How do I access you tube in Turkey - Computers & Internet
    Scholar:
  • 65 Answers
Use this proxy
https://browse007.com
Posted on Sep 27, 2010
Is netflex ava?lable ?n Turkey
VPN offers everything SmartDNS does, but it also unblocks other websites that tend to be blocked in Turkey. ... However, the best way, at least as of now, is to get Netflix Turkey access is to get a VPN Service . There are a lot of service providers.
Nov 20, 2016 | Netflix
Tip
To remove transmission fluid.
If over fill transmission , you can take a turkey baster ,cut a pencil size hole in the bulb, add on a peice of 3/8 tubing about 3 ft long to the other end.Put the tubing down the fill tube.Squeeze the bulb ,then with the bulb squeezed cover the hole with your finger and release the bulb. Repeat this prosess removing your finger only long enough to sqeeze the bulb again.After doing this several times your turkey baster will be full of trany fluid,Pull your new tool 3/8 tubing and all out of fill tube and drain into an empty container.[ This will remove about a pint of fluid at a time ]
on Dec 02, 2009 | Vacuums
Ice maker will not fill with water.
You mean " Why The Water Doesn't Fill the Tray in Kenmore Ice Maker?"
Am i right to your question? Well, Kenmore brand refrigerators often have an ice maker that uses the water supply to create ice inside the freezer compartment. Some models have an ice dispenser on the freezer door for easy access, and others simply create ice and deposit it into a tray inside the freezer. While most ice makers should work well with basic maintenance and care, issues may occasionally arise. One such problem is if the water does not fill the tray to create ice inside the ice maker. Resolving this issue may be possible through some troubleshooting efforts.
1 Remove the ice bin from the freezer.
2 Fill a turkey baster with hot water.
3 Spray hot water from the turkey baster into the tube at the back of the ice maker, which may be frozen or clogged.
4 Repeat spraying water into the tube until the blockage or frost is removed.
5 Replace the ice bin into the unit.
Please let me know if this help you.
Thanks for using FixYa
Sep 06, 2011 | Refrigerators
We have a top freezer whirlpool gold refrigerator - the tube for the freezer seems to be frozen solid causing water to leak into the fridge. How do we get at that tube - we can only feel the hole in the...
You must remove items from the freezer and gain access to the rear panel via removing the screws on back panel and in most cases also removal of icemaker is a must. Then once access is gained then most bakers have a turkey baster get hot!! water and squirt water into drain area once water flow get a small flexible tube to insert into drain and then push what could be lodge in the peetrap built in the drain once done you good to go... it is a design issue on some models and the process may need to be done again....
Apr 02, 2011 | Refrigerators
Why youtube sometimes are not working in Turkey?
I think the government of Turkey has been blocking access to services of Internet to websites like Google and YouTube? Are you aware of this? Honestly, I was not but I have read that maybe your problem will be answered by this article: Breaking News: First YouTube now Google being banned in Turkey
Sep 17, 2010 | YouTube Videos
Inefficient high pressure cast iron propane burner
Make sure you are using an adjustible high pressure regulator. Make sure there are no obstructions insde the burner tube or burner holes.
Oct 31, 2009 | Thermos 0210-1309 Turkey Fryer
We have water in the button to turn the jets on so now they won't work. How do we get the water out?
The button is likely an "air switch" which uses a push button to send a puff of air down a tube to activate the switch at the other end. Since 99.9% of jetted tub makers no longer can use an electrical switch mounted at the surface of the tub, due to the possibility of contact with water (shock hazard).
The best way to clear the tube of any water is to remove the access panel (if you have one) on the tub, otherwise, you'll have to gain access from an adjoining room via a wall, etc. You can try to suction the wate from the tube, if you can remove the push button from the tub. I would try using a turkey baster or eye dropper to extract the water from the tube, but as I stated, the best way is to gain access to the inside of the tub components and remove the switch tube that way. It is possible that the push bulb switch has become disconnected from the actual switch mechanism and you'll need to reattach it anyway.
Check your owners manual to see where the switch is located, in case you need to get at the controls via cutting through an adjoining wall. This is why the manufacturer's all say these types of tubs should always be installed to allow access to the inside components for servicing, in case repairs are needed. Just an FYI, it is easier to repair and replace a small piece of drywall 16" by 16" than to have to repair tile work, etc. Of course, it all depends on what you're good at!
You might also want to contact Kohler to talk with one of their customer service people and see what they recommend you try. 1-800-456-4537
Hope you find this helpful and best regards!
Aug 06, 2009 | Kohler Archer 6ft Heated Whirlpool with...
Cannot get ice maker to fill with water
Check to see if the tube at the back is iced up. If it is, then water can't flow to the tray.
A simple way to fix the problem is to remove the ice bucket and use a turkey baster to spray hot water into the tube. It may take 15 or 20 minutes to unclog the tube.
IF Amana/Whirlpool conforms to wiring standards the main AC wires should be white=neutral, black=hot, red=switched line. Of course, they already depart with the use of the brown wire.
You should be able to access the 'full' switch at the ice maker itself and as you have found, it will turn on (or off) the fill solenoid.
Let me know if you have any other issues.
God Bless.
Jul 08, 2009 | Whirlpool Refrigerators
Freezer drain plug
Self defrosting refrigerators as well as freezers all have a defrost drain system. This drain system can become plugged or frozen causing defrost drain water to back up into the refrigerator or freezer compartment. The water may gather under the crisper drawers on top freezer models. On side by side, bottom or stand alone freezers ice will build up in the freezer at the bottom and eventually leak out the door.
Plugged Defrost Drain - Freezer on Top (Water under the crisper drawers)
At the top of the refrigerator next to the temperature controls there usually is a cup-like part that carries the defrost drain water into a tube and out the back of the refrigerator to a defrost drain pan behind the unit. Pull the cup out of the tube and clean the cup with hot water and soap. If there is no cup, pull the refrigerator out away from the wall, go behind it and disconnect the drain tube to clear it. If the drain tube is not accessible from the back or the drain can not be cleared from there the main back panel in the freezer can be removed to access, thaw and flush out the drain under the cooling coil.
Use a turkey baster to flush HOT water into the tube to clear any obstruction. The water squirted into the tube should end up in the defrost drain pan.
If the tube will not clear with hot water try blowing it out with compressed air.
Put the cup back on and make sure it is all the way on or in the tube.
Plugged Defrost Drain - Side By Side, Bottom-Freezer Refrigerator or Stand Alone Freezer
The defrost drain pan is located at the bottom of the freezer compartment behind the back wall of the freezer. On some models, the pan is accessible without removing the back panel and others are not. After you get to the defrost drain pan use a hair dryer to melt the ice from the pan.
Once the ice is removed use a turkey baster to squirt HOT water into the drain hole to clear the drain.
When the drain is clear you should hear or see the water you are squirting into the hole enter the pan under or behind the refrigerator.
TheRepairGuru ---- www.repairclinic.com
http://www.repairclinic.com/Whirlpool-Refrigerator-Parts
Jan 26, 2009 | Whirlpool ET9FTKXK Top Freezer...
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
