Question about Panasonic DP-8035 Grayscale Copier
What is the default TCP/IP of panasonic DP-8020E. At first I connected the LAN Cable I recieved the DHCP option, I disbaled it, than instantly there comes TCP/IP setting but disappeared. Now I can't find the TCP/IP setting to configure the printer on LAN. Thanx DPA Zafar Javd LAN Administrator
SOURCE: DP-190 Network Printer
I succeeded in printing via network to the Panasonic Workio DP-190.  Here is a brief summary of what needed to be done...
* HP laptop w/ Windows XP SP2 installed * requires LPR support via "Print Services for Unix" to be installed from Windows Components (http://technet.microsoft.com/en-us/library/bb457002.aspx) * Installed using GDI printer driver (http://panasonic.co.jp/pcc/products/en/mfp/download/dp-190/list.html)
During the GDI installation I choose a 'Network printer' and the printer was already setup for proper IP addressing, etc...
I created a new printer port of type LPR, doing so required me to input the printer's IP address and a queue name -- the queue name was left blank.
Hope this helps, John
Posted on Mar 30, 2008
SOURCE: Panasonic Workio Dp 2500 problem
change any one of the IP adress to one group..i.e.,change 192.168.2.20(address of Printer) to 192.168.1 to 99 or the the other way round..that would solve your problem...
Posted on Apr 01, 2008
firecontrol7
  • 6161 Answers
SOURCE: Set user codes on DP-8020E Panasonic copier and
Have you tried, 00000000, or 0000 ,12345678
Posted on Aug 06, 2009
SOURCE: drivers problems
please send the driver
Posted on Sep 30, 2009
  • 54 Answers
SOURCE: dear sir , we have one error on printer E02-01 ,
the paper lift assembly will be broken or some paper will be struck check both the piont ,also check the voltage
Posted on Mar 02, 2010
What can do to configure my bizhub c300when network setting did not display?
Go to Admin mode, then network, TCP/IP, then enter the IP address, subnet and gateway. SET FOR STATIC IP not DHCP!!!!!!!
Default admin pw 12345678
Feb 13, 2015 | Konica Minolta Bizhub C300 All-In-One...
Setting IP address on Panasonic dp8020e
Press the function button while in the copier mode, scroll to general setting and press set or the green start button, scroll to key operator mode and press set or start, input 000 or 0000 in some cases and press start, scroll down till you find dhcp and switch off, press set or start scroll down to tcp/ ip and enter your new static ip, press set do the same with subnet mask and gateway. Remember to press set or start after each input. Press the red stop button until you are completely out of the menu. Switch machine of and after a few seconds back on again. Ping ip from pc to confirm communication.
Oct 21, 2013 | Panasonic DP-8020E Black and White Copier
Default ip addr of panasonic network printer workio 8020e
In workio 8020e default is DHCP active
insert manual ip
Nov 26, 2012 | Panasonic Workio DP-1820E Copier
Unable to establish connection between PC and router.
Check your PC NIC card is installed properly in device manager or connect your PC directly to MODEM and check if IP, DG and DNS would appear.
If that works, then you know its the router (Belkin). Try resetting it to factory defaults by pressing the RESET button.
Jul 26, 2010 | Belkin Wireless G Router
I have a yellow machine p400t and i need to give it a static IP address and do this through a linksys router. how do i go about this? do i need to attach it to a computer?
Yes, it must be attached to the network 0. Install the yellow machine software on the PC 1.Log on to the Yellow Machine Manager. Go to “Logging On To Yellow Machine Manager” on page 8. 2.From the Yellow Machine Manager, click Network > Network Interfaces. The Network Interfaces window appears. 3.Click Edit. 4.Select Yes to Enable LAN Interface. Default: Yes (Enabled) • If you select No, all other LAN option fields are blocked. • If you disable the LAN Interface, the only access to the Yellow Machine appliance is through the WAN port. Anthology Solutions does not recommend this configuration. 5.Check Enable DHCP Service if the DHCP service is needed for the PCs attached to the Yellow Machine appliance’s LAN ports. This setting makes the Yellow Machine appliance the DHCP server for your LAN (or sub-network), providing IP addresses dynamically for the clients connected to the LAN ports. Default: Checked (Disabled) 6.Select either Obtain IP Address Automatically from DHCP Server, or Static IP Address. Default: Static IP Address • Choose Obtain IP Address Automatically from DHCP Server if your Yellow Machine appliance connects to either a router that has DHCP service enabled or to a cable modem. This setting makes the Yellow Machine appliance a DHCP client on your network. • Obtain IP Address from ADSL provider is greyed out. • Choose Static IP Address if your network is locally defined and controlled and does not use DHCP services. Type the IP address manually. 7.Specify IP address and Subnet mask if you selected a Static IP Address, and click Apply. 8.Click Yes to confirm, No to abort. The changes takes affect within five seconds after the network interface change notice appears.
Jan 26, 2010 | Anthology Solutions Yellow Machine P400T...
Unable to connect to DHCP server. getting 169.254 ip Have already tried the following: unplug/ reset reboot router; ipconfig /release /renew; Run MBAM Version 1.43; System restore to a date when connection...
Whew! Awesome troubleshooting work there.
When it's configured for DHCP, go to the Internet Protocol (TCP/IP) Properties and hit Advanced to bring up the "Advanced TCP/IP Properties" dialog.
Under the IP Settings tab, the top panel should be "IP addresses" and should have "DHCP Enabled" as the only entry, and the default gateway should be blank.
If both of those are correct, then I have one other question for you:
When you manually set an IP, are you able to use the network? If so, are you able to ping the DHCP server's address?
If so, then my guess would be that the DHCP server has a stale record for your Dell's MAC address.
Post back with the "Add Comment" button here and we'll get it working for you.
Jan 06, 2010 | Dell Dimension 3100 PC Desktop
Dear Sir,need ip address
i want to configure a network printer on lan but i do not know how to assign an ip address to the printer panasonic dp-8016p
Dec 20, 2009 | Panasonic Workio DP-1820P Laser Printer
DP-300 Print Server Access Problem
Using a print server like this, you should not need to "browse" to find the printers. See what ip address has been assigned to the printer. Once you have the ip address, open a command prompt (start -> run -> cmd) and type:
ping <insert ip address>
ex: ping 192.168.0.24
See if you can ping the printer from each of your computers. If you can, great, install the new printer by adding a "local" printer at a new TCP/IP port with the IP address of your printer. If not, then you may have some routing issues.
Are all of the printers connected to the same switch? Do you have multiple "routers" on your network acting as DHCP servers?
Hope this helps.
May 27, 2009 | D-Link DP 300 (DP-300) Print Server
Wan indicator does not light up..
Hi there
Getting Started
Setting up a Wireless Infrastructure Network
Please remember that D-Link AirPlus G wireless devices are pre-configured to connect together, right out of the box, with their default settings.For a typical wireless setup at home (as shown above), please do the following:
1) You will need broadband Internet access (a Cable or DSL-subscriber line into
your home or office)
2) Consult with your Cable or DSL provider for proper installation of the modem
3) Connect the Cable or DSL modem to the DI-524 Wireless Broadband Router
(see the printed Quick Installation Guide included with your router.)
4) If you are connecting a desktop computer to your network, install the D-Link AirPlus G DWL-G510 wireless PCI adapter into an available PCI slot on your desktop computer. You may also install the DWL-G520, or the DWL-520. (See the printed Quick Installation Guide included with the network adapter.)
5) Install the D-Link DWL-G630 wireless Cardbus adapter into a laptop computer.
(See the printed Quick Installation Guide included with the DWL-G630.)
6) Install the D-Link DFE-530TX+ adapter into a desktop computer. The four Ethernet LAN ports of the DI-524 are Auto MDI/MDIX and will work with both Straight-Through and Cross-Over cable. (See the printed Quick Installation Guide included with the DFE-530TX+.)
Using the Configuration Menu
Whenever you want to configure your network or the
DI-524, you can access the Configuration Menu by
opening the web-browser and typing in the IP Address
of the DI-524. The DI-524 default IP Address is shown
bellow:
-Open the web browser
-Type in the IP Address of
the Router (http://192.168.0.1)
Note: if you have changed the default IP Address assigned
to the DI-524, make sure to enter the correct IP Address.
-Type admin in the User
Name field
-Leave the Password blank
-Click OK
The Home>Wizard screen will appear. Please refer to the Quick Installation Guide for more information regarding the Setup Wizard.
Home > Wizard
These buttons appear on most of the configuration screens in this section. Please click on the appropriate button at the bottom of each screen after you have made a configuration change.
Home > Wireless
SSID- Service Set Identifier (SSID) is the name designated for a specific wireless local area network (WLAN). The SSID’s factory default setting is default. The SSID can be easily changed to connect to an existing wireless network or to establish a new wireless network.
Channel- 6 is the default channel. All devices on the network must share the same channel. (Note: The wireless adapters will automatically scan and match the wireless setting.)
WEP- Wired Equivalent Privacy (WEP) is a wireless security protocol for Wireless Local Area Networks (WLAN). WEP provides security by encrypting the data that is sent over the WLAN. Select Enabled or Disabled. Disabled is the default setting. (Note: If you enable encryption on the DI-524 make sure to also enable encryption on all the wireless clients or wireless connection will not be established.)
WEP Encryption- Select the level of encryption desired: 64-bit, or 128-bit
Key Type- Select HEX or ASCII
Keys 1-4- Input up to 4 WEP keys; select the one you wish to use.
Home > WAN > Dynamic IP Address
Host Name- The Host Name is optional but may be required by some ISPs. The default host name is the device name of the Router and may be changed.
MAC Address- The default MAC Address is set to the WAN’s physical interface MAC address on the Broadband Router. It is not recommended that you change the default MAC address unless required by your ISP.
Clone MAC Address- The default MAC address is set to the WAN’s physical interface MAC address on the Broadband Router. You can use the “Clone MAC Address” button to copy the MAC address of the Ethernet Card installed by your ISP and replace the WAN MAC address with the MAC address of the router. It is not recommended that you change the default MAC address unless required by your ISP.
Home > WAN > Static IP Address
Static IP Address- IP Address-
Subnet Mask- ISP
Gateway Address- Primary
DNS Address- Secondary
DNS Address- Choose Static IP Address if all WAN IP information is provided to you by your ISP. You will need to enter in the IP address, subnet mask, gateway address, and DNS address(es) provided to you by your ISP. Each IP address entered in the fields must be in the appropriate IP form, which are four octets separated by a dot (x.x.x.x). The Router will not accept the IP address if it is not in this format.
IP Address- Input the public IP Address provided by your ISP.
Subnet Mask- Input your Subnet mask. (All devices in the network must have the same subnet mask.)
ISP Gateway Address- Input the public IP address of the ISP to which you are connecting.
Primary DNS Address- Input the primary DNS (Domain Name Server) IP address provided by your ISP.
Secondary DNS Address- This is optional.
Home > WAN > PPPoE
*** Please be sure to remove any existing PPPoE client software installed on your computers.
Choose PPPoE (Point to Point Protocol over Ethernet) if your ISP uses a PPPoE connection. Your ISP will provide you with a username and password. This option is typically used for DSL services. Select Dynamic PPPoE to obtain an IP address automatically for your PPPoE connection. Select Static PPPoE to use a static IP address for your PPPoeE connection.
PPPoE- Choose this option if your ISP uses PPPoE. (Most DSL users will select this option.)
Dynamic PPPoE- receive an IP Address automatically from your ISP.
Static PPPoE-you have an assigned (static) IP Address.
User Name- Your PPPoE username provided by your ISP.
Retype Password- Re-enter the PPPoE password
Service Name- Enter the Service Name provided by your ISP (optional).
IP Address- This option is only available for Static PPPoE. Enter the static IP Address for the PPPoE connection.
Primary DNS Address- Primary DNS IP address provided by our ISP
Secondary DNS Address- This option is only available for Static PPPoE. Enter the static IP Address for the PPPoE connection.
Maximum Idle Time- Enter a maximum idle time during which Internet connection is maintained during inactivity. To diable this feature, enable Autoreconnect.
MTU- Maximum Transmission Unit-1492 is the default setting-you may need to change the MTU for optimal performance with your specific ISP.
Auto-reconnect- If enabled, the DI-524 will automatically connect to your ISP after your system is restarted or if the PPPoE connection is dropped.
Home > LAN
LAN is short for Local Area Network. This is considered your internal network. These are the IP settings of the LAN interface for the DI-524. These settings may be referred to as Private settings. You may change the LAN IP address if needed. The LAN IP address is private to your internal network and cannot be seen on the Internet.
IP Address- The IP address of the LAN interface. The default IP address is: 192.168.0.1.
Subnet Mask- The subnet mask of the LAN interface. The default subnet mask is 255.255.255.0.
Local Domain- This field is optional. Enter in the local domain name.
Home > DHCP
DHCP stands for Dynamic Host Control Protocol. The DI-524 has a built-in DHCP server.
The DHCP Server will automatically assign an IP address to the computers on the LAN/
private network. Be sure to set your computers to be DHCP clients by setting their TCP/
IP settings to “Obtain an IP Address Automatically.” When you turn your computers on,
they will automatically load the proper TCP/IP settings provided by the DI-524. The
DHCP Server will automatically allocate an unused IP address from the IP address pool
to the requesting computer. You must specify the starting and ending address of the IP
address pool.
DHCP Server- Select Enabled or Disabled. The default setting is Enabled.
Starting
IP Address- The starting IP address for the DHCP server’s IP assignment
Ending
IP Address- The ending IP address for the DHCP server’s IP assignment
Lease Time- The length of time for the IP lease. Enter the Lease time. The
default setting is one hour
Advanced > Virtual Server
If you would like to view more of this manual CLICK HERE
Thank you for using FixYa. Have a nice day and please remember to give this solution a good rating.
Jun 28, 2008 | D-Link AirPlus DI-524 Wireless Router
Panasonic DP-8035 Grayscale Copier Logo
454 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
