE LAPTOP LCD...
Need driver download have new tower and lost CD for monitor X2GEN model MG19MY
Most monitors do not need additional drivers for them to function properly in Windows XP, Vista, and 7. If you are not able to set the monitors native resolution then look at your video card drivers. If these are not up to date, then you can see some very odd default resolutions.
Mar 27, 2010 | X2Gen Computers & Internet
Windows 7 vga port problem
the driver u are looking for is: Intel Extreme Graphics II (855GME) go to WWW.INTEL.COM search for drivers select windows 7 and download.
Nov 06, 2009 | IBM ThinkPad R50e Notebook
Open Questions:
cmv221d wont power on even after changing capacitors Not even the LED or any response from the screen, nothing.. I ordered replacement capacitors, all except the big 400v one, replaced them all.. nothing's changed. I've ordered the big capacitor's replacement just incase, but heard they rarely break.. any other ideas of what the problem might be? The guy who gave me it said that he thought all that was wrong with it was a line across the screen (corresponding to where he said that line was, I found some dirt on the edge of the connectors). It actually did not power on as it was supposed to, according to the previous owner, who made no profit by giving it to me. A tiny part of the circuit-board did get slightly peeled when pushing one capacitor in, but only about 3mm across, affecting two small strips of whatever those little chrome strips are, but I soldered it back down.. I may have also re-attached the large Capacitor, and in folding it back down, had to force it.. could this have internally damaged it easily? This is the first time I've done anything like this, but I have followed a tutorial and learned the correct technique for soldering. Does anyone have any ideas what else it could be? The fuse looks fine. The power cable works in other monitors. I hear a little crackling if slowly pulling out the power cable as you'd expect with any screen if you listen close (atleast in Australia, I remember being surprised at how much things crackle here after moving from the UK). But yeah, basically the screen is stone cold dead, no response whatsoever..
Dec 27, 2012 | Chi Mei Corporation CMV-221D LCD Monitor
See all Chi Mei Corporation CMV-221D LCD Monitor Questions
Chi Mei Corporation CMV-221D LCD Monitor Logo
360 people viewed this question
Top Chi Mei Corporation Computers & Internet Experts
Jax Planet
Jax Planet
Steven's...
Steven's...
Are you a Chi Mei Corporation Computer and Internet Expert? Answer questions, earn points and help others
