Question about Gateway 7001433 Keyboard
The n40 36c2 d6esnt w6r2 and neather d6es fn 6n 0y 3a*t6*
Keyboard malfunction. i have to use the on screen-keyboard. here is the same text from the actual keyboard. 2eyb6ard 0a3f4nct56n. 5 have t6 4se the 6n screen 2eyb6ard.
It looks as if your function (fn) key has jammed. I would carefully pull up on the key to try and get it to unstick. If you can't do it with your fingers, do it carefully with a small screwdriver.
Apr 22, 2011 | ASUS Eee Pc 904Ha Notebook
H6w t6 f5x 0y 2eyb6ard
Some keyboards have a feature called "Number Lock" It is mostly found on laptops. But turn it off to regain your default keyboard. On most keyboards it is located near the screen shot, print screen buttons. Push your shift key and the NumLk/ScrnLk button, and your keyboard should return to default.
Hope this helps...... :)
Jan 30, 2011 | Computers & Internet
Gett5ng n40bers 5nstead 6f 3etters
3ETTERS AD N40BERS 05XED 4* 6N 0Y GATEWAY
Jan 27, 2011 | Gateway 7001433 Keyboard
How do I turn off the FN function key h6w d6 5 t4rn 6ff the FN f4nct56n 2ey I have to keep holding it to type!
Hi and Welcome to Fixya
Seems like the number keypad is locked. Press and hold the Fn key then ap the numlock key once. This will disable the number lock.
Thank you and have a good one!
Jan 22, 2011 | HP Compaq 6720s Notebook
Numeric Keypad
if you search on the keyboard keys there will be one key that says "NUM LOCK" on it pressing which you will be able to turn on or turn off the numeric keypad on the keyboard.
Apr 22, 2009 | Computers & Internet
Keys
if that is a laptop catherine which i suspect it is. locate the number lock key and toggle it off. might be labeled just have two letters NM.
Robert
Sep 18, 2008 | Acer NSK8458AN Keyboard
My keyboard
yaa bcoz you have made your Numlock On thats why keyboard gives you these characters. You can see a led 'on' on your keyboard near Num Lock.
To make it off press and hold Fn kye (left side bottom row of the keboard) and press Num Lock kye (Top row right side). It will make your Num Lock on/off.
Thanks
Iqbal
Apr 12, 2008 | IBM ThinkPad T30 2366 Notebook
Gateway 7001433 Keyboard Logo
537 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
