Question about Toshiba Satellite A60 Notebook
My toshiba turned off about a month ago, it wouldnt work at all. the keys first got all sticky so i tried to clean the keys off. it wont turn on. it would show that it was charging, but then it wouldnt show it any more. and now the battery light isnt on either and my computer is turning on. help?
    Scholar:
  • 104 Answers
Unless you are comfortable in taking apart your laptop to find out what might be causing the problem, you should take your laptop to your local repair store and see if they can fix it. My best guess is that some sort of juice or fluid has been spilled on the laptop and this is causing alot of internal problems (fluids and circuits don't mix well in most circumstances). There is a good possibility that the damage is permanent.
After re-reading your post carefully, at the end are you saying the the laptop now turns on?
Posted on Sep 27, 2010
    Sergeant:
    Champion:
  • 214 Answers
Please clear whether your computer is getting ON or not.
You can try to bypass your battery (Remove the battery and connect the Power cable). Make sure now your machine should be switch ON. If it is then Just wait for 5mins, Swithc OFF your laptop and connect the battery again. Now it should be working.
Keyboard keys wont type. used on screen keyboard to type this. any suggestions?
You might have "sticky keys" so try this:
When sticky keys are enabled, users can access functions that require pressing multiple modifier keys such as "Ctrl," "Alt" and "Shift" at once by pressing one button at a time. If sticky keys are enabled, it is possible to accidentally turn them on at an unwanted time. After turning off the sticky keys, disable the feature to prevent them from accidentally turning on again.
    • Press the "Shift" button five times in a row to turn off sticky keys.
    • Open the "Start" menu and then click "Control Panel."
    • Click "Ease of Access Center" from within the Control Panel window.
    • Click "Make The Keyboard Easier To Use" from within the Ease of Access Center window.
    • Remove the check-mark beside "Turn On Sticky Keys" to prevent sticky keys from being accidentally turned on.
    • Click "Apply" to save your changes and then click "OK" to close the window.
Hope this helps. Good Luck!
Aug 05, 2013 | Toshiba Satellite L645DS4040 Laptop
(Ignition) Key won't turn. Happened about a year ago and locksmith WD40'd it, worked fine til about a month ago, key got stuck, I did same (WD40) now the WD40 isn't working and the key won't turn (I also...
graphite is what needs to used on sticky tumblers oils are the worst and causes more problems. you may be able to wiggle the wheel and get the key out. I would put graphite on the new/other key before I inserted into the ignition. Good Luck Tim
Apr 17, 2011 | 2002 Jeep Liberty
Sticky keys L45-S7419 Laptop
Hey there , you can visit this company www.laptopkey.com they sell laptop keyboard keys ,you can get the sticky keys replaced by them .. i got new keys from them a month ago, and they working great now :)
Jun 02, 2010 | Toshiba Satellite P205-S6237 Notebook
406 wont lock/unlock please help!!!
Switch ignition ON.Press and hold lock button for 10 sec.Switch ign.Off.Remove key from ign. switch.Wait 5 sec.Sinchronization procedure complete.Confirm sinchronization has been successful by locking,double locking and unlocking vehicle. Repeat abuve procedure to sinchronize any remaining key.Good luck
Nov 30, 2009 | 2005 Peugeot 405
Car wont start. when key is turned i get weird clicks.
You said you checked your battery, did you check volts and amps? It's possible that your battery is not functioning properly. You may need a new one. Does it start if you try to jumpstart it?
Nov 12, 2009 | 2004 Chevrolet Malibu
99 jetta headlights wont turn on, replaced 4mo ago.
If the bulbs and relays are good, then the switch is faulty.
Sep 13, 2009 | 1999 Volkswagen Jetta
2003 Trailblazer- no power after key stuck in ignition
Sounds like an antitheft problem I would start with the antitheft system. Usually when you only have one key all keys have to be programmed together even the original. When you have more than one it is easy to program additional keys.
Apr 11, 2009 | 2003 Chevrolet TrailBlazer
Will not start or even turn over
the starter motor has worn out it needs to be reconditioned
Oct 20, 2008 | 1989 Pontiac Firebird
Power button problem
As you said, its 4 months old and assumed under warranty cover. Contact Sony Service Center for repair because if you try yourself, will void warranty.
Aug 15, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Toshiba Satellite A60 Notebook Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
