Question about AEG 7.59 cu. ft. / 215 liter Upright Freezer A75238GA
Alarm light keeps flashing - AEG 7.59 cu. ft. / 215 liter Upright Freezer A75238GA
Inhave just reurned from a short holiday and found My Miele f1313s freezer has the alarm light flashing. Thoughts?
Make sure you have enough amps in the outlet its plugged into. The kitchen outlet might of had more amps than the garage outlet. Also, try unplugging it for a few seconds then plug it back it which might reset it.
Sep 20, 2014 | Miele 3.7 cu. ft. / 105 liter Upright...
No alarm sounding but red light is flashing?
Warning light (red)
If the temperature warning light (4) lights up, it
indicates that the temperature within the freezer has
reached a level where the safe food storage is no
longer ensured. When the freezer is first switched on, the warning light will stay on until the temperature has dropped to
a safe level for the storage of frozen food.
Temperature acoustic alarm
This appliance incorporates an alarm which gives off
an audible signal whenever the warning light comes
on. This signal can be temporarily stopped by
depressing the push button for fast-freezing (6).
The fast-freezing push button can be released as
soon as the warning light is off.
Open door acoustic alarm
This appliance also incorporates an alarm which
sounds if the door is left open for more than 60
seconds. The signal will be stopped when the door is
closed again.
Dado
Sep 02, 2014 | Zanussi 3.53 cu. ft. / 100 liter Upright...
Why is the red light flashing on my zft810fw freezer when it is freezing ok inside
Under normal operating conditions, the internal
temperature of the freezer will ensure the longterm
conservation of the stored food.
When such temperature rises above a certain
level (-12 °C), the appliance will trigger an
acoustic and light alarm. The light alarm is a
blink red light (Red Alarm Indicator Light), while
the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing
the Acoustic Signal Stop Switch once.
When switching on the freezer for the first
time, the Red Alarm Indicator Light will
blink until the internal temperature has reached
a level required for the safe conservation of frozen
food.
Dado
Jul 08, 2014 | Zanussi Freezers
Alarm keeps going off
Alarm will sound if the temperature of the freezer rises to unsafe levels. An indicator light will flash and continue to flash until the temperature reaches a safe level. The buzzer will also sound and will continue for 48 hours unless a safe condition exists.
Dec 14, 2010 | Kenmore Freezers
Miele F7131 S The red alarm and the orange -32 degrees orange light on the front of my under counter freezer keep flashing. I have defrosted it. It appears cold but the lights will not stop flashing.
Freezer Temp. shoud be 0 to -5 Deg. if to warm it will set off the alarm. try unpluging or turn off power to freezer for 1 or 2 min. to see if it will reset.
May 17, 2010 | Freezers
Freezer Alarm keeps going off...
I think your freezer's coils have been damaged. Consult a enjinner.
Aug 10, 2009 | Kenmore Freezers
Freezer alarm and signal light comes on daily
The beeping and light indicates the need for a new battery (9v)
May 22, 2009 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Flashing power light on Kenmore upright freezer
If the yellow light is flashing it may mean that the 9 volt battery is dead.
On my Kenmore there's a small battery compartment on the bottom right of the unit - under the door.
Aug 10, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Temp alarm going off
What is the temp in the freezer, sounds like temp is to low..no water should be coming out of freezer, sounds like may be defrosting Need to check the temp to make sure its cold enough.. thats what that alarm is for
Aug 10, 2007 | Kenmore Freezer 20.3 cu. ft. Frost Free...
AEG 7.59 cu. ft. / 215 liter Upright Freezer A75238GA Logo
Top AEG Freezers Experts
Gil Shultz
Charles T Nevin
Charles T Nevin
Victor Nwachukwu
Victor Nwachukwu
Are you an AEG Freezer Expert? Answer questions, earn points and help others
