DVD player the unit is a VCR & DVD player by Panasonic---it will play normal for about 2-3 minits & then a clicking sound for about 1 minit ---next it will free up & a notice will appear on the screen " check for schrees"---we have used a laser lens cleaner by Philips with no emprovement---please advise
    Problem Solver:
  • 5 Answers
Check with a brand new cd dvd .
if does not work.
try to get it replaced if under warranty.
if not change the lens.
Posted on May 24, 2008
No sound when I play back a commercial DVD
May be something wrong with HDMi cable.
Is there sound when play VCR?
Please test - check with regular RCA cable AV out.
If OK. Next step Replace HDMI cable.
IF No sound with RCA cable look like need replace VCR Main Board.
Feb 20, 2015 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Require a Unlock Code for region free
DVP 3618 - how to unlock region codes?
1. Power ON the DVD player with no disc inside
2. Go to the SETUP icon and press OK; next, go to
Preferences and press OK
3. With preferences highlighted,
3a. Press NEXT CHAPTER (button above AUDIO, it looks like
this: >'),
3b. Press PREVIOUS CHAPTER (button above SUBTITLE, it looks
like this: '<)
3c. NEXT CHAPTER >'
3d. PREVIOUS CHAPTER '<
4. The OSD will show the current Region Code
5. Press the Navigation Up or Navigation Down buttons to
select your desired region, or 0 for region free
6. Press OK to confirm your region selection
It works for DVP 3618 model.
Dec 04, 2013 | Panasonic DMR-EZ47V DVD Recorder/VCR
My panasonic dvd/vcr combo displays the message DV D 2 in the display. Cnnot play DVD
Sounds like your remote code is different to what's in the unit's display (DVD 2). You can try to 'reset' the remote, by pressing (and holding) 2 and ENTER/OK buttons together for 5 - 10 seconds, then release. This should restore your remote function back to your unit. If it does not, replace the batteries with new ones, and try again.
The remote may require a 'reset' of its command mode (to match the unit) whenever the batteries are replaced.
I assume you can play DVD by pressing the PLAY button on the main unit.
Apr 28, 2011 | Panasonic DMR-EH55 DVD Recorder/HDD...
When I press the TV/VCR button on the remote, the picture on the TV becomes fuzzy and we see no signal from the DVD player. The first sign we were having trouble was that we couldn't set the time...
The TV/VCR button is usually not a function of a DVD player itself.
Normally this is a button on VCR remote controls that allow you to switch between whats playing in the VCR or whats coming in from the 'air/cable signal' from the cable or antenna wire on the back.
If this is a VCR/DVD player combo unit it would appear that the TV may be on the wrong channel for proper operation of the VCR functions (ch 3 or 4 are usually the selectable option on the back of the unit).
Make sure your DVD player is plugged into the correct input on the TV(video 1/svideo/or component ) and the TV is tuned to that same input. If the TV is on the correct input then the TV/VCR button shouldn't do anything at all which is normal operation when watching a DVD. If this doesn't clarify please reply with the model # of the unit. I would be happy to help more.
Aug 05, 2009 | Panasonic Televison & Video
DVD won't play
Its Sounds as if your DVD went kaput this tends to be a problem with most combination players usually the VCR goes first also you may need to run a cleaning CD made for DVD players maybe that will help.
Apr 03, 2009 | Samsung DVD-V3500 DVD Player/VCR
1/2 Grey Screen when switched to DVD and VHS
First of all,i don't know if you have a combo dvd/VCR player or two separate units.Secondly,please tell me how you connect your dvd/VCR combo OR DVD player and VCR player to your TV.
Solutiondoct
Oct 22, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Sony DVP-NS575P DVD/CD player
Hook the Yellow, Red and White cables properly in both TV and Player. Play the DVD Player and select A-V Input by TV remote at TV.
Aug 10, 2008 | Sony DVP-NS575P DVD Player
Panasonic DMRES30V DVD Unlock code
Try This ..Turn On player with no disc inserted
While pressing Shift on the remote press Setup
Press Enter twice
Move the cursor to Other
Enter the appropriate four-digit region setting, beginning with 000
Press Enter
Press Return twice
Switch unit Off for at least 3 seconds
Found at http://www.dvdhacks.co.uk/hacksearch/hacksearch.asp?player=PANASONIC
Jul 21, 2008 | Panasonic DMRES30V DVD Recorder/VCR Combo
Panasonic DMR-EZ47V Fuzzy horizontal line in VHS mode
Dirty heads or the recording was from a different brand VCR and the Panasonic cant get the right tracking. Try manual tracking just a little in either direction to you get the right one.
May 18, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Does not playing DivX movies
Its not supposed to play Dix AVI movie files.
For a DVD player to play anything other than a DVD movie the manufacturer must pay royalties to who ever owns the patent, for example they would have to pay Philips say $1 for every DVD player made that plays VCD's, that may not sound a lot but, make 100,000 dvd players and they would have to pay Philips $100,000.
The technology has to be put into the device for it to work.
Hope that helps.
Feb 16, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
53 people viewed this question
 Grubhead
Grubhead
